Cold War (1950-1974)
Hosted by Tim Hatton
Best Starfighter Ever?
SteveAndrews
KitMaker: 635 posts
AeroScale: 495 posts
Posted: Saturday, January 18, 2020 - 10:08 PM UTC
Iím slowly working my way around all the doors and flaps. The same techniques described earlier got me here with the small main landing gear doors.
The last parts on my list are the speed brakes. They presented a dilemma. The kit parts are basic and the moulding is the usual inexplicable mix of fine detail and vague blobs of plastic. On the other hand the Eduard replacement offerings require some very delicate work and precision bending of multiple parts. Frankly, the potential to mess these up and my doubts about the final strength of the mounting points made me think twice. In the end I decided on a hybrid approach. Iíll use the kit parts and enhance them with a bit of kit bashing using adapted Eduard parts. Iím a bit nervous about this as the Eduard replacements are not designed to work with kit parts - they are complete replacements. Letís see how it goes.
Happy modelling guys.
SteveAndrews
KitMaker: 635 posts
Posted: Saturday, January 18, 2020 - 10:06 PM UTC
Good morning Joel and Gaz (well, morning here),
It's really interesting how two very different techniques get such impressive results. Joel, your cars look smoother than a samba at sunset, and Gaz yours has a lovely authentic look. Thanks both for adding to the discussion and sharing your techniques. One day (he said) I'll tackle the Valentino Rossi race bike I have in my stash, then I'll really need those glossy finishes.
In the meantime, it's back to work on the detailing.
Thanks again for dropping in. It's always a pleasure.
Have a great day,
Steve.
KitMaker: 10,579 posts
AeroScale: 7,365 posts
Posted: Wednesday, January 08, 2020 - 02:25 AM UTC
Steve,
Happy Holidays my friend. While I don't post very often these days on your incredible build, I do follow it through everyone of your updates.
Being a full time race car/classic road car modeler for the past several years, gloss finishes both for final appearance and for the decaling stage is super critical. Many of my techniques I've learned, adopted, or just plain stolen from Paul Budzik, so you can be sure that they do indeed work.
a smooth painted surface for decaling starts with the raw plastic, so prep work is super important. It's like the foundation of a house. All the various stages of the paint process are air brushed in lite, even coats.
Primer which is Mr. Color 1,500 Grey or Black is 1st, thinned 50:50 with their self leveling thinner which is just a retarder that is added. Like you, my flow rate is between 14-20 psi. I never stop a pass nor even slow down. Just add coats 3 min apart till I've got what I like. I let this dry and cure for 24 hrs. Then a lite polishing with 3,000 grit. It's now smooth as silk, which is the goal.
Up next is my color coats. I generally use pre-thinned paints by Gravity or Zero, but I've used Mr. Color or even Tamiya that I've thinned 2 parts paint to 3 parts thinner, which is applied exactly as the primer was. Any Orange Peel or imperfections is rubbed out with 6,000, 8,000, & 12,000 Micro papers or pads. Again, smooth as silk.
Now I decal right over the paint without any clear gloss coat as none is needed. Since you've knocked down any peaks, buffed out the valleys, there is no silvering nor flash.
Clearcoat for blending in the decal to the paint as usual.
As for Gloss colors, for smaller areas just thin lite coats same as always. Gloss paints take longer to setup, so go 5 min between coats.
Here's just two examples of that technique.
KitMaker: 4,292 posts
AeroScale: 1,825 posts
Posted: Tuesday, January 07, 2020 - 06:12 PM UTC
HI Steve,
I'm just at the beginning of a couple of kits, a 1/32 Hasegawa 109 and a Trumpeter Sturer Emil. I haven't done much more than slap plastic on either.
But to get back to the topic of paint smoothing, I'd like to show some pics of a recent 1/48 ICM build where it took polishing the paint to keep the desired camoflage from being lost in a sea of overspray:
ICM Dornier Do 217 N2/r22
While the larger markings were done with masks, the stencils and stuff were decals which I didn't clear coat before applying.
Gaz
Gaz
SteveAndrews
KitMaker: 635 posts
Posted: Monday, January 06, 2020 - 07:29 AM UTC
Hi Gaz,
Thanks as always for the encouragement.
I guess smoothly applied paint without any loss of detail is the Holy Grail of airbrushing. Personally, I find it very hard to get a smooth finish with matt paint. The properties that make it matt - a microscopic lumpiness to the surface, apparently - work against it.
I guess you are working on something super shiny like a vehicle body? In fact I think I remember you writing that at some point. Your approach pays off I'm sure.
For what its worth I've found that Tamiya acrylics diluted with Mr Colour Levelling Thinners are quite forgiving and dry with a smooth surface. I spray at a low air pressure - around 15-20 p.s.i - and work close to the subject. I also try and make neat passes, building up thin layers in the classic way. Having said that, I did a test once and just blasted my mix at an old kit; the results were surprisingly good even after a thick layer of paint.
