September MOM Winner: F-104
History
After the Luftwaffe has decided in the late 50s to replace their F-84s and F-86s with the Lockheed F-104G Starfighter the Marineflieger division more or less had no choice but also to adapt the F-104G as their main weapon system. The Marineflieger preferred in the beginning a two-engine plane like the F-4 or the Buccanneer which meant more safety when flying over the North and Baltic Sea. In total 2 Geschwader (wing) each consisting of 2 Staffeln (squadrons) flew the F-104. Marinefliegergeschwader 1 (MFG 1) was stationed in Schleswig and used the F-104 from 1963 to 1981, Marinefliegergeschwader 2 (MFG 2) in Eggebeck from 1965 to 1987.
Main task of MFG 1 and MFG 2 was reconnaissance (each Geschwader had several RF-104 G for that role), anti-ship missions and ground attack. The MFG F-104Gs also defended themselves against enemy fighters with Sidewinder, usually mounted under the belly. In the very early years the F-104s were even planned for making nuclear strikes against targets in Eastern Europe. This never-liked task was abandoned in the late 60s. Only the Luftwaffegeschwader kept this role until phasing out the F-104.
During the Starfighter period the Cold War especially the Baltic Sea in northern Europe was a „hot“ place. Marineflieger F-104s met their the Warsaw Pact counterparts almost daily on their training missions. Contacts with east German, Polish and Russian MiG-21 and MiG-23 were quite common. It was common sense that if the Cold War turned hot northern Germany and Denmark's islands and shores needed to be defended against Warsaw Pact landing operations. It was assumed that the Warsaw Pact armies of the GDR and Poland would have been used to establish an additional front from the north to support a central attack in mid Germany.
MFG (R)F-104 G armament at that time consisted of
  • M61 20 mm Gatling gun
  • Unguided bombs and rockets (Mk 82, 83, french made Matra bombs)
  • Britsh made Huntington Engineering BL-755 cluster bombs
  • Aerospatiale AS-20 and AS-30 guided missiles
  • AIM-9B Sidewinder
  • Optical and infrared cameras (RF-104 G)
  • MBB (Messerschmitt-Bölkow-Blohm) Kormoran ASM. of this highly effective low-flying anti-ship missiles could be carried by the F-104 G from 1977 onwards. This missile had a flying range of about 40 km and was a true fire-and-forget weapon
    Many people still think that the F-104 was a bad plane due to its high crash rate. We now nowadays that this crash rate was not only caused by the plane alone but there have been several additional reasons:
  • The big jump from subsonic to a highly sophisticated Mach 2 combat plane within a few years. Many pilots had to adapt to this plane first
  • High political pressure to get as many 104s ready. Germany bought 916 104s in total which required pilots, mechanics, hangars, spares...
  • Lack of good infrastructure. 104s stood outside even in rain and snow until finally NATO started to build hardened shelters for each plane end of the 60s.
  • Lack of trained pilots and ground crews. In the early 60s it was much more attractive to have a job outside the army in the booming economy at a much better salary
  • Structural issues and bureaucracy
    By analyzing all those reasons and drawing the right conclusions (for example by increasing flight hours, improving safety equipment etc.) Luftwaffe and Marineflieger were able to decrease the loss rate over the decades tremendously. All people who flew with 104 or had the possibility to work with it never were mad at this plane and had only the best memories. I think it can be said that both Luftwaffe and Marineflieger made the best out of the F-104 G. 1 About the model My very first plastic model kit was a Revell F-104 G in 1/144, built in 1991 I think. This may be a reason for a deep fascination for this plane, not only in German but also in Canadian, Belgian, Italian etc. service. I always wanted to build a late Marineflieger 104 being fully armed with Kormoran and Sidewinder. Back in the 80s you could see this configuration quite often on Starfighters displayed at open days. Personally I think the Kormoran fits very well to the sleek F-104.
    The kit and accessories
  • Hasegawa F-104 (I had a Japanese F-104 in my stock). Still the one and only for a 1/48 F-104 (although also the Monogram F-104 is still close to it to my opinion and a nice kit)
  • Master Model pitot tube
  • Eduard Canopy and external masking set
  • Resin Martin Baker GQ-7 seat (the source I cannot remember...)
