making the best of raised panel lines...
discordian
KitMaker: 239 posts
AeroScale: 95 posts
Posted: Tuesday, July 14, 2009 - 03:40 AM UTC
And I mean making the best without sanding them off and rescribing them. I have no interest in doing that at this point.
So, short of making your own recessed panel lines do you do anything special to make the model look realistic?
alpha_tango
KitMaker: 5,609 posts
AeroScale: 5,231 posts
Posted: Tuesday, July 14, 2009 - 04:07 AM UTC
Hi Scott
In general, raised panel lines are as realistic as engraved ones. Often panels overlap or form a similar raised effect. I personally prefer engraved lines, but just for the techniques I am using, that work better with this type.
IMO it would be best if you keep the raised lines and try out some other techniques .. e.g. pre/postshading and drybrushing might work. If you have to remove panel lines (sanding and the like) you can restore them with streched sprue glued on with a bit of liquid cement.
others surely will add more hints
all the best
NormSon
KitMaker: 181 posts
AeroScale: 18 posts
Posted: Tuesday, July 14, 2009 - 11:44 AM UTC
Archer Fine Transfers has raised panel line replacements in their "Surface Details" line. They are decals and can be cut to the length that you need them.