My preferred combination gets me a good result most times, even if it takes a while to cover large areas. Of course, I can and do matt coat at the end if the kit needs it but usually I go for a satin finish and let weathering tone down the shine.
Anyone else got some good techniques for a smooth finish?
By the way, what are you working on?
Have a great day,
Steve.
Posted: Sunday, January 05, 2020 - 10:44 AM UTC
Hi Steve, happy new year! Iím glad to see your excellent work progress.
I find your reticence to apply clear coats interesting. More so as I have been working on the problem of paint smoothness for other reasons. I have been using either micro mesh sanding cloth between 4000 and 12000 grit wetsanding for smoother finishes. If I want finer abrasive I use liquid buffing compounds and microfibre cloth, especially if there is raised details nearby as there is less chance of damaging the paint on them. One thing to mention is that these buffing compounds often have petroleum distillates in them, so they canít be used with enamels.
Keep up the great work!
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, January 05, 2020 - 08:19 AM UTC
Happy 2020 Gaz, and everyone following along or just dropping in from time to time. I hope you had a great holiday and that the return to work and/or normal life is a good one.
At some earlier stage I made a glib comment about getting paint on by Christmas. This was sort of tongue in cheek - like all those politicians and generals who promise the latest war will be over by Christmas. I also hoped that it might be true (possibly like all those politicians and generals too). Well, I got some paint on some parts. OK, itís not the biggest parts, but it is paint on parts (case for the defence rests).
At this point I have a confession. I absolutely hate putting down gloss coats. Instead, I tend to add a good deal of Tamiya Clear or satin varnish to my paint so I end up with a finish that is good for washes and decals. Sometimes I forget and end up clear coating anyway, but my preferred option is shiny paint. I might be delusional but I feel like that gives me more control over the surface texture and the thickness of the coverage. Anyhow, each person has their own approach, and this is mine. I make absolutely no claims that it is better than any other approach. It just sits well with my preferences.
Here we have the canopy and avionics bay lids airbrushed in Tamiya acrylics which are thinned about 50% with levelling thinner.
Posted: Tuesday, December 24, 2019 - 08:57 AM UTC
Nice work, Steve! Merry Christmas!
SteveAndrews
KitMaker: 635 posts
Posted: Tuesday, December 24, 2019 - 06:46 AM UTC
It was the night before Christmas and all through the house nothing was stirring not even a mouse. Actually, thatís not true. In my house at least a pot of Tamiya Extra Thin has been stirred and used to stick various bits of tiny plastic into the canopy of the F-104. I decided on this scratch building route rather than using the option of photo etch because it gives a more three dimensional look.
Earlier I decide to experiment with making the seeker heads for the Sidewinders. After some thought - and the realisation that I hadnít ordered any products to help me - I opted to sand down clear sprue. I also had to fettle the holes drilled in the missile body to get the right diameter.
Here we go with visuals:
I hope you have a very merry Christmas if you are celebrating, and if youíre not then simply enjoy your modelling. Maybe youíll enjoy these guys too.
https://www.youtube.com/watch?v=fCya1_jvPgo&list=PLnUYR9dekiKeAj0OMDHUh_RQwx6jWDiHZ&index=12
See you in 2020.
Steve.
SteveAndrews
KitMaker: 635 posts
Posted: Tuesday, December 24, 2019 - 06:44 AM UTC
Hi Nick and Damien,
First of all, I'm sorry it has taken me a while to reply. Work and family life has kept me away from doing anything but lurking for a wile. I must admit, I'm a mood modeller. If I'm in the mood I do, and if I'm not I don't.
Nick, I feel your pain. I hope everything looks good in the cold light of another day and with a beer to help dull the pain.
Damien, it's a pleasure to be here, and I like your description of the F-104.
Thanks for looking in guys, and now a tiny Christmas present...
KitMaker: 6,919 posts
AeroScale: 3,557 posts
Posted: Sunday, December 08, 2019 - 12:13 AM UTC
Maybe there's room for a section here on fixes and crisis management
Not enough bandwidth to cope with the torrent of posts on that subject matter Steve!
I'm still sticking my head in to have a look here from time to time, loving the work you've been doing and the effort you put in to display it all here is very much appreciated.
Nick, I thought you would be enjoying this build, it's a louder, pointier version of the work you have been doing over on Automodeler.
Stickframe
#362
KitMaker: 1,476 posts
Posted: Saturday, December 07, 2019 - 03:32 PM UTC
Hi Steve,
I enjoy dropping in from time to time to see your progress - really something else to see - really nice work. This time tho - Iím glad that you report your periodic disasters - not to mean Iím glad they happen, but because it reminds us that weíre not alone with them!
