Revell 1/144 Fletcher build
DutchBird
#068
Zuid-Holland, Netherlands
KitMaker: 1,144 posts
AeroScale: 123 posts
Posted: Saturday, February 26, 2011 - 12:11 PM UTC
Thanks Harm! As I said: it pokes you in the eye at first but as you add more bits and pieces it fades and just looks well used. Mind you, it is an easy way to ruin a build if things go pear shaped.
Julian
You are right there... the same, in my opinion, goes for depicting worn ships in general. To me it seems really hard to pull it off convincingly, esecially with naval vessels (which are usually modelled). You seem to have succeeded with depicting a worn lower hull though.
Harm
Gremlin56
KitMaker: 3,897 posts
AeroScale: 564 posts
Posted: Saturday, February 26, 2011 - 06:37 PM UTC
Thanks Harm, now that was an interesting experiment
I had my trusty bottle of "brand spiritus" at the ready to strip everything if it went wrong but luckily it turned out ok.
Julian
Gremlin56
Posted: Sunday, February 27, 2011 - 12:45 AM UTC
Nice work Julian - I have to admit I wasn't to impressed with the glaze on the deck when you first showed it but it has 'settled down' very nicely.
John
Thanks John, I have received a couple of reactions about the glaze.Is it the photos I posted with the wet paint? It looks really dire there.
Julian
Gremlin56
Posted: Friday, March 04, 2011 - 05:25 AM UTC
Update March 4th: Back to work on the "Chevy" after a submarine interlude
Fixed the deck houses to the hull and have started washing, glazing and weathering to turn the build into a working war horse:
I'm taking things slow and gentle so bear with me on this part.
Julian
johndon
KitMaker: 120 posts
Posted: Saturday, March 05, 2011 - 01:08 AM UTC
Looking very nice indeed Julian.
John
Gremlin56
Posted: Saturday, March 05, 2011 - 08:14 PM UTC
Thanks John, still a long way to go yet but looking more like a ship now
Julian
Gremlin56
Posted: Sunday, March 06, 2011 - 01:36 AM UTC
March 6th update: salt streaks and railings. Oil dot washings on the hull. Have added what I presume is the chartroom and the CIC, (not too sure if that is correct).
Also started adding the railings:
That is all for the moment,
Julian
javlin
Mississippi, United States
KitMaker: 106 posts
AeroScale: 7 posts
Posted: Thursday, March 10, 2011 - 04:44 AM UTC
Julian she is looking righteous Sir!! One day i hope when I grow up I will be that good at weathering Cheers Ole Boy Kevin
Gremlin56
Posted: Thursday, March 10, 2011 - 06:08 AM UTC
Hi Kevin, you are much to kind Thank you very much.
regards,
Julian
Dangeroo
#023
Zurich, Switzerland
KitMaker: 2,058 posts
AeroScale: 67 posts
Posted: Thursday, March 10, 2011 - 09:30 PM UTC
Hi Julian! Your weathering is outstanding! I'm looking forward to further progress!
Cheers!
Stefan
aturnbull
KitMaker: 8 posts
Posted: Thursday, March 10, 2011 - 10:53 PM UTC
Hi julian i came back to modeling about a year ago and after building a few ships in 1/700 [and not doing very good jobs] i saw this model.It was the first large scale ship i had came across so i bought it and got a pe railings set from eduard. I finished it [again not great] so started looking for another and was pleased to get one in 1/144 again.This one was from the german navy.It was after i got it home that i found out it was the same model with some slight differences.But i dont really mind as i will not make some of the mistakes i made on the original.The question i have is what did you use to achive the weathered look on the hull it looks really good as does the rest of your weathering.regards anthony
Gremlin56
Posted: Friday, March 11, 2011 - 12:51 AM UTC
Hi there Stefan, thanks mate ! Glad you like the effect.
