Modeling Questions?
Q: how to make photo etch more 3-D
southpier
KitMaker: 536 posts
AeroScale: 16 posts
Posted: Tuesday, September 17, 2019 - 11:56 AM UTC
I have a Verlinden, several Royal Models, and who knows what else, frets of photo etch tools. i'd like to give them a little more presence.
Q: would leaving them on the frets and building up a couple of paint layers be "the way" to go in an attempt to make them a bit less two-dimensional?
Kevlar06
KitMaker: 3,411 posts
AeroScale: 798 posts
Posted: Tuesday, September 17, 2019 - 12:33 PM UTC
I like to use thin coats of CA, building up to the thickness and texture I want. Works better and faster with an accelerator, at least for larger items. Very small (as in tiny) PE parts can actually melt because of high temps generated with an accelerator. So I only use it on larger brass PE.
VR, Russ
RobinNilsson
Staff MemberTOS Moderator
KitMaker: 6,170 posts
AeroScale: 19 posts
Posted: Tuesday, September 17, 2019 - 07:30 PM UTC
Some gloss enamels have a tendency to shrink away from open surfaces and hide in the corners, it also shrinks away from edges. Humbrols gloss white or ebony for instance.
Painting a tool handle should cause the paint to huddle along the centerline, gradually rounding off the flat PE to something almost 3D
/ Robin
southpier
KitMaker: 536 posts
AeroScale: 16 posts
Posted: Tuesday, September 17, 2019 - 08:48 PM UTC
thanks. I have some left over frets which I will experiment.