  • DACO models Starfighter Improvement Kit
    Danny Coremans from Belgium is a 104 nut (and I mean this 100% positive!). He created a very comprehensive kit with weapons, accessories and corrective parts for 104 1/48 kits. Inside you find things which were a few years ago nowhere available (for example recon pods for Dutch F-104s, injected moulded underwing tanks and pylons, all nuclear bombs ever used with F-104 etc.).
    From this kit I used:
  • the Kormoran with special underwing pylons
  • main wings and stabilizer
  • Chaff/Flare dispensers (used only on German MFG2 F-104s in the 80s)
  • AIM-9B Siderwinder and catamaran belly launchers
  • DACO models German Stafighter decals
    Also this sheet is amazing. You can depict every German F-104 possible. What I personally like are lots and lots of unique zappings which very common especially in the 80s made by ground personnel during exercises.
    Construction process
    Construction is straightforward. This is my 6th Hasegawa 104 kit and it went together very well without any big issues. What I persnally like with this kit each time is the great fit of the clear parts.
    Picture 1. Small parts and cockpit tub ready.
    Picture 2. As you may see from this picture the fuselage went together well without any big issues. In this picture you can also see the Eduard canopy maskings which are highly recommendable.
    Picture 3. Nose already sprayed white. I sprayed also the red engine warning line because it is easy to mask. My principle: when you can spray it easily, spray it!
    Picture 4. Dayglo wingtip tank. One of the most significant characteristics of a German 104. I usually start with white, then yellow and finish with shaded orange to depict a worn-out effect.
    Picture 5. Starfighter belly, already sprayed in RAL 9006 Weissaluminium (mixed by eye from Tamiya Gloss, Flat White and Aluminium. I already shaded the panel lines at that stage.
    Picture 6. Ready for painting the upper side in RAL 7012 Basaltgrau.
    Picture 7. Applying Basaltgrau in various brighter and darker shades.
    Pictures 8 and 9. Pheeew! Being lucky, no rip off of paint when removing the masks...
    Picture 10: Masking the tan coloured antenna panel on the fuselage bottom with Eduard mask
    Picture 11: Missiles ready. All in typical inert weapons color of dark olive drab.
    Picture 12: Applying the decals on a gloss coat.
    Pictures 13 to 21 (and more): Geschafft! After applying a coat of Vallejo Matt Varnish and final assembly the F-104 is done.
    Information sources
    http://www.916-starfighter.de/ This great page is hosted by a former Luftaffe Starfighter and F-4 pilot. His aim is to collect and display each Starfighter used by the Bundeswehrr (916 in total) in at least one picture. But not only pictures of Luftwaffe/Marineflieger pictures can be found here.
    For example you can see a picture of the „real“ 26+60: http://www.916-starfighter.de/Large/2660.htm Funny thing: this was the very last Starfighter which flew for the Bundeswehr on May 21st 1991, piloted by LtCol Armin Ewert (3078 fligh hours on 104).
    http://www.dacoproducts.com/ Here you find all the great stuff from DACO.
    http://www.flightschwein.de/ A site hosted by a former Luftwaffe 104 mech. Great background info and pictures.
    Special thanks to all Aeroscale users who voted for this model
    my building buddy Rebilda who hangs around here in the forum somewhere
    and finally: my wife who (still) tolerates my hobby.
    About Sebastian (Middle_Franconian)
    Hello! I have been modelling for almost 20 years now. I am mainly specialized on post-war Luftwaffe of the cold war era (1956-1990) but also other NATO air forces of that period of time. When looking for something different on the work bench I also build military vehicles (WWII and cold war). Ma...
    Nice work,,,congrat,.
    DEC 03, 2016 - 12:48 AM
    Beautiful build Sebastian a well deserved winner
    DEC 03, 2016 - 02:24 AM
    A beautiful piece of work.
    DEC 04, 2016 - 01:08 AM
