Hi all!
how do you paint the Cockpit with so much detail, i seen other people do this aswell. and i would love to do it myself. but it never get my instrument panel painted with so much detail. can you tell us how you do it?
Léon, I always use the same methode. First I apply a basic color (Tamiya acrylics, always flat), next I drybrush with Prince August paint (excellent and very fine stuff), then I paint the details and finally I apply a wash (tinted Klir/Future). I'm now comfortable with this technique and it always works ok for me. Next time I will shoot more pictures about the process...
I have a question, what paint do you use for the overall silver?
It depends Butch. I did use Tamiya aluminium in the past but for this project I'm using an old can of Humbrol 56. For a basic aluminium coat, to do some weathering later, a perfect and shiny finish isn't that important. For Bare Metal finishes, I think Nigel Julian (Lampie) is more an expert than me. I've never used Alcad for example...
I've made some progress today. The "Mr Surfacer technique" to fill the wing root seams worked very well... but as I said previously the seams are very limited on this model. For the engine nacelles I didn't even had to use filler since the fit was perfect...
Despite the fact that Hasegawa made the kit with optional parts (to do other variants in the future), I found no real problems with the assembly so far. If you work carefully, you won't loose any surface detail of the kit. Under a coat of aluminium paint, everything is clean and smooth.
This is how the Ki-45 model looks like now. I think I will wait at least 24 hours to let the aluminium paint cure before applying the camouflage...
I also masked the transparent canopy parts with Tamiya tape cut to shape with an X-Acto knife. Of course I've used a new blade...
I will be away tomorrow, so don't expect an update until Sunday... thanks for watching!
Jean-Luc
