Figures
This forum is for discussion of military figure making.
US Insignia & Medals WWII
Teacher
KitMaker: 4,924 posts
Posted: Monday, September 11, 2006 - 05:36 PM UTC
This is a set that modeller''s have been dreaming about! Brilliant! And in colour too!
Simon
KitMaker: 878 posts
Posted: Monday, September 11, 2006 - 06:01 PM UTC
Hi there!
Thanks for the review.
Just commented on the German badges. Looks great. I like the armbands.
I'm gonna need those for sure.
Simon
Gunny
KitMaker: 6,705 posts
AeroScale: 50 posts
Posted: Monday, September 11, 2006 - 06:24 PM UTC
All I can say is Thank's Eduard, and also to you, Mr. Branigan, for bringing us this great news and first look! Both this and the new German set are fantastic!
MonkeyGun
KitMaker: 943 posts
Posted: Monday, September 11, 2006 - 08:55 PM UTC
Thanks Vinnie
Great idea and cheap as chips too :-) :-) :-)
Ian
keenan
KitMaker: 5,271 posts
AeroScale: 74 posts
Posted: Monday, September 11, 2006 - 09:11 PM UTC
My only concern would be getting them to "sit" properly on the figures, ie conform well to the sleeve. Look great and well worth the money.
Thanks for the review Vinnie.
Shaun
Grumpyoldman
Staff Member_ADVISOR
KitMaker: 15,329 posts
AeroScale: 836 posts
Posted: Monday, September 11, 2006 - 10:17 PM UTC
They do look interesting, and I'll probably be picking up a set.
spooky6
Sri Lanka
KitMaker: 2,174 posts
Posted: Monday, September 11, 2006 - 10:28 PM UTC
If they're anything as good as the Lion Roar 1/16 set, they should be thin & flexible enough to be shaped to the sleeve. Glue 'em onto the unpainted fig, so that once the sleeve is painted, it'll look like it's sewn on.
keenan
AeroScale: 74 posts
Posted: Monday, September 11, 2006 - 10:36 PM UTC
Thanks for the info David. Congrats on your literary award, too.
Shaun
spooky6
Sri Lanka
Posted: Monday, September 11, 2006 - 10:52 PM UTC
Thanks, mate
Teacher
Posted: Monday, September 11, 2006 - 11:03 PM UTC
David, unless you're very careful, I'd advise putting these on after painting. They're coloured, and I don't think the Lionroar ones are. They are thin enough to sit properly on any surface you care to put them on, and as mentioned in the review, the colours don't 'crack'.
Vinnie
HARV
#012
Wyoming, United States
KitMaker: 3,035 posts
AeroScale: 79 posts
Posted: Tuesday, September 12, 2006 - 12:36 AM UTC
Thank you Vinnie. These look really cool. I hope that they will produce more later on. I would like to see some 4th Infantry Division patches.
Thanks again, HARV
spooky6
Sri Lanka
Posted: Tuesday, September 12, 2006 - 05:46 PM UTC
I found that the smaller badges don't hold very well when superglued onto a painted surface. Usually (particularly when weathering) pulls off a dot of paint and disappears into the carpet. Also, many dry-fits are necessary in order to bend a sleeve patch to the exact curvature of a shoulder or arm, often you have to press hard to get the right curve, and this might damage the sleeve paint finish. Another way is to use the wet paint as glue and apply the badges directly, but you'll have the same trouble. But my first suggestion is best because when you glue first and paint later, the paint on the uniform builds around the PE patch, making it look like its firmly sewn on. This doesn't matter, of course, with the Iron Cross and other pin-on metal badges. It doesn't matter that the PE is pre-painted because you will have to weather the badges to suit the uniform wear. These are just some of my experiences with the 1/16 PE.
