Eduard 1/48 scale P-47D limited Edition
Posted: Friday, February 20, 2015 - 12:56 AM UTC
After finishing up my 1/48 scale GWH F-15C, I had to make a decision on what my next build would be. I’ve had in my small stash for a a while, Eduard’s 1/48 scale Jugs Over Italy Limited Edition kit. So I thought as my usual practice of one jet/one prop/etc., it would be the perfect build to follow, as I’m a huge P-47 Jug fan, since it was built right here on Long Island by Republic Aviation of Farmingdale. Grumman’s has always been #1, and Republic has held the #2 spot on my list of favorite aircraft manufactures.
The Eduard limited edition kit is in reality the Academy 1/48 scale injected molded kit, with all sorts of upgrades. Two PE-photo-etched sheets with one being colored for the Instrument panel, place cards, electrons, levers and knobs. A sheet of masks, for the windscreen and canopy which is always a nice touch, and a host of Eduard Brassin Resin parts: Wheels & tires, wheel hubs, the correct prop hub, two different sets of prop blades, a very nicely detailed gun sight, and a outstanding cockpit. Rather then the usual one piece cockpit, Eduard has designed it as a multi piece sub assembly as you would expect of an ejected molded cockpit. Decals are designed and printed by Cartograf for 6 different aircraft. I haven’t exactly decided on which one to do as yet, but one of the main goals of this build is to kick up my MNF standards a few notches, so the build will be a NMF Bubble top. Eduard has supplied the builder with a 16 page instruction booklet printed on glossy stock, with the last several pages dedicated to each of the 6 individual aircraft.
I’ve gathered a fair amount of research material, so I felt I could check the kit for accuracy, make corrections as needed, and add small details.
Construction starts with the usual cockpit. The hardest part is cutting all the various walls and pieces off their molding blocks. The floor has nearly a full block, so I opted to use my Dremel and a disc cutter. Wearing a mask and cutting in the garage with the doors open, made short work of this. Final sanding was done as usual on wet emery cloth to cut down on the dust issues.
Work started on the two side walls. Comparing them to the maintenance manual, I noticed that the cockpit light should be on the left side wall, but it’s molded on the right side. Yet, I’ve seen numerous restoration photos with it on the right, and one or two that just omitted it. So I cut it off and moved it to the other left wall, then added an electrical wire from lead wire stock. A few cables were added, and the upper sidewall plate was rebuilt on the right wall. Each wall on the upper rear side has some tube with two mounting brackets, so I made them out of lead wire, and the brackets out of masking tape.
Once the floor was detailed with the supplied parts, I primed all the various cockpit parts with Tamiya Flat Black FX-1. This was done for two reasons, I wanted to further darken the cockpit color, and add some much needed shadow modulation when I air brushed on the color coat.
As soon as I finished cleaning my air brush, I applied the color coat. There’s been a lot written about what was the actual color of the P-47D cockpits. Without going into the long and short of it, I decided that Dark Dull Green would be the way I would go. Using Tamiya paints, I mixed 2 parts XF-5 Green to 1 part XF-4 Yellow Green and two drops of XF-1 Black. I cut this mix 1:1 with Tamiya X-20A Thinner.
The resulting color looks a little too bright due to the lights I used to take the pictures. Next I painted the appropriate electrical boxes, panels, etc. XF-69 Nato Black as it has a more scale look to it then just flat Black. I sealed everything by hand brushing on Pledge, then a wash of enamel Burnt Umber, and when dry a coat of Testors Dullcoat.
I added the colored PE shoulder harnesses and seatbelts to the seat, then started to glue up the cockpit.
Next up was the IP. A backer plate with the backs of the instrument gauges that I drilled out so I could wire them, the instrument faces, and finally the cover plate with the bezels. I have to say that this is so far superior to anything that I could have fabricated or painted.
Using Extra thin Zap A Gap and accelerator I glued up the rest of the cockpit.
With the cockpit now complete, I dry fitted it, and as expected it needs a little tweaking to fit correctly.
