General Aircraft
Spitfire Mk. Vb
TedMamere
Moselle, France
KitMaker: 5,653 posts
AeroScale: 4,347 posts
Posted: Monday, September 11, 2006 - 10:21 PM UTC
Andy Brazier (Betheyn) reviews a classic kit of a classic airplane: Tamiya''s 1/48 scale Supermarine Spitfire Mk.Vb.
betheyn
KitMaker: 4,560 posts
AeroScale: 2,225 posts
Posted: Tuesday, September 12, 2006 - 02:22 AM UTC
Thanks Jean-Luc, for the fast turnaround of the review.
Andy
TedMamere
Moselle, France
Posted: Tuesday, September 12, 2006 - 10:35 AM UTC
Hi Andy!
No problem. I must thank you! Actually, I don't have this kit in my Spitfire collection, so it was a nice opportunity to take a look into the box. I only have a Fujimi Mk. Vb/c and think Tamiya's one is the way to go!
Jean-Luc
P.S. I'm working on the "Portfolio" too...
Tarok
KitMaker: 10,889 posts
AeroScale: 174 posts
Posted: Tuesday, September 12, 2006 - 12:28 PM UTC
Thanks for the great review, Andy.
IIRC Sir (?) Douglas Bader flew a Vb? What, apart from the aircraft's numbering would need to be changed to model Bader's aircraft?
Also nice to see the decals are for "Sailor" Malan, the most famous of SA born pilots
Rudi
Antoni
KitMaker: 574 posts
AeroScale: 573 posts
Posted: Wednesday, September 13, 2006 - 03:30 AM UTC
Rudi
Although often depicted as a Mk Vb, DB's Mk V was in fact a Va. (He did not like cannons.) It's possible to build it from the Tamiya Mk I kit but you need to add some parts from the Mk Vb. I cannot remember them all off the top of my head so I will look it up in Model Aircraft Monthly tomorrow.
Update.
You need an oil cooler with a circular intake, Tamyia Vb kit parts D7 and D9. The ailerons were metal not fabric and need to be replaced with those from the Mk Vb. de Havilland prop, circular section exhaust manifold, external bullet-proof windscreen and flat-sided canopy hood all come from the Mk I kit.
Tarok
Posted: Friday, September 15, 2006 - 12:56 AM UTC
Thanks Antoni
Antoni
KitMaker: 574 posts
Posted: Friday, September 15, 2006 - 03:13 AM UTC
Thinking about it, it should be possible to make DB's Va without using a Tamiya Mk V as a donor. You can get Vb control surfaces from Ultracast:
http://www.ultracast.ca/products/48/039/default.htm
Airwaves had a Mk Vb oil cooler. According to the Modellers Datafile the part number is SC48068. Airwaves are only available from Hannants but I cannot find 48068. I did find a Mk Va oil cooler to convert the Tamiya Mk I
http://www.hannants.co.uk/search/?FULL=AES48070
I leave it to you to work out if the aftermarket parts are cheaper than a Mk Vb donor kit.
KitMaker: 7,772 posts
AeroScale: 3,175 posts
Posted: Friday, September 15, 2006 - 04:11 AM UTC
Hi Andy,
Good review! What an enticing model, even to one who has little interest in RAF! (But just wait, I'll build my BAC Lightning, Hunter, Halifax I and Gladiator soon )
I'll buy this bird just for the box art--gorgeous!
Tarok
Posted: Friday, September 15, 2006 - 10:47 AM UTC
Antoni,
Thanks again. I think in my case it would probably be easier to purchase the 2 kits, as both are readily available in LHSs around my neck of the woods. Unfortunately with the current exch. rates (+- 13-14 ZAR to 1 GBP ) it would work out wa-a-a-ay too expensive
Thanks again for your help
Rudi
Antoni
KitMaker: 574 posts
Posted: Friday, September 15, 2006 - 04:06 PM UTC
Suggestion for what to do with the Mk Vb donor kit.
You can use the fabric ailerons and D-shaped oil cooler form the Mk I to make a Mk IIb. The Mk V exhausts are OK, parts D15 and D17, but remove the gun heating intensifier tubes from the rear. Use the external bullet-proof windscreen C2 and flat-sided canopy C1. Then you need to add a coffman starter bulge and find a blunt Rotol spinner with metal blades.
betheyn
Posted: Saturday, September 16, 2006 - 12:24 AM UTC
Cut the front end off and fit a Daimler Benz 605 engine to it :-) . I have just got the resin conversion set for it .
Andy
