General Aircraft
1/144 Scale modeling
Frigate
West Virginia, United States
KitMaker: 500 posts
AeroScale: 243 posts
Posted: Wednesday, March 28, 2012 - 02:26 PM UTC
Folks,
OK then, this thread has been dormant for way too long. Many, including myself, have drifted away. But our beloved 1/144 will rise again ! This scale is just too interesting to let it lay.
For those who may not realize, we have a campaign build running for 1/144, so join in if you can.
I'm in with a Revell AH-64D that I'm converting to the Israeli version - or attempting to anyway. And speaking of that, that is one of my loves of 1/144th scale - conversions !
The great thing is you can experiment with conversions without destroying the budget. So what do you all feel about that ? Things like converting the Revell Sea Stallion (CH-53) perhaps into an HH-53, or MH-53, etc. Plus if you grab some of the older kits, like a DC-3,(C-47), imagine the number you can come up with. A whole lot of modeling there.
At any rate, join in and drop a line, we need to liven up our scale again ! Take care.............Bruce
mbittner
Nebraska, United States
KitMaker: 191 posts
AeroScale: 171 posts
Posted: Wednesday, March 28, 2012 - 11:29 PM UTC
Thanks for that, Bruce. I completely forgot about the Campaign, and I signed up for it! Sad...
Frigate
KitMaker: 500 posts
Posted: Thursday, March 29, 2012 - 02:24 AM UTC
Matt,
No problem,you've probably been busier than a 1 armed bandit lately. I have no doubt Internet Modeler is limiting your modeling time.But you folks are doing a tremendous job, as always.
OK then, my AH-64 "Saraf" is in production. I did manage to fabricate the satellite antenna balls for the stub wings, and just need to fair them in with filler. But I also have a question for anyone out there. Anyone know of any tiny Israeli national marking decals I can use for this scale ? Obviously the Apache takes minute markings to say the least, any ideas would be appreciated.
Take it easy, and keep building, Gang.........
pbhawkin
KitMaker: 179 posts
AeroScale: 170 posts
Posted: Monday, May 07, 2012 - 10:56 AM UTC
you have to be in it to win it guys.
So far we are about to ask Q3, and as the questions can be answered up until competition closing time (1 August) it isn't to late to have a go!
Remember this is for a resin Wellington B.Mk.III CAD drawn and CnC milled (with the new fine tip cutter).
see here:
http://www.kampfgruppe144.com/phpBB3/viewtopic.php?f=6&t=1699
pbhawkin
KitMaker: 179 posts
Posted: Saturday, July 14, 2012 - 03:40 PM UTC
Here is my latest finished (also entered it for the July MoM comp).
This is my conversion from the Algernon BigBird US PBY-5A (amphibian) to a RAAF PBY-5A(M) pure flying boat (ie no undercarriage as a means of saving weight and extending range).
These RAAF planes were very successful at dropping mines in far away Japanese shipping lanes and ports.
Using the 'Owl' resin and PE set (from Ebay) this conversion is set to go!
Firstly the fuselage had to be pulled apart as one of the blister semi-circular walkways was upside-down! Then all green interior parts were glued in (detail painting will be later). The front turret had to be put back in at this stage as it is 'trapped' in a recess to allow it to turn but not come out.
The new exhausts were glues on after sanding to ensure a good fit.
The centre section glued on and the outer wings attached using CA on the tabs and Humbrol putty on the mating edges to fill the slight gap. The excess putty was wiped off before it dried and the gap filling remains are seen in the picture.
Firsty a base coat of Silver (Tamiya) was sprayed. I wanted to know what the original colours were prior to repainting in Black but couldn't. I thought that a layered effect (Silver to represent bare metal then original camouflage) showing through the worn Black paint would look good but then realised during the 1500hour taken to convert these planes they probably removed the old paint anyway as a weight saving measure (that was why they were doing the conversion in the first place)!
Once dry I used cotton buds soaked in water to rub away at the aeas I wanter to fade and chip.
The Black paint both rubbed off a bit and so thinned as well as came off in small pieces. Any hard object like a scalpel, tweezer ot nail easily removed the Black paint. I had to be careful to not overdo it, and in a couple of place had to repaint the Black where too much came off.
A coat of Polltscale flat finish matts everything down and adds a slight faded look as well.
Smoke and white ashe from MIG were added for the exhaust stains.
Radar aerials are from the Owl set and the rear wheel dolly was made up from the PE set too but I forgot to include a picture of it!
I used Lifcolor's Tensocrom Rust 1+2, Fuel and kerosene to add further detailing and weathering.
The antennas are EZline.
The pitot will be replaced with a 23fg hypodermic needle.
Frigate
KitMaker: 500 posts
Posted: Sunday, July 15, 2012 - 02:45 AM UTC
Peter,
Nice job on the "Cat". That is one aircraft you can just keep building and building, there are soooo many schemes for it. The Minicraft kit is also a decent starting point.
We just need some more interest in 1/144th ! Although we did just finish a group build. (Which I started, and still haven't gotten much further....Oh well....)
Posted: Sunday, July 15, 2012 - 07:33 AM UTC
Eyup Peter, it takes a real craftsman to turn a plastic toy into a beautiful model. thanks for posting, that thing is fabulous.
hey, how do you anchor the EZline? Id like to do aerials like that, but the ends always come out aweful...
pbhawkin
KitMaker: 179 posts
Posted: Sunday, July 15, 2012 - 09:45 AM UTC
thanks guys.
