Campaigns: Active Campaigns
Hosted by John Pereira
Bury My Heart at Stalingrad
canismalus
#465
KitMaker: 308 posts
Posted: Saturday, February 09, 2019 - 05:50 AM UTC
Hey everybody,
Those are some very cool projects you guys have started on. I probably won't be able to get to this for a few weeks, but here are the start photos for my 24th P.D. Panzer III J anyway:
Have fun,
Jerry
KitMaker: 4,135 posts
AeroScale: 1,786 posts
Posted: Saturday, February 09, 2019 - 12:57 PM UTC
Jerry,
Great to have you along. Will be looking forward to your Pz IIIJ build. Seems you have some nice goodies to go with, as well.
Gaz
pathfinder14
KitMaker: 25 posts
Posted: Saturday, February 09, 2019 - 03:02 PM UTC
The Mark IIIH is just about done gluing. This is my first time doing individual tracks and boy is it a pain, but so far I'm liking the results.
Early stages of my base for the Mark III diorama. Very basic celluclay, static grass, cat litter for littles rocks. For the pig pen I'm using a mud product from MIG, first time using this too, I like it, but I'm likely going to add some more layers either through washes or highlighting to get the effect I desire.
Onto my T34 diorama..
Here's the base. I like how it's come out so far. For the rubble I've used crushed brick and Pegasus bricks and other miscellaneous items. The Pegasus bricks and real life bricks don't match in color, not sure if I like this or if I'll try and touch it up some, maybe a couple more washes will help blend them.
Another picture of the T-34 diorama.
Anyone of these two dioramas by themselves would have provided a decent challenge because of the new techniques and ideas I'm trying, the fact that I'm doing the two of them at once just increases that challenge.
brekinapez
Georgia, United States
KitMaker: 1,787 posts
AeroScale: 91 posts
Posted: Saturday, February 09, 2019 - 03:28 PM UTC
I am trying to decide between:
DRAGON 6262 7.5cm Pak 40/2 auf Fgst Pzkpfw II (Sf) Marder II
https://www.scalemates.com/kits/dragon-6262-panzerjaeger-ii-fuer-pak40-2-marder-ii--106727
or
DRAGON 6363 Pzkpfw IV Ausf G LAH, Kharkov 43
https://www.scalemates.com/kits/dragon-6363-pzkpfw-iv-ausf-g--108508
I really like Pz IV's and only have a D and and an F on my shelf at present but I have built nine of the non-tank variants, while at the same time I have two only Marders--both III's.
petbat
KitMaker: 2,074 posts
AeroScale: 21 posts
Posted: Saturday, February 09, 2019 - 10:10 PM UTC
HI Pathfinder. The model and Dio are looking good.
A tip on the indy link construction , you might find it easier to do the bottom part first. That is flat and you can sit the vehicle on them, then curl up the ends around the sprocket stopping about the 11 o'clock position, making fit around the teeth easier and giving you a solid position to later glue the top run to. Use a good strong tape on the whole track face to stop them coming apart, then curl the track run over the sprocket and idler and secure the tape to the return rollers to keep the tension around the curls and let the glue set up.
The new top run can later be done the same way and glued to the lower run link at the sprocket end first and the end links will fit in the sprocket teeth from just before 11 o'clock to 1 o'clock, holding them tightly in place while you work the other end and do the slack between return rollers/ and idler. Having tape along the whole top run and using that to secure the ends around the sprocket and idler will hold the joins firmly onto the lower run. The tape will hold the links when you press down between the return rollers to make the slack, so you wont pull links apart.
Hope this makes your life easier next time
Posted: Saturday, February 09, 2019 - 10:22 PM UTC
Hi Pathfinder,
Both of your dioramas are looking very interesting, and I like how they're coming together.
I;ve only done indy links a couple times myself, but I think you're doing very well. Anything beats rubber band tracks.
Keep up the motivating work!
Gaz
Posted: Saturday, February 09, 2019 - 10:34 PM UTC
Shell,
Both kits should be great to build. I built the Tamiya Marder II when I was kid. It was pretty simple making me wonder what the Dragon kit would be like. And having recently completed a Brummbar, I need to recuperate before my next PzIV suspension...lol
Gaz
Posted: Saturday, February 09, 2019 - 10:35 PM UTC
Gee, Pete! Where were you when I was ruining my first set of indy links??
Gaz
Posted: Saturday, February 09, 2019 - 10:42 PM UTC
Hi everyone,
Been working like a dog on my Masterclub resin t-34 tracks. They were fiddly, irritating, and nowhere near as enjoyable as Friuls...but they did only cost 10 dollars. And due to breakages, miss-drilling, I barely had enough. But here is evidence of progress:
At this stage, the wheels and idler arms are only held in place by blutack... but the dreaded tracks are at least complete.
And here the tracks have been primed and the idler arms glued and drying. All wheels and sprockets only held on by friction.
Gaz
d6mst0
#453
KitMaker: 1,295 posts
AeroScale: 5 posts
Posted: Sunday, February 10, 2019 - 02:15 AM UTC
Gaz,
I try Masterclub resin tracks on my KV-8 kit and they were just awful to put together. Those resin pins would not fit and kept bending. Now Masterclub metal tracks are wonderful. I just put a set together on my Tamiya Elephant kit and those resin pins went in without a problem and I have not needed to use any glue to keep them in place. They fit perfectly around the drive sprocket.
I ended up using metal wire to hold those resin tracks together. Never will buy another set of resin tracks from Masterclub.
Mark
Posted: Sunday, February 10, 2019 - 08:42 AM UTC
Mark,
Did you have to drill the pin holes?
Gaz
d6mst0
#453
AeroScale: 5 posts
Posted: Monday, February 11, 2019 - 12:56 AM UTC
Mark,
Gaz
No, I didn't have too they went right in. The fit was just right, the pins stayed in place no matter how many times I flexed the tracks.
Mark
Posted: Monday, February 11, 2019 - 05:55 PM UTC
Thanks for the fill-in, Mark! That opens up another alternative to Friuls.
Gaz
d6mst0
#453
AeroScale: 5 posts
Posted: Tuesday, February 12, 2019 - 12:44 AM UTC
Gaz
Gaz,
Have you looked at Kaizen tracks? They are a resin track and they use wire to pin the tacks together. Very nice tracks, no clean up, the wire fits nicely with a spot of thin CA to hold. They move and will sag just like metal tracks when assembled and cost a third or half of Friul tracks.
They have a limited selection mainly Sherman, Tigers, Panzer III and IV and some T-34. They are my go to after market tracks when I am building these models.
Mark
Posted: Tuesday, February 12, 2019 - 07:07 PM UTC
Gaz
Gaz,
Mark
I've only just heard of Kaizen tracks recently. I'll think of them next time I need to order some tracks and see if I can find what I need from a close shipping source.
Gaz
k_mero4
Sofiya, Bulgaria
KitMaker: 274 posts
AeroScale: 19 posts
Posted: Thursday, February 14, 2019 - 08:47 AM UTC
Hello everyone!
III build a Junkers Ju-87 D-1 or D-3 of II./StG.2 "Immelmann".
The basis of my project is Italeri 2709 Ju-87 D-5, which with some upgrades should become the early version.
Here are the starting photos.
Good luck to everyone in the campaign!
Kalin
Posted: Thursday, February 14, 2019 - 06:08 PM UTC
HI Kalin!
Welcome to the campaign! Great to see a Stuka in the works!
Gaz
d6mst0
#453
AeroScale: 5 posts
Posted: Friday, February 15, 2019 - 06:52 AM UTC
Kalin,
Welcome to the campaign, really liking your choice.
Mark
petbat
AeroScale: 21 posts
Posted: Friday, February 15, 2019 - 07:42 AM UTC
Some 'upgrades' Kalin? Weren't the wings around 60cm longer on the Ju87 D-5 than previous versions. If that is what you call an upgrade, I'd hate to see what you call a major modification!!
Welcome aboard. It will be interesting to see you build a 'wingy thingy' for a change
Posted: Friday, February 15, 2019 - 09:52 PM UTC
HI everyone,
A small update as I try to get a snow effect in the waffle tracks:
Posted: Saturday, February 16, 2019 - 05:53 PM UTC
Hi everyone,
I fought with the snow for quite a bit but finally plowed through to my current state. Everything is dryfitted to help me figure out my next step after weathering the underside of the beast.
Gaz
d6mst0
#453
AeroScale: 5 posts
Posted: Sunday, February 17, 2019 - 02:38 AM UTC
Gaz,
Nice effect, not over done.
Mark
Posted: Sunday, February 17, 2019 - 07:47 PM UTC
Thank you, Mark!
petbat
AeroScale: 21 posts
Posted: Sunday, February 17, 2019 - 09:55 PM UTC
Looking good Gaz.
How about this for a dio idea - not a t34 but....
https://media.giphy.com/media/15L4GgZxncHh6/giphy.gif
Posted: Monday, February 18, 2019 - 09:43 AM UTC
Looking good Gaz.
Wow, Peter that is amazing! That says alot about the Christie suspension.
Show-off Russians!
Gaz
