Sherman Tracks?
daleil
KitMaker: 59 posts
Posted: Saturday, June 21, 2003 - 12:07 AM UTC
Hy guys!
A new question:
Can I use the "Steel Bar Cleat" tracks for a late M4A1 Sherman which is used in 1945. Or must I use the usual Steel or Rubber Chevron tracks?
Thanks for any help!
Gre aus Deutschland
daleil
Kencelot
KitMaker: 4,268 posts
Posted: Saturday, June 21, 2003 - 12:27 AM UTC
Daleil, Yes. The T-49 three bar cleat could be used.
You could use nearly any of the track types on nearly any version of the M4. There was no true "standard" track type used. As the war progressed, rubber supplies dwindled, and the use of the all steel type tracks would seem more obvious.
DaveCox
KitMaker: 4,307 posts
AeroScale: 272 posts
Posted: Saturday, June 21, 2003 - 02:42 AM UTC
Different angle on the same subject - I'm looking to do a couple of dragon shermans but hate individual track links - apart from buying tamiya / italeri kits just to rob the track anyone know of a source for some decent tracks?
generalzod
KitMaker: 3,172 posts
Posted: Saturday, June 21, 2003 - 03:22 AM UTC
Dave,you may wanna try RHPS or AFV Club tracks for your Shermans Yes they are individual links,but they snap together They go together pretty easy
herberta
Canada
KitMaker: 939 posts
Posted: Saturday, June 21, 2003 - 03:56 AM UTC
Hi DaveCox
You have a couple of options.
1 - Contact Tamiya or Italeri directly and you can order parts.
2 - put a 'wanted' notice here in the Buy/Sell/Trade forum. I did that a while back and got lots of the rubber bands that folks don't use! I'm sure you could trade your indy links with someone out there!! Try posting on TL and Hyperscale too, and cover all the bases!!
Posting a set of tracks overseas is cheap (I've done it).
Good luck in your search
Andy
Kencelot
Posted: Saturday, June 21, 2003 - 04:31 AM UTC
Dave, check your PM's!
stufer
KitMaker: 416 posts
Posted: Saturday, June 21, 2003 - 08:05 AM UTC
daleil and dave,if you're not keen on individual links,have you been to Accurate Armour's site,and check out the resin Traxpax they stock?they are more 'link and length' than seperate links,but are pretty well detailed and semi flexible,nice selection of M4 tracks too,prices around the 10 mark
Sabot
KitMaker: 12,596 posts
AeroScale: 287 posts
Posted: Saturday, June 21, 2003 - 09:16 AM UTC
AFV Club makes several one piece vinyl tracks for the Sherman series tanks. They come in two sizes, regular and the extended size to be used on British Shermans based on the M4A4 chassis. I have a set of the 3-bar cleat tracks for the regular hulled Sherman. They are number AF 35027 T49 track.
Kencelot
Posted: Saturday, June 21, 2003 - 10:19 AM UTC
Rob, how do AFV's compare to the typical ones you get in Tamiya's kits? Good detail? Paint-able?
I've never seen them.
daleil
KitMaker: 59 posts
Posted: Saturday, June 21, 2003 - 10:04 PM UTC
Hy!
I'm going to use some ready tracks, no individual links. I use T-49 from the Academy M-10 (he got other tracks), but maybe I'll use some individual links for the other Sherman.
IMPORTANT!
Where can I get interior kits for Sherman (M4A1 Italeri or M4A3 HVSS Dragon), Verlinden??
Thanks for help!
Gre aus Deutschland
daleil
Kencelot
Posted: Sunday, June 22, 2003 - 12:06 AM UTC
Daleil,
Commander Series Models has a set which is for all M4's; Kit # 2051:
The Tank Workshop has an M4 Late Interior/ Wet Stowage kit # 0023 which may work in the Dragon kit: ??? Note They also produce an early M4 interior which states it's for the DML and Tamiya kits.
Verlinden's interior set, kit # 1244 is actually for Tamiya's M4 Early Production version.
I don't now if any of these kits could be used in kits other than the ones their respective manufactures state. ???
Sabot
Posted: Sunday, June 22, 2003 - 02:45 AM UTC
Better detail, haven't tried painting them yet though.
herberta
Canada
KitMaker: 939 posts
Posted: Sunday, June 22, 2003 - 04:54 AM UTC
Hi
Regarding the T49 tracks from AFV Club, I used the Academy set on my M4A176(w). They painted up well, and fit nicely. I used acrylics and oils to do the weathering.
I assume the AFV Club ones will be similar, but someone out there must have an M10 with those tracks on it...
Andy
avukich
Virginia, United States
KitMaker: 760 posts
Posted: Monday, June 23, 2003 - 01:08 AM UTC
I would suggest staying away from the Commander's Series interior as it is pretty lame. My copy is plagued by many airbubbles and it doesn't include half of what you need (there is absolutely nothing included for the turret interior).
With a little work I would think the Tank Workshop and Verlinden interiors could be made to fit into any Sherman kit out there. I have not seen the TW kit, but the Verlinden one is actually the best Verlinden item I have ever seen (I'm not a big fan of Verlinden, but I really like this kit of theirs).
Greg
Oregon, United States
KitMaker: 455 posts
Posted: Tuesday, June 24, 2003 - 06:55 AM UTC
I've used Accurate Armour tracks on several projects and love them. They are easy to shape with heat from a hair dryer, and easy to cut too. Usually three lengths are glued together and run over the top of the sprocket, return rollers, and idler. Then with applied heat soften them and ben them 'round. Easy. The gap on the bottom can be filled with a piece cut from another length. On short-hull Shermans you'll end up with a spare set of tracks after purchasing four sets of the same type, since they give you extra track to do an M4A4 hull.
Greg
