Do you thin future?
chris1
Auckland, New Zealand
KitMaker: 949 posts
AeroScale: 493 posts
Posted: Friday, September 19, 2008 - 04:41 PM UTC
Hi Guys,
I'm looking to apply future prior to decaling .
As I don't as yet own an airbrush I'll have to do it the old fashioned way,by brush.
Do I need to thin it? and if so what do you use?
Thanking you
Chris
KitMaker: 6,743 posts
AeroScale: 6,151 posts
Posted: Friday, September 19, 2008 - 04:49 PM UTC
Chris you don't need to thin it at all but , you can as well . It's all about choice . You can thin it with Isopropyl Alcohol ( rubbing alcohol ) . You can get this at any drug store , even a dallor store for a buck . You can also use this to thin arylic paint as well . Or just plain water !
Every one has their own perfance on what they use and how .
Hope this helps you !
Posted: Monday, September 22, 2008 - 08:39 AM UTC
Hey how did the baking soda and water tip work out for you ?
drabslab
KitMaker: 2,182 posts
AeroScale: 1,587 posts
Posted: Wednesday, September 24, 2008 - 01:05 AM UTC
I add up to 40% isopropyl alcohol. It permits airbrushing with lower pressure, it gives a thinner coat and I find that overall the result is better.
chris1
KitMaker: 949 posts
Posted: Wednesday, September 24, 2008 - 08:25 AM UTC
Hi Guys and Gal
Thanks for the replies,once again,the folks here rock.
Terri,your idea works really well,I now keep a prepared spray bottle on the bench
Thanks again
Chris
Posted: Thursday, September 25, 2008 - 02:29 AM UTC
No trouble at all Chris , you are welcome .
mazyen
Singapore / 新加坡
KitMaker: 112 posts
Posted: Monday, September 29, 2008 - 04:49 AM UTC
Hi Chris,
You can also wipe "Future" on with a piece of cloth. The type used for cleaning spectacles is excellent. I've been doing that on my car kits for quite sometime, which I then polish it gently with some Tamiya fine polishing compound & then finsh off with their wax.
You may not need to do this with your aircraft though.
ladymodelbuilder
Virginia, United States
KitMaker: 1,218 posts
AeroScale: 424 posts
Posted: Tuesday, September 30, 2008 - 12:37 PM UTC
Hi Chris,
You can also use windshield washer fluid, the basic 99 cent type. The blue tint doesn't have any effect in the color of the paint nor does it alter "Future" in any way.
Asa far as clean- up.... I found that it is easier to run glass cleaner w/ ammonia in your airbrush to get rid of any remaining future before it dries.
Hope this helps....
Posted: Tuesday, September 30, 2008 - 12:48 PM UTC
Hey that's a great tip ! using windshield washer fuild . I will have to try that myself .
