Scale Modeling Sponsors
See Your Ad Here!
World War II: Great Britain
SH 1/32nd Hawker Tempest MK.V
betheyn
KitMaker: 4,345 posts
AeroScale: 2,150 posts
Posted: Wednesday, August 02, 2017 - 03:46 PM UTC
Special Hobby via Rowan have sent in their second boxing of the Hi Tech Tempest Mk.V kit, and being rather stupid I opened the box, whilst supposedly working on other reviews, and the inevitable happened, I started it .
Its all SH fault as they included a gorgeous looking resin engine in this boxing, which just cries out to be built, so I did, and with Rowans double build of the earlier Tempests having stalled I just thought what the hell, lets just dive in .
Anyhoo, the customary boxart and info,
Kit - Tempest MK.V "Hi Tech"
Item No - SH 32070
Price - 70 ish
The first job to do (about halfway through the instruction booklet btw) was get the front of the aircraft ready for the inclusion of the resin engine, so the cowling panels need to be cut off and a groove around the edge of the lower front needs channeling out.
Then comes the best bit, the engine.
This is made up of quite a few resin parts, and is beautifully detailed.
Built up and painted, with some wiring (not included in kit).
With the engine built up, I think I had best go back to the beginning of the instructions and build the cockpit.
So stayed tuned .
Andy
litespeed
Staff MemberNews Reporter
KitMaker: 1,649 posts
AeroScale: 1,529 posts
Posted: Thursday, August 03, 2017 - 01:42 AM UTC
Looking good there Andy
KitMaker: 5,476 posts
AeroScale: 3,452 posts
Posted: Thursday, August 03, 2017 - 05:30 AM UTC
Yep, following this one. Very nice start!
Scrodes
KitMaker: 740 posts
AeroScale: 734 posts
Posted: Thursday, August 03, 2017 - 06:15 AM UTC
What colour did you use for the plumbing on the engine? Specifically which paint - it looks great.
Mecenas
Katowice, Poland
KitMaker: 1,590 posts
AeroScale: 1,269 posts
Posted: Thursday, August 03, 2017 - 10:29 AM UTC
Hi Andy!
Generaly speaking opening any model box, if you have other things to do, is never very smart...
Just keep the pace now, you're on the right track. Your current progress looks great.
betheyn
Posted: Thursday, August 03, 2017 - 11:59 AM UTC
Thanks guys, glad to have you along.
That would be AK's Xtreme Metal Brass, sprays really nice, and can be brushed on with a couple of coats.
Hi Andy!
Thanks Michal.
Yep, wasn't the cleverest idea I had .
Plodding on slowly with the cockpit, and considering how many parts there are and the some bits are rather fiddly, it is a most enjoyable build so far.
Andy
betheyn
Posted: Thursday, August 10, 2017 - 02:58 AM UTC
Well I'm slowly making progress.
Cockpit parts sub assemblies.
Cockpit together
The fabric HGW harness, although very nice is a right fiddly thing to put together, took me most of a day.
Andy
KitMaker: 16,671 posts
AeroScale: 12,413 posts
Posted: Saturday, August 12, 2017 - 06:27 PM UTC
Nice work Andy!
Both the engine and cockpit are looking really good. I didn't sneak a look at the engine before sending the kit on to you - and seeing it here, I can understand why you're so impressed.
betheyn
Posted: Sunday, September 10, 2017 - 02:21 AM UTC
Nice work Andy!
Thanks Rowan. I'm glad you didn't look at the engine before you sent it, otherwise I might not of got it .
Well I haven't had much time to work on this for a couple of weeks, but I have managed to do some work.
The front of the fuselage halves need the moulded on firewall removed, for fitting the resin engine. Not too bad to do, but you will need to test fit the resin engine before committing to gluing the fuselage halves together.
Fuselage together, a little seam work needs doing mainly on the front as the fit is very tight.
Next up is the undercarriage bays and attaching the wings.
Andy
betheyn
Posted: Wednesday, October 04, 2017 - 08:25 PM UTC
Well after starting this two months ago, I finally got a good run at the beast over the last three days, such a good run I finished it.
An enjoyable build, and well recommended if you fancy a Tempest in 1/32nd scale.
Now to find somewhere to put the big beastie .
Andy
Posted: Wednesday, October 04, 2017 - 08:40 PM UTC
Hi Andy
Wow! That's stunning! Great job!
betheyn
Posted: Saturday, October 07, 2017 - 09:26 PM UTC
Thanks Rowan.
I have ordered a CMK pilot and a PJ miniatures ground crew to go with it, so as soon as they turn up, they will get painted and I will post some more pics.
Andy
Mecenas
Katowice, Poland
Posted: Sunday, October 08, 2017 - 11:10 AM UTC
That's a big push, I shall learn this technique.
Great model Andy. It looks that when you already deal with all these interior and engine details further assebly process is rather straightforward.
betheyn
Posted: Monday, October 09, 2017 - 02:45 AM UTC
Thanks Michal, it was a big push, one that I had too do or it would have never been finished .
Once the major surgery is done, its a pretty easy build. The only exception is the two inserts for the leading edge wing roots that need coaxing into position then sanding. Why SH did this heaven knows.
Andy
greif8
#277
Bayern, Germany
KitMaker: 670 posts
AeroScale: 491 posts
Posted: Thursday, October 12, 2017 - 08:45 PM UTC
First rate build Andy. The engine looks very, very nice and really stands out.
Ernest
betheyn
Posted: Saturday, October 14, 2017 - 04:15 PM UTC
Ernest
Thanks Ernest, the engine does really set the kit off, and was the main reason it hit the bench before anything else.
Andy
