World War II: Japan
Aircraft of Japan in WWII.
Hasegawa Ki-61-1 1/48
KitMaker: 6,743 posts
AeroScale: 6,151 posts
Posted: Wednesday, January 17, 2018 - 05:36 AM UTC
Hi guys ,
Yes , I have tried Bare Metal Foil, which ended in a huge disaster for me . Will NOT be going down that road again . Also in the past I tried liquid mask and wasn't a fan of it . Will stick with the masking tape . Works the best for me . However , I have made progress on this and got her painted up . This is my worst paint job ever , the whole build actual and rather embarrassed on such a crappy job coming from my bench .
So , can you spot all the errors ? 50 points to the person who can find the cat hair !
Terri
KitMaker: 7,623 posts
AeroScale: 3,138 posts
Posted: Wednesday, January 17, 2018 - 07:07 AM UTC
Hi terry,
Cat hair in red of underside of R. stabilizer?
Now now, it isn't a bad paint job. Looks good to me.
Posted: Thursday, January 18, 2018 - 05:22 AM UTC
Hi terry,
Sorry Fred , not even close . However on the other hand you are warm . It is on the underside .
I had paint lift when un-masking , paint bleed . Very ill fitting canopy resulting in a not so good putty job . I'm affaird to pull on the masking tape . Have a feeling that this go around yielded bad results .
Terri
rdt1953
KitMaker: 1,006 posts
AeroScale: 841 posts
Posted: Thursday, January 18, 2018 - 06:24 AM UTC
Hi Terri - looks like my paint woes from the Hayabusa project may be contagious- too bad but happens to the best of us from time to time - Hang in there- you'll fix it I'm sure . Chin up - Richard
KitMaker: 11,210 posts
AeroScale: 7,390 posts
Posted: Friday, January 19, 2018 - 01:25 AM UTC
Terri,
It's hard to see all the issues you're referring to as the picture size is rather small, but I do see some. Your painting has always been top notch, so if this effort doesn't meet your expectations, why not just strip it and start over? You can also work on the canopy fit issues is that's still bothering you.
Having a cat, I know all to well about cat hairs. The hair in question is on the lower side of the starboard wing which is inverted, so it's on the left not the right. The hair is just to the left of the bomb rack about 1/3 down the cord of the wing.
Posted: Wednesday, January 24, 2018 - 04:50 AM UTC
Thank you Richard and Joel for you continuing support with this build .
So , I can blame you Richard for the build woes ? Cool !
Hi Joel , I did redo a few things ..others not so much . I just wanted it off the bench so I can move on to other projects .
I have made progress and the only thing left to do is a bit of pastel chalk weathering with a final sealant followed by pulling the masking off the canopy .
Will have the final build pics up tomorrow if everything goes well .
Terri
P.S. Joel , you just got yourself 50 points . You are correct on the cat hair . Which I left it there . Blau is a big part of my life so I look at it ..he wanted to contribute as well !
russamotto
Utah, United States
KitMaker: 3,356 posts
AeroScale: 372 posts
Posted: Wednesday, January 24, 2018 - 08:35 PM UTC
Best of luck on this. My build is held up for paint issues right now as well so I really sympathize, though I am not to your skill level.
Posted: Wednesday, January 24, 2018 - 10:14 PM UTC
Terri
Thanks for the 50 points. I can use all I can get.
BTW, I've started my next build, but haven't accomplished enough to make an opening post.
Posted: Friday, January 26, 2018 - 05:48 AM UTC
Hello Russ , thank-you There is nothing wrong with your skill level . You have a uniqueness which no one else has . Really enjoy following your builds . You do really nice work . I read about your paint woes and hpe that you are able to get it playing right .
Joel my friend , glad you can use the points I have a few builds in which there is a cat hair So what are you building then ?
I'm calling this one done ! Finished it last night but I was lazy and didn't feel like posting the pic's . Not my best , but in the end not my worst either . Some of the weeknesses end up turning to a positive .
Terri
Posted: Saturday, January 27, 2018 - 04:27 AM UTC
Thanks guys
Posted: Saturday, January 27, 2018 - 07:19 AM UTC
Terri,
Nicely done. Makes for a fine display presentation. Decaling came out spot on perfect.
I also live with cat hairs as it's my wife's cat that never leaves me alone. And now that I'm retired as Friday was my last day, he's with me every min of the day I'm home.
My new painting procedures involves vac'ing the model room prior to painting. Gee, what fun that's going to be.
My new build is the Airfix 1/48 scale BOB Hawker Hurricane MkI. Made the intro and 1st update post earlier this afternoon.
Posted: Sunday, January 28, 2018 - 05:18 AM UTC
Thanks Joel , glad that some one likes how it turned out .
Terri
Posted: Sunday, January 28, 2018 - 06:37 AM UTC
Fantastic work Terri! I echo Joel's sentiments, and funnily enough your build has inspired me to build another Ki-61 also Hasegawa's offering. Kit has had the wings glued together but the price was to good to pass up. So it'll give you an opportunity to watch me bungle my way through it. LOL
rdt1953
Posted: Sunday, January 28, 2018 - 06:57 AM UTC
Terri - looks good to me ! Sorry it faught you here and there but you got it finished !
Hope you enjoyed it in spite of the difficulties.
Richard
Posted: Monday, January 29, 2018 - 06:32 AM UTC
Thanks guys , it does help the modeling ego !
Terri
mrockhill
KitMaker: 566 posts
AeroScale: 507 posts
Posted: Tuesday, February 06, 2018 - 09:47 AM UTC
Didnt turn out so bad after all! I also really like the scheme you picked with the red tail it over solid green. I guess with the Hinomaru monkey off your back, its time for more Mustangs?!
History usually seems to compare the Ki-61 directly to the 109, I always thought it looked eerily similar to the He-100
KitMaker: 1,574 posts
AeroScale: 1,273 posts
Posted: Tuesday, February 06, 2018 - 01:20 PM UTC
Great result of your Hien, Terri! I like that camo scheme and have built one in these colours also some time ago. Mine was flown by the remarkable Sgt. Masao Itagaki.
Mike, that's true what you said. The Ki-61 was "copied" from the He-100 and not from the Bf 109. They have only the engine in common, DB 601 and the Kawasaki licensed build Ha-40. That's why they are sometimes called "sisters by heart" - together with the Macchi C 202 Folgore, which had the same DB engine, built by Alfa Romeo.