Posted: Friday, February 20, 2015 - 01:39 AM UTC
Hi Joel
Great start! The "office" looks fantastic.
Posted: Friday, February 20, 2015 - 01:54 AM UTC
Very nice work on the tub Joel, I'm definitely following your build here.
Redhand
#522
KitMaker: 1,460 posts
AeroScale: 1,443 posts
Posted: Friday, February 20, 2015 - 02:21 AM UTC
Looking really good so far. For variety's sake, you might want to consider a Brazilian Jug.
Posted: Friday, February 20, 2015 - 04:33 AM UTC
Hi Joel
Rowan,
Thanks. I knew you would like it.
Posted: Friday, February 20, 2015 - 04:34 AM UTC
Damian,
Looking forward to your input throughout the build. It should be a fun journey.
Posted: Friday, February 20, 2015 - 04:38 AM UTC
Brian,
If I had a few in the display cabinet, I would. But believe it or not, this is my 1st Jug in more then 35 years.
The Academy kit really isn't even close to the Tamiya kit in terms of detail. I've already cut out the vents right behind the lower cowl and will be replacing them with home made ones that look like vents. Not thrilled with the exhaust header either as it looks really soft.
Glad you found the time to stop by.
Redhand
#522
Posted: Friday, February 20, 2015 - 05:07 AM UTC
Of course! I should also have some time this w/e to do some work myself on the 17.
I have exactly one 47 in my display case too. An Otaki P-47D razorback backdated to a P-47C; built in the 80s as Hub Zemke's "My Comrade."
"One of these days" here too. I assume you're doing one of the colorful Corsica-based 47s?
Carry on. I subscribed.
Posted: Friday, February 20, 2015 - 05:21 AM UTC
Hi Joel.
Nice work so far!
Signed up to follow this build.
I think that we are due for a P-47 GB (hint, hint Damian!)
Posted: Friday, February 20, 2015 - 05:34 AM UTC
Brian,
I'm duly impressed. The old Otaki kit I bought it but don't remember ever building it. As for what scheme, I haven't really studied the Cartograf decal sheet yet.
Posted: Friday, February 20, 2015 - 05:36 AM UTC
Hi Joel.
Nice work so far!
Richard
Welcome aboard Richard. It's going to be a fun ride for sure. I'm more then up for a P-47 group build.
KitMaker: 6,743 posts
AeroScale: 6,151 posts
Posted: Friday, February 20, 2015 - 11:49 PM UTC
Cool , following along with keen interest Joel
Terri
bdanie6
New Hampshire, United States
KitMaker: 615 posts
AeroScale: 459 posts
Posted: Saturday, February 21, 2015 - 01:40 AM UTC
Hi Joel,
Great job on the cockpit. I'll be lurking along too.
Posted: Saturday, February 21, 2015 - 02:04 AM UTC
Terri
Terri,
Why thank you. Chime in as often as you'd like, and then some.
Posted: Saturday, February 21, 2015 - 02:05 AM UTC
Hi Joel,
Bruce,
Thank you. No need to lurk. Just join the party whenever you want to.
magnusf
KitMaker: 1,953 posts
AeroScale: 1,902 posts
Posted: Sunday, February 22, 2015 - 02:00 AM UTC
Finally I've found one of your build threads Joel! I am impressed that you find the time to build since you're so active at kindly commenting the work of others as well! I'll be happy to follow this one.
Cockpit: is detailed the word we're looking for ?
Magnus
Posted: Sunday, February 22, 2015 - 02:25 AM UTC
Magnus
Magnus,
Glad to have you along for the ride. I have plenty of time to build, too much if you ask my wife. I'm semi retired and only work 4 days per week. Getting old does have at least one advantage.
Checkout my F-15C build and Feature in the Modern forum, it's my best ever build by far.
Thearmorer
Alabama, United States
KitMaker: 121 posts
Posted: Sunday, February 22, 2015 - 03:07 AM UTC
Joel,
Great looking 'pit you've got there. You look like you've centered it just right on the used-but-not-abused threshold. Just the right amount of "busy" to look believable. Looks like we've got another F-15 class build, but with a visible means of propulsion this time. Keep it up!
