Armor/AFV
KV-1/KV-1S Hybrid
pgb3476
KitMaker: 966 posts
Posted: Sunday, February 16, 2020 - 11:09 AM UTC
Looking great so far.
MrNeil
KitMaker: 245 posts
Posted: Sunday, February 16, 2020 - 09:47 AM UTC
Paint time
I gave the entire model a coat of Vallejo's grey primer, then hit the undersurfaces, everything below the fenders, along with the crevices and the edges of every panel and hatch with Vallejo Black Green.
I then went to work with AK Interactive's 4BO Russian Green Special Modulation set, starting with the Dark Base, then the Base, Highlight and Shine, keeping the Highlight and Shine only to the top of the turret.
I didn't clean the airbrush between colors with this approach, just added small amounts of the next lighter color to gradually lighten the tone, building up highlights and depth at the same time.
Everything below the mid-point of the turret sides will soon get a coat of whitewash, so there's no point in going all out with modulation on the hull.
MrNeil
KitMaker: 245 posts
Posted: Saturday, February 15, 2020 - 12:29 PM UTC
The final missing detail that I added was the travel limiter or 'bump stop' under the rear-facing turret machine gun, which was presumably there to stop the crew from hitting their own engine deck. While a round would have likely skipped off the armor, it was possible that it might hit the radiator intake mesh and deflect downwards into the radiator itself.
Now...I think ...the model is ready for paint.
MrNeil
KitMaker: 245 posts
Posted: Wednesday, February 12, 2020 - 10:48 AM UTC
Matt, my initial intent was to do just what you suggested...combine parts from multiple kits with some aftermarket parts, and produce an accurate model of the hybrid. However, the more I looked at pictures of the Parfino vehicle...and the more discussions I had over on the KV group on Facebook...the more problems I found with the Trumpeter kits, particularly the turret. So AMS set in, and the scratchbuilding started
Boris, the casting number indicates a December 1942 turret, number 582 in the series, which is consistent with the presence of handrails but the absence of lifting hooks. The handrails reappeared (they were on the prototype but not the early production vehicles) in early December, but the lifting hooks didn't appear until March 1943.
Borris
Rostov, Russia
KitMaker: 2 posts
Posted: Wednesday, February 12, 2020 - 01:17 AM UTC
Glad to help.
KV is one of my favorite tanks.
Another nice photoset with good photos of turret of KV-1S. Note to casting number on the turret.
https://warspot.ru/9725-kv-1s-iz-bolot-volhovskogo-fronta
MrNeil
KitMaker: 245 posts
Posted: Tuesday, February 11, 2020 - 11:55 PM UTC
Thanks for the compliments guys. Glad you're enjoying the build. Many thanks Boris for the pics. I hadn't seen that page before.
Borris
Rostov, Russia
KitMaker: 2 posts
Posted: Tuesday, February 11, 2020 - 10:11 PM UTC
Amazing work!
Here is some photos of real tank: https://warspot.ru/9074-parfinskiy-kentavr
SSGToms
Connecticut, United States
KitMaker: 3,540 posts
Posted: Tuesday, February 11, 2020 - 03:29 PM UTC
Wow Neil when you first began I thought this was going to be gluing together all the correct parts and aftermarket. Now, I'm just blown away by your scratchbuilding skills. Absolutely amazing craftsmanship, my friend!
rfbaer
KitMaker: 1,828 posts
Posted: Monday, February 10, 2020 - 11:56 AM UTC
I'm really enjoying learning the techniques you're using to scratch details.
MrNeil
KitMaker: 245 posts
Posted: Sunday, February 09, 2020 - 11:53 AM UTC
Time for some revisions here...
First of all, I've been referring to the subject of my build as 'Powerful'. However, I recently realized that a closer translation of СИЛЬНЫЙ is 'Strong', so that's how I'm going to refer to the subject vehicle from now on.
Next, I posted a pic on the 'Kliment Voroshilov. KV series of tanks Appreciation Society' group on Facebook, showing the casting number on the turret rear face of my build. Somebody over there posted a pic of the Parfino vehicle, showing the casting number in more detail than I'd previously been able to find, and showing my initial interpretation was incorrect.
The casting number was comprised of two parts. Above the horizontal line was a two-part number indicating the month in which the turret was cast. The Parfino vehicle carries '7-9' which indicates September (the ninth month) of 1943 (I don't know why 1943 is '7'). The lower part of the number is sequential and indicates the number of this turret in the series. The Parfino vehicle carries '360'. We don't know exactly what number 'Strong' carried so I used some modeler's license and used '350'.
As with the first attempt, I made the numbers from short lengths of 10-thou styrene rod, except for the curly '3' for which I used 10-thou phosphor bronze wire.
Another discussion on Facebook turned up some decent photos and drawings of the cupola roof, and showed some details I'd missed. I therefore went back and added rain strips to the roof over each periscope cover, as well as the little domed 'bumps' inboard of the right-hand side of each periscope cover. I'm not certain what these were for, but I'm assuming they provided clearance for the operating mechanisms that allowed the periscope covers to be opened and closed.
