148
Dansk Falk
history
The F-16 Fighting Falcon, commonly referred to as the F-16 Viper, is a multirole all weather fighter/bomber. Originally developed as an air superiority day fighter by General Dynamics for the USAF, the F-16 has evolved into a world wide known fighter/bomber. Production of the F-16A was launched in 1976 and entered service with the USAF in 1979. Since then, more than 4,500 F-16s have been built.
The F-16 introduced many new features, such as: a frameless bubble canopy for better visibility, an ejection seat reclined 30 degrees to reduce the effect of g-forces, a side mounted control stick for easier control while maneuvering, and the first fly-by-wire flight control system. The F-16 has a fixed, forward firing M61 Vulcan cannon, and 11 hard points for various missiles, bombs, and pods. Besides the USAF, many NATO countries adopted the F-16 as their multi role jet aircraft.
The big tail of the F-16 is a good place to paint an artwork. The kit provides large tail decals for four NATO countries; Italy, Denmark, The Netherlands, and Norway. I chose to go with the tail art for the Royal Danish Air Force. The Royal Danish Air Force celebrated its 60th anniversary in 2010. The aircraft received artwork consisting of the Danish Flag and a Lion on the tail.
Construction
Note that this Eduard NATO Falcons kit is a re-boxed Kinetic F-16 kit with a lot of Eduard PE and Brassin parts added to the kit. I built this kit out of the box using the plastic parts the kit provides. I was not interested in spending the extra time needed to install the many small PE and Brassin parts—many of which you will not see on the finished model. I did however use the PE seat belts and shoulder harness for the ejection seat.
Also note that the kit instruction guide doesn't provide assembly drawings for some of the assemblies where you use the kit plastic parts instead of the PE or Brassin parts, for example, the ejection seat. In the recent past I built a Kinetic F-16 and saved the instruction guide. So, to build this model I used both instruction guides.
Overall the parts fit for this kit was just fair. There were no huge gaps that required filling, but I did a lot of seam filling and sanding. Kit parts had a lot of flash and there were ejector pin marks all over the parts. I spent a great deal of time cleaning up parts before installing them.
Painting
The kit instruction guide provides color painting guides for four NATO F-16s. Since I chose to have my F-16 in the livery of the Royal Danish Air Force, I pretty much followed the paint scheme for an F-16 of the ESK370 Squadron, Royal Danish Air Force, 2010-2012. Here are the paints I used:
  • ● Landing gears and wheel wells MM Flat White
  • ● Underside of fuselage and wings MM Light Ghost Gray
  • ● Horizontal stabilizers, top and bottom MM Light Ghost Gray
  • ● Wing tip missile rails MM Light Ghost Gray
  • ● Vertical stabilizer (tail) Floquil Signal Red
  • ● Top side of fuselage and wings MM Gunship Gray and Neutral Gray
  • ● Nose cone MM Navy Gloss Gray
  • ● AIM 9 missiles Floquil Signal Red.
Decals
Once the paint dried and cured I hand brush two coats of Future on the model and let in dry for 3 days in preparation for decals. The kit provides decals for four different NATO F-16s. Since my F-16 has the paint scheme of the Royal Danish Air Force, I used the decals provided for that aircraft.
Decalling the model was a real chore. The reason it was such a chore was it was very difficult to move the decals on the model surface. Once decalling was complete I cleaned up the model with a damp cloth, then applied a light coat of Future over the model. To finish off the model, I airbrushed it with a coat of MM Semi Gloss Lacquer Finish.
Conclusion
To sum up, I found this kit challenging to build, mainly because of the time I spent cleaning up parts, and the fussy decals. This is definitely not a week-end build. The parts fit was only fair, but the cockpit and external detail was good. Additionally, the instruction illustrations were excellent. Despite the problems I was satisfied with the look of the finished model. This is not a kit for beginners. I would recommend that only modelers with a good deal of modeling experience tackle the Eduard NATO Falcons Kit.
Burt, Rock solid F-16 build, especially the overall painting and decaling. Nicely done exhaust can with the carbon colored paint in the inside. My only suggestion would be to flat coat the tires as they're all rather glossy. Just finishing a Kinetic kit is a major accomplishment. Joel
OCT 14, 2014 - 03:51 AM
Thanks for the compliment Joel.
OCT 14, 2014 - 01:54 PM
Beautiful build. As a native I love to see this bird made up. I have one myself and can only hope to make a great result like you. Thanks for sharing!
OCT 15, 2014 - 09:28 PM
Very nice F-16 Burt, looking great, i like colofull stuff on modern day gray jets. Will do a dansk F-86D at some time. Bernd
OCT 19, 2014 - 06:52 PM
