| Subject: Scratchbuilding: Generally what do I need? |
 | Sean Hopkins shopkin4 | Location: Alabama, United States Member Since: March 29, 2009
Posts: 125 entire network,
0 this site
| Posted: Friday, October 16, 2009 - 04:19 PM UTC |
I am going to start my next project in a little under a month and I want to make some additions to the project that make my model unique, so what better than to scratchbuild! However, I have never done it, and hobby shops that carry plastic are a decent trip away so I am better ordering it online.
I have never done it before, but for 1/35 scale could someone possibly list some tools. This would help me as well as others. If something like this exists already then point me in the right direction.
From what I think I will need for any general scratch building would be: T beams H beams Thin Rod Possible a punch die (had one and lost it)
lets go from there
THanks |
| HIDE SIGNATURE AREAS |
 | Joe Szczygielski mother
Associate Editor
|  | Location: New York, United States Member Since: January 29, 2004
Posts: 3,048 entire network,
762 this site
| Posted: Friday, October 16, 2009 - 04:56 PM UTC |
I do alot of scratchbuilding, and my tool list is pretty basic.
1. Reference photos and books 2. Thin super glue and Ten-X 3. Sanding sticks 4. Metal 6'' ruler in MM's 5. Plenty of sharp hobby blades 6. Metal files 7. Sharp pencils 8. Circle / square templetes
That's pretty much it for me.
Good luck with your Project, Joe |
| It feels like bible camp…Only I’m not crying pretending I’m somewhere else. | |  |
 | mat | Location: Limburg, Netherlands Member Since: November 18, 2003
Posts: 456 entire network,
42 this site
| Posted: Friday, October 16, 2009 - 04:59 PM UTC |
well, some card would be a good idea. The Evergreen stuff is quite expensive. My LHS has plastic card which is from an unknown supplier and costs 10% of the evergreen stuff. You can use thick card for supporting structure sor large surfaces. The thin card can be used for curved areas. Some square rod is also useful if you want make boxed structures from card. What I found out in the past is that good equiment is a must. Since I bought a small steel ruler, many measuring and cutting problems were solved. I have a Tamiya ruler with a scale up to 0,5 mm. But any brand will do. A pen with a very fine tip (we call them "fineliners" here) is also very useful and cost about a euro here. oh I forgot, those thin flat strips from evergreen are also handy. I use them a lot. What are you building? I'm curious |
"We don't know anything about their race, history, or culture, but one thing's for sure. They stand for everything we stand against."
Zapp Brannigan from the cartoon series "Futurama"
0 this site
| Posted: Friday, October 16, 2009 - 05:13 PM UTC |
I am planning on a doing a challenger 2 diorama, with a possible burnt out iraqi BMP and building. Not really sure I am finally starting to plan things out, but I wanted to add a lot of details. I am currently at school so I am slowly but surely gathering all my resources. |
 | Adam Kijak Maxymilian | Location: England - West Midlands, United Kingdom Member Since: March 21, 2009
Posts: 117 entire network,
0 this site
| Posted: Friday, October 16, 2009 - 05:26 PM UTC |
Hello, word of advice about evergeen plastic. After few projects involving scratchbuilding in last few years and trying different materials i would highly recomend evergreen. I know that maybe is a bit expensive, but it is worth it, so much easier to work with. For my project of M88 on which i have to do a lot of modifications i have spend so far 15 pounds and there will be some plastic left. |
 | phil cpt_Hobo | Location: England - East Anglia, United Kingdom Member Since: August 28, 2009
Posts: 6 entire network,
0 this site
| Posted: Friday, October 16, 2009 - 06:12 PM UTC |
polyfila or ready mixed filla |
| HmmmmmmmmmmmmmmmmmIC!!!!!!!! | | |
 | mecanix | Location: Kerry, Ireland Member Since: March 03, 2003
Posts: 53 entire network,
0 this site
| Posted: Friday, October 16, 2009 - 10:20 PM UTC |
[quote]I do alot of scratchbuilding, and my tool list is pretty basic.
Good luck with your Project, Joe[/quote
This is a pretty sound list of the basic requirements, I would only add a decent set of dividers or compass for transfering measurements. Which brings me to, in my opinion, the main requirement for any scratchbuilder, a drawing. It can be a full scale 3/5 view plan or a sheet of paper with the basic shapes and dimensions drawn on it but it keeps you litterally straight and proportional. Good luck with the project and if you do get the scratchbuilding bug, Evergreen will become your God!!! Paddy |
 | Soeren Gorizont | Location: Sachsen, Germany Member Since: November 28, 2007
Posts: 477 entire network,
15 this site
| Posted: Friday, October 16, 2009 - 11:00 PM UTC |
... with a possible burnt out iraqi BMP and building ... That sounds interesting! I wait for the first pictures. greetings... Soeren |
in progress:
- detailing my s.10cm K18 "snow dio"
- soviet Venera-9 + 10 +14 Venus-landers (1/48)
planned:
? 17cm Kanone 18 (DAK) | | |
 | bob davis dioman13 | Location: Indiana, United States Member Since: August 19, 2007
Posts: 365 entire network,
1 this site
| Posted: Saturday, October 17, 2009 - 02:28 AM UTC |
Sean, For ground work I'll add my 1/2 cents worth. I keep on hand the following; plaster of paris/tackey white glue/liquid dish soap/baby sand/cat litter(not the grey, it's clay b ased and will desolve)/ small gravel and coal/cheap water based paint (browns)/ static grasses/twine/styrofoam and pastel's. I paint the base to water proof it and build up the height with foam. Mix plaster with glue/water and paint and dish soap and apply to base. Contour to desired likes and add baby sand for ground texture and some cat litter. Add building, stones, walls ect. Next dry brush ground and add f oliage. Don' forget to press figures and vehcicals and such into moist ground work so they sit right. Hope this helps. |
| There is no return policy on time spent | | |
 | Eric Johnstone stoney | Location: British Columbia, Canada Member Since: October 16, 2006
Posts: 203 entire network,
3 this site
| Posted: Saturday, October 17, 2009 - 03:49 AM UTC |
Sean, just because I haven't seen it on the list yet I have to reccomend Aves Apoxie sculpt. Its a 2 part putty that is a dream to work with, great for sculpting and such. Good luck! |
 | José Silva clay_cliff | Location: Lima, Peru Member Since: April 07, 2008
Posts: 179 entire network,
0 this site
| Posted: Saturday, October 17, 2009 - 04:45 AM UTC |
I bought these plastic sheets two years ago:  The metal ruler is 60 cm. They're 0.35 mm, 0.60 mm and 1.00 mm thickness and they used to be bigger, but since I bougt them, I've been using them, specially the 1.00 mm thickness. The price? S/. 5.00 for the 0.35 and 0.60 and S/. 10.00 for the 1.00 (S/. = Nuevos Soles, Perú currency), that's about USD 1.70 and USD 3.50 respectively! I purchased them in a serigraphy supplies shop. Best regards. José. |
 | Graeme Davidson stormfront | Location: Alberta, Canada Member Since: August 05, 2003
Posts: 601 entire network,
0 this site
| Posted: Saturday, October 17, 2009 - 08:22 AM UTC |
In addition to Joe's list, I would add this: Mini Square and this: 2x2 Angle Plate and this: Drill Bit set |
 | T Murphy McCraken Cuhail | Location: Illinois, United States Member Since: February 10, 2004
Posts: 1,929 entire network,
19 this site
| Posted: Saturday, October 17, 2009 - 09:45 AM UTC |
I mentioned it in your SB Forum post and I'll repeat it here. All of the above recommendations (Especially Mother's list) and one more thing. A self-healing cutting mat or just an old, flat piece of wood to cut on. Tabletops take damage pretty easily. Cuhail  |
Campaigns:
Stop, Look and Listen -STARTS 02-01-09
What if? -STARTS 06-01-09
ACUTR Again-STARTS 08-18-09
On the bench:
1/35 Scratchbuilt [censored]
 | Jim Carswell junglejim | Location: Alberta, Canada Member Since: February 18, 2003
Posts: 527 entire network,
0 this site
| Posted: Saturday, October 17, 2009 - 01:52 PM UTC |
I will add (in addition to Graeme's suggestion of a small square), NWSL Chopper or Chopper 2 and True Sander. I pretty much have the entire Evergreen stock in a drawer, I had a list and every visit to a hobby shop I would get a pack, for eg .020 x .030" one day, .020 x .040" the next time. Sheets of .005 through .080", a punch and die set, cordless drill or Dremel Mini-mite, sanding block, and a good set of needle files.
Jim |
0 this site
| Posted: Saturday, October 17, 2009 - 02:25 PM UTC |
These suggestions are all very helpful. Thank you every one! |
 | John Osselaer John_O | Location: Oost-Vlaaderen, Belgium Member Since: November 23, 2007
Posts: 329 entire network,
0 this site
| Posted: Saturday, October 17, 2009 - 07:42 PM UTC |
I would like to add a scribbler! You know, a knife with a curved beak or what they call a P-cutter. I find those very useful for cutting plasticcard. I have both the Tamiya and the Trumpeter one: http://www.1999.co.jp/itbig09/10096107.jpg http://www.ask-models.com/shop/images/uploads/trumpeter/TM09912.jpg cheers, John |
| "Do not allow yourself to be programmed." UR, Detroit | |  |
