Armor/AFV: Large Scale
DML 1/4 Ton 4x4 Truck
plane_mc
KitMaker: 91 posts
Posted: Wednesday, September 14, 2016 - 03:13 PM UTC
hi Mark your build looks absolutely amazing! i was wondering if you would be able to tell me how to make hinges for hatches and others? as i have several models that i would like to have unction hatches and/or bonnets
,Teague
Hi Teague,
The hinges on this build were mostly just either styrene rod or tubing, depending on the size of the hinge. If I used tubing, I drilled it out so I could use a piece of wire as the center pin. The tubes were then cut into small pieces and glued to the base and lid in alternate sections. After the glue dried, you can remove the wire and still have separate parts for painting. Hope that helps.
Mark
LiquidShovel
Tasmania, Australia
KitMaker: 13 posts
Posted: Saturday, September 17, 2016 - 09:01 AM UTC
Oh thank you!
And once again outstanding work on that model
