How to model a T-62
TopSmith
KitMaker: 1,742 posts
AeroScale: 14 posts
Posted: Sunday, November 17, 2019 - 04:21 PM UTC
Referring to welding track to the grab handles.
Most likely wire is used. It is also possible, but I do not know if this is what they did, that the tracks are welded to the grab handles.
The grab handles I have seen are hollow bent tubing. I dought anyone would weld to it. If one side of the grab handle is broken loose, it is not hard to bend it or twist it up, down or out.
seanmcandrews
KitMaker: 561 posts
Posted: Wednesday, October 12, 2016 - 10:19 PM UTC
This one
https://www.amazon.com/Soviet-T-62-main-battle-tank/dp/B0006F1QDE
seanmcandrews
KitMaker: 561 posts
Posted: Wednesday, October 12, 2016 - 09:07 PM UTC
Mike,
maybe thinking about the book by Pat Stansell published by Genadier Press ?
Sean
MLD
Vermont, United States
KitMaker: 3,569 posts
AeroScale: 419 posts
Posted: Wednesday, October 12, 2016 - 06:41 PM UTC
It really depends on what you need. If you want a good, brief, history lesson, the New Vanguard book from Osprey is pretty good.
If you want a good reference for model building detail missing in the kit, you want something different.
I am looking for a more detailed reference.
The old (ancient) Tamiya photo series book on the T62 is a pretty good reference and there was another.. I'll have to look in the library at home tonight.
Klaus-Adler
MODELGEEK
KitMaker: 1,504 posts
AeroScale: 193 posts
Posted: Wednesday, October 12, 2016 - 06:31 AM UTC
I have a trumpeter t62 mod 1972 and the drive sprockets are said to be on sprue "K"hhowever I don't have that sprue but I have located drive sprockets on the two "A" sprues minus the round disk with holes in it that goes in the middle of each sprocket, has trumpeter altered the spruce count and not the instructions or am I missing a sprue?
Sensha
KitMaker: 34 posts
Posted: Sunday, April 10, 2016 - 04:09 AM UTC
I've looked around the internet for some time but I have not come across a 1/35 scale 100mm U-8TS gun. Is there such an aftermarket item?
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
AeroScale: 79 posts
Posted: Tuesday, February 23, 2016 - 12:50 AM UTC
I'm looking at the Concord book by Zaloga. It's a bit pricey, but not too bad and seems to offer an in depth photo primer.
Jacques
Minnesota, United States
KitMaker: 4,630 posts
Posted: Monday, February 22, 2016 - 10:15 PM UTC
For detailed references, online is by far your best resource. There may be some Russian language books you can acquire, but off the top of my head, that is all I can think of.
retiredyank
AeroScale: 79 posts
Posted: Sunday, February 21, 2016 - 08:09 AM UTC
Jacques
Posted: Sunday, February 21, 2016 - 06:39 AM UTC
retiredyank
AeroScale: 79 posts
Posted: Saturday, February 20, 2016 - 04:00 PM UTC
With the resources posted, here I may not need one. However, I am soon to start my T62 mod 62 build and would like to know of any recommended reading. I am looking at T-62 Main Battle Tank 1965-2005 (New Vanguard). Will this one be helpful or is there better material out there?
Jacques
Posted: Thursday, February 11, 2016 - 07:45 PM UTC
KMT-5 mineroller from the OLD Trumpeter T-55 or T-72 kit with them. MiG does a KMT-7 mineroller in resin.
Detailing the inside of the T-62 hatches...probably have to do it yourself from scratch or cobbling pieces from other places. No replacement piece I know of. Will bring it up to SP Designs though...
retiredyank
AeroScale: 79 posts
Posted: Wednesday, February 10, 2016 - 04:04 PM UTC
I'm back at my 62 mod 62. Is there any media for detailing the inside of the hatches available?
I'm also searching for a kmt-5 mine roller.
retiredyank
AeroScale: 79 posts
Posted: Tuesday, February 09, 2016 - 10:28 PM UTC
RLlockie
KitMaker: 1,112 posts
AeroScale: 21 posts
Posted: Sunday, November 15, 2015 - 09:53 AM UTC
Ah, sorry. Must have missed most of the original post. Since the axis of the sprocket is fixed by the need for the final drive to be in line with the axle (track tension is adjusted at the idler with a much chunkier fitting than that bolt), that must be the oil filler for the final drive.
MLD
Posted: Sunday, November 15, 2015 - 08:10 AM UTC
Isn't it the lower part of the unditching log bracket? Or am I looking at the wrong thing?
Robert,
I think so yes. The unditching beam has two parts to the bracket, under that on the sprocket bulge, about even with the top of the tow hook, but under the (missing ) spring clip.
Removed by original poster on 11/15/15 - 21:56:21 (GMT).
RLlockie
AeroScale: 21 posts
Posted: Saturday, November 14, 2015 - 11:30 PM UTC
KurtLaughlin
KitMaker: 2,402 posts
Posted: Saturday, November 14, 2015 - 09:00 PM UTC
I have not seen the trumpeter T-62 m60 kit yet, do not know about the turret (though I suspect it is the same turret as in the m62 and m67 kits).
Trumpeter T-62 parts from HobbySearch. Click on box to view image.
M1960 (01546)
M1962 (00376)
M1962 ERA (01555)
M1972 (00377)
M1972 ERA (01556)
M1975 (01550)
M1984 BDD (01554)
Iraqi M1960 (01547)
Iraqi M1972 (01549)
MLD
Posted: Monday, September 28, 2015 - 05:26 AM UTC
Does anyone know the purpose of the fitting there on the left side, under the log brackets? The hex bolt there on the sprocket bulge, is it a filler port for oil or is it a tensioner for the sprocket?
I have seen excerpts from the maintenance manual, but cant make heads or tails of the Cyrillic.
phantom8747
Alabama, United States
KitMaker: 281 posts
Posted: Monday, September 28, 2015 - 05:00 AM UTC
Aftermarket T-62 barrells.I am looking for one that fits the Trumpeter mantlet w/o modifying the mantlet.Are ther any aftermarket barrels that are a direct fit.Thanks.
Jacques
Posted: Sunday, August 16, 2015 - 11:08 PM UTC
SP Designs kit 234 (T-62 m67)has a one piece turret with the turret ring under. It does improve the kit, pieces are pressure cast.
phantom8747
KitMaker: 281 posts
Posted: Friday, August 14, 2015 - 06:34 PM UTC
A few questions on the SP Designs T-62 1967 turret.How is it? Does it also include the turret ring? thanks.I am interested in getting one as it looks more accurate than the Trumpeter 1962 turret.Did they also put that turret in their T-62 1960 kit? Thanks.
MikeKeenan
Kildare, Ireland
KitMaker: 50 posts
Posted: Friday, July 24, 2015 - 02:30 PM UTC
Thanks for the info, Jacques.
Jacques
Posted: Wednesday, July 22, 2015 - 08:21 AM UTC
Yes. The T-62 m62/75 is a updated m62 with the added LRF. There are some other changes, but they are interior.
