Start Here (for Beginners)
How do I stop masking bleed.?
lampie
#029
KitMaker: 6,249 posts
AeroScale: 3,270 posts
Posted: Saturday, March 28, 2009 - 10:59 PM UTC
Hi Chris.
The bleeding is caused by the paint being forced under the tape.
If you spray directly down onto the tape this should eliminate the bleed.
As everyone has said, thin coats is the way to go.
Hope this helps
fantacmet
Oregon, United States
KitMaker: 104 posts
AeroScale: 37 posts
Posted: Saturday, March 28, 2009 - 04:04 PM UTC
Before each color, lay down a thin coat of clear. If it's a glossy surface, use gloss clear, if it's flat, then use flat clear. I do this when painting multi colored paint jobs on model cars, and that's one subject where the demarcation line has to be FLAWLESS. Works like a charm. You are getting some bleed under from the clear, but being clear you don't notice it. The clear will also seal the edge of the tape.
drabslab
KitMaker: 2,174 posts
AeroScale: 1,587 posts
Posted: Thursday, October 02, 2008 - 04:55 AM UTC
burnishing the tape down really good and light coats will work.
and use several thin coats instad of one thick one
and spray "away" from the edge of the mask and never towards it
calvin2000
KitMaker: 886 posts
AeroScale: 332 posts
Posted: Thursday, October 02, 2008 - 02:00 AM UTC
Tomcat31
#042
KitMaker: 2,828 posts
AeroScale: 1,720 posts
Posted: Thursday, October 02, 2008 - 01:38 AM UTC
I use Tamiya Masking tapes exclusively for my canopy maskings. After applying the tape and cutting the framing out, I normally cut the end off of a cocktail stick and then "burnish" the remaining tape down.
I would also If using a rattle can spray several light coats and remove the tape once the paint was touch dry but not fully cured.
Hope this helps
Allen
BoogalooJ
KitMaker: 230 posts
Posted: Wednesday, October 01, 2008 - 03:50 PM UTC
If you're using acrylic paints, there is a new masking tape on the market that prevents bleeding, but only for acrylics. I haven't seen it or tried it, just saw an ad for it the other day. Not even sure if it has any use in modeling (may be too thick or aggressive), but I sure want to try it out and see.
It's called frog tape, and here is a link:
http://www.frogtape.com/
Jamie
KitMaker: 6,743 posts
AeroScale: 6,151 posts
Posted: Wednesday, October 01, 2008 - 03:27 PM UTC
Hi Chris ! I still have the same problem as well , what I have been doing of late is after the masking tape is down . I spray it with a clear coat first . If it's forming up along the edge of the tape , you are correct . I never did like spray cans . And yes light coats , might take a few , but you will get better results . I do know that you can get very thin masking tape and comes in different sizes , Tamiya has it and there is a few more . I have some just haven't used it yet so I don't know how they work . Yet !
chris1
Auckland, New Zealand
KitMaker: 949 posts
AeroScale: 493 posts
Posted: Wednesday, October 01, 2008 - 03:11 PM UTC
Guys,
Once again I need to pick your brains.
I been practicing masking and then spraying with a rattle can.
I tend to get bleeding under the tape and also a ridge forms at the tape.
Am I right in assuming that I'm not applying the paint in thin enough coats and that I'm not removing the tape as soon as I've finished,rather than removing after paint has dried?
TIA
Chris