Hello Anthony, the effects are no real big deal: underwater hull was achieved with a base layer, sponge applied liquid masking and a darker layer of acrylic sprayed over the masking. Remove the masking and there you go, (mind you I did do a couple of practice runs on a scrap model). If things go pear shaped you can remove the paint with methylated spirits and start all over again. the weathering on the decks is done with a glaze of artists oils, (go for the best quality you can afford, preferably WIndsor & Newtons). The outer hull is done using the dot oil technique, (plenty of articles on this online). Don't go mad, Navy vessels are well maintained by huge crews. After heavy use and low maintenance situations you will get salt stains, dirt and light rust around fairleads, anchors bollards, but you will not get a run down rusty garbage scow. Go lightly
Practice, practice and more practice.
cheers,
Julian
surfsup
KitMaker: 1,230 posts
Posted: Friday, March 11, 2011 - 02:11 PM UTC
Really starting to come together now Julian and looking great....Cheers Mark
Gremlin56
Posted: Saturday, March 12, 2011 - 02:45 AM UTC
Thank you Mark, just adding the March 12th update: working on the bridge deck and wheelhouse. Fit at the front of the superstructure isn't too good. Think now I should have taken another route to building this so that the front could be sanded flush. Doesn't look like that is a good idea now :
cheers,
Julian
Gremlin56
Posted: Sunday, March 20, 2011 - 03:15 AM UTC
March 20th update:
Bridge now fitted with railings on topdeck. Searchlights and signal lights fitted, ( used 2 of Dmitri Kovalev's "Elf production headlights" for the signal lamps). Stacks are now permanently attached and the first quintuple torpedo launcher has been fitted. Now working on the aft AAA gun tub:
cheers,
Julian
RedDuster
KitMaker: 7,078 posts
Posted: Sunday, March 20, 2011 - 10:40 PM UTC
Great Work Julian.
The more I look at builds of this kit, the more I am tempted to have a bash at it myslef.
Si
surfsup
Posted: Monday, March 21, 2011 - 02:29 AM UTC
Likewise Julian. She is coming along beautifully.....Cheers Mark
Gremlin56
Posted: Monday, March 21, 2011 - 07:29 AM UTC
Simon, Mark, thanks guys, very kind of you both. This is a really enjoyable build, no real big niggles with the Revell offering or the Eduard PE set. Fit a bit rough at the front of the bridge, (would tackle this differently with the benefit of hindsight ).
If you go for a build get hold of a PE set somewhere, otherwise it's a bit dire, reminiscent of Revell's Tirpitz.
cheers,
Julian
Dangeroo
#023
Zurich, Switzerland
AeroScale: 67 posts
Posted: Monday, March 21, 2011 - 07:42 PM UTC
Julian, great progress, as always. Am still watching!
Cheers!
Stefan
Gremlin56
Posted: Tuesday, March 22, 2011 - 05:54 AM UTC
Hi Stefan,
Thank you. PM concerning paint incoming
cheers,
Julian
javlin
KitMaker: 106 posts
AeroScale: 7 posts
Posted: Wednesday, March 23, 2011 - 03:35 AM UTC
She is coming along quite Nicely Sir Cheers
Gremlin56
Posted: Thursday, March 24, 2011 - 06:10 PM UTC
A very good morning to you Kevin Thank you very much,
cheers,
Julian
Gremlin56
Posted: Saturday, March 26, 2011 - 04:07 AM UTC
March 26th update: The stern gun tub is ready to fit. I will fit the railings on the upper deck before fitting the gun tub. Also in a fresh coat of Vallejo ground grey the Mk 37 gun director. This construction of PE nearly brought the whole build to a rather dramatic stop. One of the problems with utilising PE replacement parts is that you have to do some surgery on the plastic pieces, so once you make your choice there is in some cases no way back. I happily chopped the Mk 12 fire support radar mount off and ran into some of the most dire PE problems I have ever encountered It took nearly a week to get the radar to stay together and to fit to a very delicate frame, (wish fragile PE parts like this were supplied with a back-up in the set Hope some of the PE producers are listening out there). I have managed to get it to stay together and look barely acceptable. I still have to fit the Mk 22 "Orange peel" antenna but that should be plain sailing now :
I also fitted the signalman's pulpits to the wheelhouse roof railing.
Julian
Gremlin56
Posted: Sunday, March 27, 2011 - 02:45 AM UTC
Update 27th March:
Railings on upper deck, gun tub and Mk 37 fitted, (including orange peel scanner).
Have also fitted the torpedo derrick.
Pulled the "Chevy" out of the clutter on my workbench for a few quick "beauty shots":
Now for some touching up and paint repairs.
cheers,
Julian
Gremlin56
Posted: Friday, April 08, 2011 - 04:16 AM UTC
April 6th update:
I have started adding the main armament. Grinding off the molded details and adding PE hatches, covers and doors. The second set of tubes with the "doghouse" to protect the crew from the blast of forward facing turret. I am also adding the waist depth charge launchers and derricks to reload them, along with a tidy supply of ready charges:
Julian