I used 10-thou styrene sheet for the ridges/strips, glued to the roof. After the glue had set, I filed and sanded the edges to blend them into the main portion of the roof.
The domed 'bumps' are 5-thou styrene sheet, cut out with my Waldron Punch set. I used the rounded end of a sculpting tool to 'dish' the undersides and create the domes. I then glued the pieces in place and after the glue had set, gently filed the edges to blend them in.
MrNeil
KitMaker: 245 posts
Posted: Tuesday, January 28, 2020 - 01:43 PM UTC
One hatch in the turret top...
Crazy
Dan
Similar to an early Sherman except that the KV-1S was more difficult to get out of, because both the commander and the gunner were on the opposite side of the gun breech from the hatch.
panamadan
Minnesota, United States
KitMaker: 1,399 posts
Posted: Tuesday, January 28, 2020 - 01:00 PM UTC
Crazy
Dan
MrNeil
KitMaker: 245 posts
Posted: Tuesday, January 28, 2020 - 10:37 AM UTC
I should have realized I was jinxing myself by saying the model was ready for paint
After I posted the pic of the loader's hatch hinge above, I realized that the Parfino vehicle has a shorter hinge plate on the hatch side and lacks the reinforcing ribs on the hinge, compared to the kit part.
I therefore removed the reinforcing ribs and trimmed back the hinge on the hatch side. It's still too big compared to the Parfino vehicle but that's because the hinge itself is approximnately 1mm too far away from the hatch rim. That's because I trimmed away the raised lip of the hatch without relocating the hinge itself. If I'd noticed this way back when I was first assembling the turret, I might have reworked it but now there's too much risk of damage to the surrounding detail, so I left it as-is.
JamesL27
KitMaker: 185 posts
Posted: Monday, January 27, 2020 - 01:03 PM UTC
These are the type of builds I love to follow. Great work so far.
MrNeil
KitMaker: 245 posts
Posted: Monday, January 27, 2020 - 12:36 PM UTC
Since I'd made just about every modification and addition to the Trumpeter turret that I could think of, I decided to add the casting mark to the rear face, as shown in the photo of the Parfino vehicle below.
I thought about using the Archer Transfers' casting numbers set but it's designed specifically for US vehicles and the size and shape of the numbers isn't right for this build. I therefore used short lengths of 10-thou styrene rod except for the wiggly '3' which I bent up from 10-thou copper wire. The end result might be a little over-scale but I think it'll look ok under paint.
I also added the spring loaded latch to the base of the loader's hatch hinge. This was basically a knob with a notch in it, which engaged a plate on the top of the hinge to hold the hatch in the open position, as shown below.
I carved a notch into the end of piece of 40-thou styrene rod, then cut it off and glued it to the top of the hinge on the turret roof.
At this point, the model is ready for priming and painting.
MrNeil
KitMaker: 245 posts
Posted: Sunday, January 26, 2020 - 04:24 AM UTC
After adding the weld beads along the edges of the cupola cover, either side of the periscopes from 10-thou styrene rod softened and textured, and the weld bead around the edge of the center roof plate in the same manner, I glued the completed canopy in place on the turret roof, and added the larger weld bead around its base from 20-thou rod, given the same treatment.
The more observant among you will note some other changes too. When I posted pics to the KV group on FB, some people pointed out that the hatches on KV-1S turrets in October 1942 were flat discs without raised rims. Checking the Parfino vehicle proved them right, so I carefully sanded the signal flag hatch cover and loader's hatch cover flat.
I also added weld beads around the hatch hinges and the loader's periscope covers, added the hole in the top of the gunner's periscope cover and the rather odd vertical metal strip up its side. I'm not sure of the purpose of this strip, but it's there on the Parfino vehicle so it's reasonable to assume it was there on 'Powerful' too.
Another detail I noted was the presence of two holes in the upper surfaces of the trunnion cheeks. There are there on the Parfino vehicle and also on a KV-1S at Kirovsk, so I drilled them out.
The other thing the FB folks mentioned was that the transmission access hatches were also flat disks in the fall of 1942, so I sanded them flat too.
MrNeil
KitMaker: 245 posts
Posted: Wednesday, January 22, 2020 - 11:23 AM UTC
A word on the construction of the cupola would be useful here. The outer shape was actually a relatively thin sheet metal cover, welded in place over an armored casting that featured a domed center and apertures for the five periscopes. The vertical armored sections visible either side of the periscopes in the photo above, are part of that casting.
I used putty to fill in the step between the lower two sections of styrene, to create the sloped base of the armored casting.
I added the lower, vertical sections of the cover between the periscopes using thin styrene, and shaped the scalloped cutouts in the lower edges with a half-round file. I then filled in the upper sections with putty and sanded it smooth.
I cut the top section of the unarmored roof from a piece of 20-thou styrene, glued it in place and sanded the edges between the periscopes to conform to the sloped contours underneath.
