1:48 Hawker Hurricane Mk. I - DUAL REVIEW
Posted: Friday, October 14, 2011 - 05:36 AM UTC
Let battle commence! Can Italeri challenge Hasegawa in the Hurricane stakes? Two reviewers take a look at Italeri's all-new quarterscale kit, comparing it with the market-leading Hasegawa offering.
Read Jean-Luc Formery's review HERE
And read Paul Barton's review HERE
robot_
KitMaker: 719 posts
AeroScale: 691 posts
Posted: Friday, October 14, 2011 - 08:15 AM UTC
Thanks Paul and Jean-Luc, two very good reviews.
With the Hasegawa spinners being so different from the new kit's, whose are more accurate?
ludwig113
KitMaker: 1,381 posts
AeroScale: 1,110 posts
Posted: Friday, October 14, 2011 - 08:31 AM UTC
i would say that the hasegawa ones are more accurate.
paul
vanize
KitMaker: 1,954 posts
AeroScale: 1,163 posts
Posted: Friday, October 14, 2011 - 10:41 AM UTC
actually, hurricanes had several types of spinners, so both are potentially (but perhaps not actually) accurate. compare:
even the top and bottom images seem to have slightly different spinners despite being similar in shape.
Antoni
KitMaker: 574 posts
AeroScale: 573 posts
Posted: Saturday, October 15, 2011 - 05:07 AM UTC
Three types:
de Havilland - short and pointed - 3rd photo.
Rotol - short and blunt, bulbous, same as fitted to Spitfire Mk II. 2nd photo.
Rotol long chord - long and pointed - specifically designed for Hurricane to replace the Rotol borrowed from the Spitfire. 4th photo.
First two fitted to Hurricane Mk I, the Rotol long chord was fitted to later built Mk Is and other Mks.
Antoni
KitMaker: 574 posts
Posted: Sunday, October 16, 2011 - 01:52 AM UTC
"...except the Malta machine which is overall Azure Blue with a Middle Stone/Dark Earth rudder. "
That’s not correct. 69 Squadron carried out reconnaissance duties and their Hurricanes were tasked with the sorties over the most dangerous targets. P3144 was locally modified by lightening the airframe and fitting two cameras. Land Temperate (Dark Earth/Dark Green) pattern A was the original scheme not Dark Earth/Mid Stone. It was over painted with a locally mixed ‘Matt Royal Blue’ colour made from five gallons of De Luxe Boston blue, seven pints of turpentine, 16 lbs of zinc powder, and 3 lbs of De Luxe black. The fin and rudder were not re-painted and left in the original Dark Earth/Dark Green.
Troy_Smith
KitMaker: 5 posts
Posted: Sunday, December 10, 2017 - 07:23 PM UTC
Three types:
this has come up as a link from a discussion on Britmodeller
http://www.britmodeller.com/forums/index.php?/topic/235023685-italeri-hurricane-mki-trop-boxed-with-wrong-wing-set
A Mk.I Hurricane has 5 potential props
Watts 2 blade.
De Havilland Spitfire type (early aircraft, and the Finnish and Romanian as well)
overhangs the nose ring as meant for a Spit.
De Havilland Hurricane type, smaller and pointier, used on some early aircafrt, and standard on Tropical Mk.I's and Sea Hurricanes
Rotol Spitfire type, one associated with BoB Hurricanes
Rotol Hurricane type, or 'bullet' Rotol, some late MkI's, all Mk.II's
but just read this as it's illustrated
http://www.britmodeller.com/forums/index.php?/topic/234980181-hawker-hurricane-propellers-and-spinners-a-modellers-guide/
and covers all Hurricanes versions.
ALL the Italeri spinners are vile abominations, as the nose ring is too big.
the Italeri kit is so riddled with mistakes I have not finished documenting them..
http://www.britmodeller.com/forums/index.php?/topic/234935596-sea-hurricane-148-italeri/&do=findComment&comment=1390213
Sadly there is no OOB accurate Hurricane in 1/48th
HTH
Posted: Sunday, December 10, 2017 - 07:56 PM UTC
Troy,
Thanks for the link. How about the Airfix 1/48 kit (the new tool one)? It seems pretty good!
Troy_Smith
KitMaker: 5 posts
Posted: Monday, December 11, 2017 - 06:28 PM UTC
Troy,
Hi
It's pretty good, but has some errors, most are inherited from the 72nd fabric wing kit...I wish I'd paid more attention to that as I'd have harassed Airfix..
chap on Britmodeller did a stunning build
http://www.britmodeller.com/forums/index.php?/topic/234986216-148-airfix-new-tool-hurricane-mki-p3039-from-no229-squadron-completed-on-31-10-at-1150-pm/&page=2
which deal;s with the problems I mention below.
the really hard problem is the fuselage to wing join, for the non-obsessed it's not that noticeable.
the think wing trailing edge is easy to deal with, the thick ailerons not so.
It maybe a bit too long, but that is not noticeable.
the wheels look a bit 'doughnutty' and the prop spinners look a bit long, but that maybe just photos.
One 'gotcha' on the prop is it is possible to fit eitehr set of blades to each spinner... I've seen two build with DH blades on a Rotol spinner....
As i have said before, poor old Hurricane, if things like this happened on a Spitfire kit you'd not hear the end of it...
T
KitMaker: 1,732 posts
AeroScale: 1,336 posts
Posted: Monday, December 11, 2017 - 09:35 PM UTC
A really lovely build, Troy! What I especially like is, that there's only a little bit of weathering. You really have to look for it. Unfortunatly, today it seems to be "state of the art" to overdue weathering, sometimes really extremely ....
Troy,
Yes it is, Michael! I've built 2 Hurris this year (Airfix and Hasegawa) and was really pleased how easy the Airfix kit went together. You know me by now, I don't make a lot of fuss about a kit - I build it and then I argue ....
If you like, scroll down this page and have a look.
Posted: Monday, December 11, 2017 - 09:46 PM UTC
Actually, I'm getting three of the Fly 1/32 Hurricanes (Mk.I, IIc, and IId) for Hanukkah and am looking forward to having a look at those. I may do some reviews for AeroScale.