DR
Posted: Sunday, February 22, 2015 - 03:50 AM UTC
Joel,
DR
Thanks for stopping time. Yeah, an actual, visible means of propulsion.
Been working on the waste gate and vents on the lower sides behind the cowl. The kit moldings are terrible, and that's the best I can say about them.
Posted: Sunday, February 22, 2015 - 10:27 PM UTC
With the cockpit done, it's time to move on to the fuselage halves, and take a really close look at how Academy has molded the exterior details. I started and stopped at the lower front of each fuselage where the engine cowl would attach. The Republic engineers had designed two waste vents, and a waste gate valve to help to vent excess exhaust gases hot exhaust gases from the Supercharger. Right under the 1st vent should also be a bleeder tube. Well, Academy's vents are extremely poorly molded, and look more like a blobs then vents, and there is no bleeder valve.
Here's what one is greeted with on each fuselage half:
I thought about just drilling, filing, sanding, and polishing out the vents, then drill out the waste gate. Finish up by drilling a hole for the bleeder tubes that I would install at the end of the build. But the longer I thought about it, the more I was convinced that I couldn't do an acceptable job of it, as it would be easier just to start from scratch
1st step was to cut out the vents, but not damage the waste gate area:
I needed some kind of backing plate so that the viewer couldn't see right through to the other side, but I didn't want it flush to the fuselage skin. So I used a piece of sheet plastic larger then the cut out, and then filled in the side with small pieces of sheet.
I had decided that it would be easier to make one large opening rather then two smaller ones so that the vents were correctly lined up. That required the added on sheet metal brace that every restoration has as a riveted piece:
Next I started to fabricate vents, then sanding and polishing them to a finer trailing edge. You can see in the picture that the front vent's trailing edge still needs to be filed. Also that the waste gate valve has been drilled out, and a punched out gate made from sheet has been glued into place.
At this point, everything is just test fitted, and looks a little rough even though the pictures are larger then life size. The bleeder lines will have their holes drilled, but the lines will be added at the end of the build. Installing them now is a certainty, that I'll break them off as quickly as I install them.
KitMaker: 1,732 posts
AeroScale: 1,336 posts
Posted: Thursday, February 26, 2015 - 12:17 AM UTC
Joel, just came across your new build blog and also signed in to follow. I've build 3 T'bolts so far, of which 2 are the Academy kit (D and N). Guess, I need to build another one soon after you're mouthwatering me with your P-47 right now ....
Posted: Thursday, February 26, 2015 - 12:37 AM UTC
Torsten,
I'm quite sure that your two builds are more then the equal of mine. So glad that you're following right along. Feel free to add and suggest anything as you deem fit.
chris1
Auckland, New Zealand
KitMaker: 949 posts
AeroScale: 493 posts
Posted: Thursday, February 26, 2015 - 01:05 AM UTC
Yay
Hi Joel.
I've rolled my chair over ,got the coffee and biscuits ready.
Between you and Dave De Silva,almost a group build.
Any chance of posting a pic of the decals?
Since you haven't chosen which aircraft to do perhaps a poll or similar based on the kit decals.
I'll shut up now.
Chris
Posted: Thursday, February 26, 2015 - 01:49 AM UTC
Chris,
A group build of two. Never thought of that.
Actually, I've narrowed it down to the P-47D-27RE sn:42-27277 of the 315th FS, 324th FG, circa 1945. The interesting thing about this aircraft is that it was transferred after a wheels up landing and repairs to the 41th FS, 324FG where it was repainted from Miss Ann to Amy Lou. I'm inclined to replicate it as Miss Ann.
Here's the decal sheets:
magnusf
Posted: Thursday, February 26, 2015 - 02:00 AM UTC
You're actually going NMF? I usually start there but during the build I always find overwhelming evidence against it and end up with something green and soothing...
Magnus
