French Voisin
The Kit
1/48 scale "Hi-Tech" kit of the Voisin 10 LAR. French World War I biplane night bomber aircraft.
This is a multi-mediakit, it containing four sprues of limited run injected plastic parts, resin and white metal detail parts for the engine, wheels, prop, plus an etched metal sheet of detail parts.
Decal sheet with French insignia and a "Pierrot" head (escadrille 125) . A illustrated, multi-page instruction sheet (4 photocopies) with photographs of a real Voisin aircraft as a guide for parts location and placement.
About Louis (Louis)
Never seen this particular aiplane bevor. Ist a real work of art, hats off to you! May I ask you how you did the rigging?
JAN 20, 2018 - 01:13 PM
Looks like hell of a kit. You made a fantastic model out of it.
JAN 21, 2018 - 02:11 PM
Thank you.Fishing wire for the wing. The others are plastic stretched. The flat ones are evergreen plastic sheets cut into strips.
JAN 21, 2018 - 07:15 PM
Interesting that I was aware of the recoil-less small canon but not the aircraft itself! Amazing work, truly! May I ask for more information on how you made your T handle fire extinguisher? Almost every one of my 1/35th military US vehicles is missing its' Pyrene fire extinguisher.
JAN 21, 2018 - 09:45 PM
Hi Louis Wonderful work as always! Your builds are always an inspiration. All the best Rowan
JAN 23, 2018 - 01:20 AM
Thank you! T handle fire extinguisher is two pieces of plastic, one stretched, the other flat glued together. The shape of the flat part is made with the scalpel, the ends rounded with the sandpaper (if I remember correctly ). Regards.
JAN 23, 2018 - 11:19 PM