Just before reading this I spent the afternoon working with white metal, metal rods, and turned metal parts and springs on the rear end of a 1/24 Porsche 908/3 race car....the parts were not agreeing to go together, at all - when, the white metal lower control arm snapped. Perfect. A clean snap at the chassis....automatically, broken suspension.... So, I tore that side of the suspension apart, made a clean cut at the break, drilled out both of what were one piece, and inserted a small metal rod and rebuilt it....and now, Iím going for a beer - need to de-stress from a day at the hobby!
Thanks for posting - I really enjoy seeing your work
Nick
SteveAndrews
KitMaker: 635 posts
Posted: Monday, December 02, 2019 - 12:23 AM UTC
Hey Gaz,
Thanks for the encouragement, and I'm sorry to read about your Dornier. You are a sensible man for buying extras!
Maybe there's room for a section here on fixes and crisis management :-)
Bye for now,
Steve.
Posted: Sunday, December 01, 2019 - 10:27 AM UTC
Keep up the good work, Steve. Your efforts are paying off. We all have crisis points. Just this weekend, on the verge of completing my ICM Dornier Do 217 night fighter an act of clumsiness cost me all four of my new Gaspatch FuG 212 radar aerials. They couldnít be salvaged. Fortunately I bought 3 sets.
Gaz
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, December 01, 2019 - 09:31 AM UTC
I spend a lot of my time with magnifying glasses on. They are - of course - great for detail work but lousy for peripheral vision. I blame them entirely for a clumsy swipe that sent the F-104 sliding across my desk, which in turn broke the front landing gear. Damn, damn and more damn. It seems like I have a crisis in every build. Last time I managed to split the windshield on a Mirage and spill glue all over the wing.
After a few moments of disbelief and then frustration I took a look at the damage. Luckily the part broke neatly and I can repair it. Iíll remove the piston between the upper and lower strut, drill out both parts and put a new piston in from plastic rod. Hopefully that will make a strong new link.
Al that happened just as I was feeling good about finalising the cockpit details and getting the windshield (carefully) glued in place. A little brush painting and weathering got the area ready. It was hard to figure out where the interior grey stops but in the end references helped and thereís a lip that makes the perfect line of demarcation.
Here is the progress and first stage repair (damn, damn and damn):
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, November 17, 2019 - 06:59 AM UTC
Cold, wet Sundays: I love Ďem. Mr Blue Sky isnít around to tempt me out, so the very best thing to do is get some serious work done on the F-104. Today that meant detailing up the cockpit edges and adding a few simple scratch built details inside the front of the canopy. There are some extras provided in the Eduard PE set but they are so thin and flimsy I opted for plastic card instead. I even managed to get some paint on. Crikey!
Here are pics and mood music.
https://www.youtube.com/watch?v=VMtarj8Ua0s
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, November 10, 2019 - 09:03 AM UTC
Thereís a story about a massive engineering project. The aim was to build a highway through a mountain. The best engineers with the best equipment were sent to do the task. Even so the start was slow as the team formed and they learnt about the equipment. But as the days went by progress became faster. Everyone got to know each other and their tools. Soon everything was working at peak efficiency and the team smashed all records for their work rate. Finally, after weeks of effort the big day came and they broke through to the other side of the mountain. The champagne was readied and everyone felt proud. But just as the corks were about to pop a lone voice was heard at the back of the crowd.
ĎWait!í He said. ĎThat was the wrong maintain.í
The moral of the story? Pride comes before fall, or maybe donít get so engrossed in a task that you lose sight of the big picture. Wish Iíd remembered that before I glued the nose on and forgot to weight it. Iíve been so focused on minute details that I forgot something basic. Luckily I managed to manoeuvre a big blob of white glue into the space behind the instrument panel and pour in Deluxe Miniatures Liquid Gravity. It seems to have done the trick.
Back at the detailing Iíve been adding PE parts to the fuselage around the electronic bays and also test fitting the front of the cockpit. Iím glad I did that before gluing the inside area with the HUD in place because the fit is very tight. I canít get everything aligned. Maybe itís my fault, but I think sanding the edges back a little and then repainting them will be needed. It might actually be the multiple layers of paint I put on in the first place that is causing the problem. Thereís PE to go in too, which will be a squeeze. The photo shows the interior stuck inside the canopy part. Itís not glued.
Slowly but surely weíre edging towards a finished kit. Maybe weíll be ready for paint by Christmas??
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, November 03, 2019 - 09:31 AM UTC
When I was a kid a film called ĎThe Land that Time Forgotí grabbed my attention. These days itís more a case of the detail that manufacturers forgot. I spent some happy and not-so-happy hours replicating the details inside the avionics bay lids, and Iím nearly done. I finally managed to find the right size drill bit to drill out the ends of the sidewinders too. Iíll make some clear seeker heads later. It all looks like this.