A tiny drop of CA and hold the EZline in position (without moving it) for about 5 sec.
The spot on the tail where the lines all meet is just held by a spot for the first line and when dry another spot of CA for the second line.
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Thursday, July 19, 2012 - 02:54 AM UTC
Hi to all!! I am new on this forum and I am glad to be here. This is my 1:144 Revell kit "OOB" hand brushed with MM paints!!
Hope you like it.........
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Thursday, July 19, 2012 - 02:56 AM UTC
And with a new tractors from Dragon......
kenner
KitMaker: 122 posts
AeroScale: 119 posts
Posted: Thursday, July 19, 2012 - 01:07 PM UTC
Wow, excellent paint job!
Frigate
KitMaker: 500 posts
Posted: Thursday, July 19, 2012 - 04:22 PM UTC
Davor,
Considering the fact that is a brush paint job, congratulations ! That is an extremely nice and clean job. You can definitely be proud of that one. We'll be looking forward to seeing you in the next 1/144th group build ! Keep up the great work ! ..................Bruce
tread_geek
KitMaker: 2,844 posts
AeroScale: 144 posts
Posted: Friday, July 20, 2012 - 04:19 AM UTC
Hi everyone!
I haven't posted anything here in quite some time as I usually don't do flying things. An associate had a kit that he felt was beyond his capabilities to build and "contracted" me to build it. However, when I saw the "Small is Beautiful" campaign running I couldn't resist "killing two birds with one stone."
The kit involved was the Dragon #4617 USMC AV-8B.
He wanted the VMA-513 "Flying Nightmares" version and wanted it "loaded for bear." I've only built one other aircraft since returning to the hobby (Revell 1/144 F-14D) but thought this one would be a quick build due to the lower parts count. I couldn't have been more wrong as this kit was (as in the parent version's Squadron name) a nightmare!!! I spent more time sanding, filing and filling than building as parts fit and moulding were atrocious. Build photos and their accompanying commentary can be found in the campaign thread starting on page 8. Anyway, in keeping with the theme of this thread I figured I'd share the end result.
The "customer" asked for the aircraft to be mounted on a "rural" base as opposed to a tarmac or flight deck so I whipped one up for the purpose.
While the new owner was most pleased with the result, I am less than proud of it. The kindest thing that I can say about this kit is that it definitely tested my patience and ingenuity to get it to the point were it is.
Jan
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Saturday, July 21, 2012 - 03:00 AM UTC
One more, 1:144 Dragon J-20, OOB , hand brushed.
And "A close encounter of the stealth kind" :
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Saturday, July 21, 2012 - 04:19 AM UTC
1:144 Revell YF-23A ,"OOB", hand brushed.
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Saturday, July 21, 2012 - 04:21 AM UTC
1:144 "Dragon" What If project --- Su-42 "Raptorski", 5-generation fighter with TVC-nozzles, hand brushed.
And one more What if 1:144 scale aircraft: Revell Su-47 "HRZ-CroatianAF" ,summer 2025. OOB with new decals, hand brushed.
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Saturday, July 21, 2012 - 04:28 AM UTC
Last one from me!!
What if you have those 2 bad kits wich are so not nice:
and you mixed parts from the boxes and glued them without the instructions?!?!?!?
Well after some work I got this :
some more work done:
well now on its way to paint shop.......
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Saturday, July 21, 2012 - 04:29 AM UTC
1:144 Revell "Amon-Cat Tyranus" hand brushed........
su27rules
Croatia Hrvatska
KitMaker: 60 posts
AeroScale: 10 posts
Posted: Saturday, July 21, 2012 - 04:35 AM UTC
1:144 Dragon USNavy carrier..... "Mule"-tow-truck and fire tractor.
Dirkpitt289
KitMaker: 346 posts
AeroScale: 307 posts
Posted: Monday, August 20, 2012 - 02:40 AM UTC
Dude, your work is amazing but what really stands out to me are the bases. Simply fantastic
kymatti
KitMaker: 3 posts
Posted: Monday, August 20, 2012 - 03:41 AM UTC
Hi Guys,
i like to show you a few Airplane i made using the 3D Printing method. All in 1/144
Citation Excel
PC-6
AS 350
Bonanza
DO-28
Bloodhound
Frigate
KitMaker: 500 posts
Posted: Monday, August 20, 2012 - 05:45 AM UTC
Hans,
I'm not familiar with the "3d printing method" - but I am very impressed with the results ! How is this accomplished, if I may ask for a short version ? I really like the looks of the products, and could see quite a few projects getting off the ground with this system ?
Thanks in advance for any information.................Bruce ....
Posted: Monday, August 20, 2012 - 02:41 PM UTC
read about it here - http://www.shapeways.com/
and check out all Matti's stuff over there, http://www.shapeways.com/shops/mattisminis
I wish I had the 3D CAD skills to do that kind of work - maybe in the next lifetime.
kymatti
KitMaker: 3 posts
Posted: Tuesday, August 21, 2012 - 12:37 AM UTC
@ Jonathan :thanks for the explenation
@ Bruce : watch this video, it shows how 3D printing works
http://www.youtube.com/watch?v=8aghzpO_UZE
robot_
KitMaker: 719 posts
AeroScale: 691 posts
Posted: Wednesday, August 22, 2012 - 02:25 AM UTC
Four images from my review of the Platz Shiden-Kai:
