OFFICAL: RAF 100 Campaign
Removed by original poster on 08/13/18 - 03:34:25 (GMT).
bomber14
KitMaker: 240 posts
AeroScale: 222 posts
Posted: Sunday, August 12, 2018 - 03:37 PM UTC
some nice builds here. tim nice spit and i am relieved to see your sky matches the sky i'm using.
since these photos i have pre shaded and sprayed the sky
GEDC3421" BORDER="0">
bomber14
KitMaker: 240 posts
Posted: Sunday, August 12, 2018 - 03:54 PM UTC
does anyone know witch prop would be right to use for a battle of britain hurricane? airfix supplies two props in their 1/48 kit but don't say which is which. thanks, joe
GEDC3423" BORDER="0">
KitMaker: 1,599 posts
AeroScale: 1,448 posts
Posted: Sunday, August 12, 2018 - 04:49 PM UTC
I believe it's the one to the right Joe, the one to the left looks like a rotol unit.
KitMaker: 3,244 posts
AeroScale: 2,329 posts
Posted: Sunday, August 12, 2018 - 11:59 PM UTC
Actually both types were used at the time of the Battle of Britain, with the Rotol unit probably predominating. Use the smaller, more pointed spinner with the sharper De Havilland prop and the larger, more bulbous spinner with the larger Rotol one.
As for which aircraft had which prop, you're sort of up in the air on that (so to speak). I don't think something like serial number will tell you. You either need to research the specific airframe or take a guess. As I say, I believe the Rotol prop was more widely used at the time.
bomber14
KitMaker: 240 posts
Posted: Monday, August 13, 2018 - 12:47 AM UTC
thanks chris/michael. i too had seen photos of both used but it's hard to tell some times if it is during the BOB time frame.
michael i was actually thinking the pointy spinner was matched to the rotol. i think the techmond sheet i am using shows the specific plane with the stubby spinner.
thanks again joe
TimReynaga
KitMaker: 1,823 posts
AeroScale: 177 posts
Posted: Monday, August 13, 2018 - 07:32 AM UTC
I hope we aren't both wrong!
Torpon
Spain / España
KitMaker: 57 posts
AeroScale: 56 posts
Posted: Tuesday, August 14, 2018 - 08:02 PM UTC
Tim, Joe, great looking Spitfires!
My Harrier has decals on and it is superglossy at the moment. Unfortunately I am now on holidays and it will have to stay like that for a couple of weeks.
Carlos.
WombatWal
#496
KitMaker: 10 posts
Posted: Wednesday, August 15, 2018 - 03:56 PM UTC
Something a bit lower and slower, from me, than most of the other marvellous aircraft being built. That Heyford is a wonderful looking aircraft and those Matchbox colours are a horror.
Kit Eduard Lysander Mk. III
Start Date 16 August
WIggus
KitMaker: 63 posts
AeroScale: 59 posts
Posted: Thursday, August 16, 2018 - 12:23 AM UTC
Ooooooohhh, Lysander!
I'm watching this one.
I finally got some flat coat to finish my Eduard Spitfire.
And in subsequent handling I broke the rudder right off.
I'll have to drill it out for some new pins. Grrrrrrrr.....
TimReynaga
Posted: Thursday, August 16, 2018 - 11:29 AM UTC
The wing decals went on without any problems, but the fuselage markings presented more of a challenge with the roundels and codes being a single decal with a large clear section connecting them.
I applied the alternate markings in the kit on a test hulk, and as I had feared, the clear areas remained visible even after careful application of decal setting solution. They might still have worked fine under a final clear coat, but just to be safe I cut out the roundels and codes and applied them individually.
The smaller separate markings not only eliminated potential silvering, but they also made it easier to thoroughly soak the decals with setting solution and get them to conform to the rather deep panel lines on the model.
In the end, the kit decals performed beautifully!
nico37
Indre-et-Loire, France
KitMaker: 635 posts
AeroScale: 165 posts
Posted: Sunday, August 19, 2018 - 10:47 PM UTC
really nice kits here, RAF used and uses so many pretty planes !!!
here is my progress on the Gladiator, riggings begining (thanks Airfix for the detailled plan !), engine and alu painting tries (I'm going to use the shinny "Mr Metal Color" alumine for the metalic parts and the umbrol 56 mat alumine for the canvas ones.
For the riggings i used thicker fishing wire than usual because the Gladiator's are thick and because .... i see them a lot more !!!!
nico
WIggus
KitMaker: 63 posts
AeroScale: 59 posts
Posted: Monday, August 20, 2018 - 12:03 AM UTC
Wow! That is SOME rigging.
Looking forward to the results.
nico37
KitMaker: 635 posts
Posted: Monday, August 20, 2018 - 12:42 AM UTC
Thanks a lot Wiggus, i'll do my best but it may be a bit long as i'll glue the 28 wires 2 at a time and then waiting untill there are dry, drawn tight them them and then move for the 2 others, i hope that'll be done in less than 2 weeks ....
nico
bomber14
KitMaker: 240 posts
Posted: Monday, August 20, 2018 - 12:53 AM UTC
really nice work tim. so we both have the same shade of sky underneath, let's see if i can do as good a job on the top side of my hurricane. i'm using the vallejo BOB paint kit and for the first time pre cut camo masks by alm.i sprayed the dark earth and already i made a mistake, i forgot to completely mask off the underside of the cowl.
joe
TimReynaga
Posted: Wednesday, August 22, 2018 - 12:48 PM UTC
Thanks Joe - I'm curious to see how things go with the Vallejo colors on your Hurricane.
On my own little Spitfire, after decaling I shot the parts with a “flat Future” overcoat – a 3:1 mix of Future acrylic and Tamiya Flat Base – to give the aircraft a matte but not quite dead-flat finish. I then attached the mast, propeller, exhausts, pitot, and undercarriage.
The only additional details were the IFF wires between the stabilizers and fuselage sides.
Also, I chose not to use the clear ventral signaling lamp part provided in the kit. Rather, I filled the recess with Glue ‘n’ Glaze, a sort of clear PVA glue for model windows, which I tinted with Tamiya Clear Orange (X-26).
nico37
KitMaker: 635 posts
Posted: Wednesday, August 22, 2018 - 06:19 PM UTC
Tim Reynaga: wowww, what a good paint job ! Great job !
TimReynaga
Posted: Friday, August 24, 2018 - 12:17 AM UTC
Thanks Nicolas! Here are some additional pics of the finished model:
bomber14
KitMaker: 240 posts
Posted: Friday, August 24, 2018 - 07:27 AM UTC
nice job tim. looks fresh out of the factory,no dirt in the panel lines. i'm going for a more weathered look so i pre shaded the panel lines and a variation of joel willstein's technique. got the dark earth and green done. just need to touch up a few spots where the masks pulled up the brown and i will post some pix.
joe
PasiAhopelto
Uusimaa, Finland
KitMaker: 254 posts
AeroScale: 140 posts
Posted: Sunday, August 26, 2018 - 04:16 AM UTC
Nice clean Spitfire, Tim. I like it.
Meanwhile, started to paint Lightning:
I'm quite impressed by Vallejo's Metal Color paints. They are officially for airbushes, but work fine unthinned with brush.
TimReynaga
Posted: Sunday, August 26, 2018 - 03:53 PM UTC
Thanks Joe and Pasi. The Spit is indeed pretty clean, even though it probably should have some weathering - but I figure those panel lines on the new Airfix kits are heavy enough as they are!
By the way, I haven't been able to post pics of the finished model in the campaign gallery - is all well?
Posted: Monday, August 27, 2018 - 12:41 AM UTC
It is indeed a very nice Spit, Tim. And a perfect first finished entry in the campaign.
I just test posted a photo to the gallery and it worked fine. Are you logged into the gallery when you try? Are your photos too big?
TimReynaga
Posted: Tuesday, August 28, 2018 - 01:20 AM UTC
Thanks, Michael. I tried it again with reduced-sized pictures, and you were right - the pics were just too big!
Guess I'm an early finisher, but I'll still be following the rest of the RAF builds with interest. Thanks for this great campaign!
bomber14
KitMaker: 240 posts
Posted: Wednesday, August 29, 2018 - 04:06 PM UTC
nice work tim. hopefully i will be joining you soon. the hurricane is painted with vallejo air battle of brittian set using pre cut vinyl masks. not that impressed with the paint, it pulled up in spots when i removed the masks which resulted in a lot of touchup. i went light on the weathering and chipping since i figure these craft were fairly new being so early in the war.
GEDC3425" BORDER="0">
GEDC3424" BORDER="0">
it is now gloss coated and ready for decals. more photos soon-
joe
TimReynaga
Posted: Wednesday, August 29, 2018 - 04:48 PM UTC
...not that impressed with the paint, it pulled up in spots when i removed the masks which resulted in a lot of touchup... joe
Joe, I know what you mean! Been trying to make the switch to acrylics, but I've had the same experience with lifting... Still, they are so much easier than those toxic, smelly enamels I just can't seem to stop using.
You are certainly making them work on that Hurricane, though!