The domed casting under the cover actually protruded slightly above the underside of the roof, and a circular section was usually cut from the center of the roof to allow the casting to poke through. The replacement roof on the Parfino vehicle doesn't have this cutout, which is why it has a hump in the middle.
The roof around the cutout was either welded to the domed center of the casting, or a flat circular plate was welded in place over the cutout. I decided to go with the flat circular plate option, and cut a circle of styrene to go in the center of the roof.
MrNeil
KitMaker: 245 posts
Posted: Friday, January 17, 2020 - 12:37 PM UTC
I wondered about that roof - Sheet metal seems to be a bit light, overhead cover-wise. Did it have a fixed top or a hatch?
KL
The KV-1S cupola lacked a hatch. There were plans to fit a new cupola with a hatch, but that never made it to production. The commander had to wait until the KV-85 to get a hatch of his own.
KurtLaughlin
KitMaker: 2,319 posts
Posted: Friday, January 17, 2020 - 12:31 PM UTC
KL
MrNeil
KitMaker: 245 posts
Posted: Friday, January 17, 2020 - 10:05 AM UTC
Every time I compared the Trumpeter kit's cupola with the Parfino vehicle, I found new discrepancies, so I decided to replace the entire cupola with a scratchbuilt one.
Here's a photo of the cupola on the Parfino vehicle, which is missing its original roof.
The first step was to cut a circle of 40-thou (1mm) styrene sheet, 20mm in diameter, to form the base. I added another circle of identical thickness, 17.5mm in diameter, on top of this.
On top of that, I added a ten-sided piece of styrene sheet that will act as a former to butt the vision blocks and cupola sides up against.
I then added the vertical plates visible either side of the vision blocks, using 30-thou (0.75mm) styrene. The shape is rather complex and this, combined with the tiny size of the pieces (5mm x 3mm overall) meant I had to go slowly and take a few breaks between pairs.
I'll post another update when I stop gibbering and sucking my thumb
MrNeil
KitMaker: 245 posts
Posted: Sunday, January 12, 2020 - 01:35 PM UTC
A Facebook friend has correctly pointed out that the commander's cupola has some serious issues. The base is the correct size but everything above it is significantly too small. That step around the circumference is simply wrong.
I'm in the process of rebuilding the upper portion of the cupola with styrene and putty. Stay tuned
MrNeil
KitMaker: 245 posts
Posted: Friday, January 10, 2020 - 10:10 AM UTC
Just a couple small details remained to be added before construction was complete.
All KVs had mud scrapers fitted to the lower hull sides immediately in front of the drive sprockets, to help reduce the buildup of mud and dirt between the sprocket rings, which could otherwise cause a thrown track.
I cleaned up the Trumpeter kit parts but didn't do anything much to them, since they're pretty decent and they'll be covered in crud anyway once the model is weathered.
Note that you can't fit them in place until after you fit the sprockets to the hull, or you won't be able to get the sprockets on.
The last items to add were the two machine guns - one on the front hull and the other on the rear of the turret. The Trumpeter parts aren't bad but I decided to use turned brass barrels from a Russian company named Magic Models. The barrels are supplied in two parts each and were a little fiddly to assemble, but look good once they're in place.
MrNeil
KitMaker: 245 posts
Posted: Wednesday, January 08, 2020 - 03:22 PM UTC
Amazing work so far mate. I love how you're really bringing these Trumpeter kits to life with these improvements. I'm mostly an OOB builder, but it's great to see folks point how ways to improve existing kits. I'm planning to build one of the Trumpeter KVs in my stash so I'm really learning a lot through your blog. Keep em coming!
Nigel, Marc, and others...glad you're finding this build log useful.
The Trumpeter kits are, for the most part, very nice though like all kits, they provide room for improvement. This build was an unusual one since the prototype was a very uncommon vehicle and even the original Soviet builders in 1942 needed to do some oddball things, which require special modifications to the kits.
MrNeil
KitMaker: 245 posts
Posted: Wednesday, January 08, 2020 - 11:39 AM UTC
The front towing shackles were similar to the rear ones, but a little more involved since they have the tow cables attached.
I've never had much joy with Trumpeter's tow cables, so I used Eureka XXL's ER-3509 set for this build. The Eureka cables provide a heavier gauge copper wire compared to the Trumpeter parts, and the resin ends are larger too. They fit nicely over the Aber shackles.
The rear ends of the stowed tow cables on KVs are secured with turnbuckles. The Trumpeter parts are molded integrally with their mounting brackets. Since I had already cut away the brackets, drilled them out and fitted them separately to the hull sides, I needed to modify the turnbuckles. I replaced the two ends with 15-thou phosphor bronze wire, bent to shape using the kit parts as a guide, retaining the central section of each turnbuckle.
marcb
Overijssel, Netherlands
KitMaker: 1,151 posts
Posted: Tuesday, January 07, 2020 - 12:42 PM UTC
That looks really good.
