Er der nogen der kan hjælpe??????
Jeg har fulgt denne vejledning:
1.) BBCODE - This is the simplest way to show images in the forum. You can use the buttons provided to insert the tags for your image into your post. Clicking on the IMG button you will see this:
Now all you need do is insert your image location where the text says "put.url.here/image.file". So as an example if you have images on your space at AOL then it would read:
Note that ".file" will be one of the typical image file extensions for most browsers. That being .gif, .jpg, .bmp, .png, etc.
Some of the disadvantages of BBCODE are that you cannot control the size of the image. For that we would use HTML.
Hvorfor f........ kommer der så ikke billeder frem??. Jeg har kopieret adressen i mit "gallery" er det her kæden springer af?