Oh, and that film
https://www.youtube.com/watch?v=d0K97czqecQ
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, November 03, 2019 - 09:30 AM UTC
Hi Magnus,
Oh my gawd. Two years? No wonder my stash keeps calling to me. I don't know about my best build ever but this is my longest.
Thanks for keeping me company. I'm happy you're enjoying it and learning as I am too.
Happy modelling,
Steve.
magnusf
KitMaker: 1,824 posts
AeroScale: 1,773 posts
Posted: Monday, October 14, 2019 - 08:16 PM UTC
Steve! Beautiful work, it is a bit like Brian's B-17: even if I never would have the stamina to pull through such a project there is lots of things both to learn and enjoy!
In a few days you're hitting two years with this build...
Magnus
SteveAndrews
KitMaker: 635 posts
Posted: Monday, October 14, 2019 - 06:20 PM UTC
Hello Russ and other friends,
I moved apartments recently and it has kept me away from the bench, so sorry for the delay in replying and also the lack of updates. Luckily I moved without any damage to the kit so more updates are coming soon.
Russ, feel free to lurk :-). I do the same all over the place. I'm happy to share the adventure and really pleased you're enjoying it. My plan is to go for a natural metal finish. Originally that meant a USAF aircraft based at Da Nang in 1965 although recently I've been eyeing the Taiwanese decal sheet.
Before that there's more detailing on the way, and I have to figure out what to do about the nose weight I forgot to add. A quick test fit showed this kit might be a tail sitter, so any advice is gratefully received. I've already glued and filled the nose of course. Doh!
Thanks for looking in, and to all the fellow lurkers thanks also for the interest.
Have a great day,
Steve.
Kevlar06
KitMaker: 3,132 posts
AeroScale: 718 posts
Posted: Tuesday, September 17, 2019 - 01:57 PM UTC
Steve, it's certainly getting there-- I've been lurking from afar, since first commenting over a year ago now when you first thought about starting this model and were deciding which kit to use. I really enjoy your updates. Have you given any thought about a color scheme?
VR, Russ
SteveAndrews
KitMaker: 635 posts
Posted: Tuesday, September 17, 2019 - 09:16 AM UTC
One of the (many) lessons this build is teaching me is the art of compromise. Thereís a limit to the amount of detail that I can reproduce using the tools and materials I have, and a limit to my patience, dexterity and eyesight. Put more simply, trying to scale down every detail is impossible - too many parts would need to be microscopically small and unusably delicate, and therefore beyond my ability to make or work with.
So what to do? Leave details out? Well thatís often Italeriís approach, and Iím trying to enhance the kit. Invest in a microscope and nano printers to get the dimensions exactly to scale? Thatís way beyond reasonable for me. My approach is to create, as far as I can, an impression of the real thing. For example - the tangle of wires inside the avionics bay lid. I made a tangle but each strand is over scale thickness and there are fewer in the bunch than on the real thing. The point is it communicates the desired shape; it saysí tangle of wiresí.
When practically applied, that diversion got me here. Not an exact scale replica of the real parts, but an improvement on the original I hope, and enough detail to sell the realism to people looking.
Oh, and one last thing. I think I can see why Eduard only offered two (not one as I said earlier) of the four sided lip. The original part is moulded with an irregular curve along one side, which I suspect is hard to reproduce in PE. It should be straight, but itís not.
SteveAndrews
KitMaker: 635 posts
Posted: Sunday, September 08, 2019 - 03:01 AM UTC
With some big construction work done I decided to go back to the cockpit and electronics bay. Thereís a lot of photo etch to add around the edge of the cockpit but I wanted to get the inside of the hinged covers that close over the avionics bay done first. Eduardís photo etch set for these areas is a bit odd. Their choice of parts misses some obvious parts ideal for PE improvement and instead gives us unnecessary extras. For example thereís a lip that runs all the way around the bottom edge of the avionics bay door. Eduardís PE offers us just one side out of four. There are also brackets that scream out for PE, but nothing in the set. On the other hand we get crude warning plaques with very low resolution colour printing. I wonder why?
Whatís not up for dispute is the missing cabling. Thereís a nice bundle of twisted cables running from inside up into the roof area. I made these from thin metal wire and also added some details from plastic card and stretched sprue, including making new details for the forward part of the lid. Italeriís sloppy moulding was sanded off.
That seems like a lot of words for some fiddly details, but I hope that all these little changes will add up to an authentic looking Ďplane once Iím done.
Oh yes. Ejector pin marks. They were nicely stamped into awkward details. Thanks Italeri. I filled them will several coats of Mr Surfacer 500 and cut up little bits of sanding sponge to get them smoothed down. Felt good once they were gone - like getting rid of the flu.
Posted: Friday, August 30, 2019 - 09:57 AM UTC
Steve,
Good luck with your first coat of paint. May your touch-ups be few.
Gaz
