Armor/AFV
Road Wheel Set for SD.KFZ221
keenan
KitMaker: 5,272 posts
AeroScale: 74 posts
Posted: Saturday, October 03, 2009 - 01:28 AM UTC
Dave O''Meara reviews Bronco''s "Early Version Road Wheel Set for SD.KFZ221."
Damraska
KitMaker: 580 posts
Posted: Saturday, October 03, 2009 - 05:05 AM UTC
I second Dave's comments about the quality of these tires. They come from a six part mold--4 quadrants for the inner tread and two halves for the outer faces--with almost undetectable seams. You must look very close to find them.
To convert a given 221 model to an "early production" version really requires these tires, early visor covers, and an MG13. MG13 ammo stowage would also help given the full Bronco interior. Bronco could have offered a more useful set by including, at minimum, the visor covers and MG13, which they already make.
However, since Bronco sells "early" and "late(r)" versions of this vehicle, I doubt many people will need these tires for a Bronco kit. But wait! The entire 221, 222, 223, 260, and 261 range of vehicles used the same chassis and wheel assemblies. The "early" pattern tires offered by Bronco definitely appear on 221, 222, and 223 vehicles. The 260 and 261 were manufactured later and I have not seen a picture of either vehicle with these tires. But in theory all 5 vehicles could use them.
Probably the best use of these parts is for improving an old Tamiya 222 or 223 kit. The Bronco outer tire and rim parts fit corresponding Tamiya hubs, leaving only a small gap on the backside of the wheel to fill. I believe the full Bronco wheel assemblies will mate with a Tamiya chassis assembly but cannot (yet) confirm this. The Bronco and Tamiya parts are almost identical, dimensionally. If you do this, make sure to put the correct wheel assembly in the correct position. These vehicles have mirror inner hubs, front to back.
For those who really want to get particular, there may be two versions of the "early" pattern tire, one with solid face chevrons and one with grooved face chevrons. I have seen both on these vehicles, but cannot tell if the former is a worn version of the latter. Based on the depth of the tread, I think not. Anyway, the Bronco "early" tires represent the type with grooved chevrons. For the tire conscious, there are also at least two version of the "late" tire--one with perpendicular V cuts and one with angled V cuts.
Hi Dave, I will trade you something for those tires if you don't want them. Just send me a PM if you are interested.
-Doug
Grumpyoldman
Staff Member_ADVISOR
KitMaker: 15,338 posts
AeroScale: 836 posts
Posted: Saturday, October 03, 2009 - 07:45 AM UTC
PM me your address Doug.
I'll get them in the mail some time next week.
bizzychicken
Wales, United Kingdom
KitMaker: 967 posts
AeroScale: 5 posts
Posted: Monday, October 05, 2009 - 07:58 AM UTC
Not being an expert on this AFV, but I bet later in the war you might have seen these vehicles with a mix of new and old tires on them. When you think of Germanys rubber sortages late in the war any tires would have done, what ever was in stock would have been fitted to keep these AFV's running
WarWheels
Illinois, United States
KitMaker: 1,815 posts
AeroScale: 20 posts
Posted: Monday, October 05, 2009 - 08:19 AM UTC
...you might have seen these vehicles with a mix of new and old tires on them.
You are completely right. I found at least two photos of vehicles (in Ryton's book "Panzerspahwagen") with both pattern wheels mounted...
Grumpyoldman
Posted: Monday, October 05, 2009 - 08:35 AM UTC
OH- I agree.
I don't think the Germans were as self-absorbed as the "roll-over minutes boy" on the television.
Damraska
KitMaker: 580 posts
Posted: Monday, October 05, 2009 - 12:27 PM UTC
I see I am not the only one going cross-eyed looking at these things.
Here is my list of tire mismatches from the Ryton book:
p47, left picture, first vehicle, straight wedge front, early back
p59, first vehicle, straight wedge front, angled wedge back
p60, right top and bottom, straight wedge front left, early front right, rear may be angled wedge
p70 top right, early front right, straight wedge front left
p78 bottom, angled wedge both front tires, but oriented in opposite directions
p93 bottom, angled wedge front right, straight wedge front left
p112 right, straight wedge front left, angled wedge front right
-Doug
bill_c
KitMaker: 10,549 posts
AeroScale: 1,196 posts
Posted: Tuesday, October 06, 2009 - 10:13 AM UTC
That's a good idea, using them on the Tamiya kits! Too bad they won't work for the 232. I spent much more for resin upgrades, and they often don't fit all that well. Welding resin to styrene is also tricky IMO. Thanks, Doug, for the insight!
