See Your Ad Here!
Reverse Post Order
REPLY
NEW TOPIC
IMAGE HELP
SUBSCRIBE
Early Aviation
Subject: WNW GB 2009 - 10 Bristol F2B - James F
James Fahey
CALLSIGN: Jamo_kiwi
_AEROSCALECONTRIBUTORLocation: Wellington, New Zealand
Posts: 24 entire network, 23 this site
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, October 07, 2009 - 10:07 PM UTC
Its time to make a start on the group build. I'm doing the Biff as a cut-away on one side to show -off the gorgeous interior detail to the max.
So far I have had a go at weaving my own pilot seat using thin copper wire with the kit item as a shape pattern. I'm reasonably happy for a first effort but will probably make another based on the experience gained.
The fuselage has been cut away carefully, to leave the metal stitching frames. Talk about flimsy! I'm hoping once the fuselage is closed up it will become a bit more rigid. There was a strong sense of "oh boy I hope this exposed thing works because there is no going back now" as the razor saw bit into the plastic. The thickness of the fuselage side is the unknown factor here - more on this later.
I'm using the restored F2B from the RAF Museum as a guide, although I have come to see that some of the fittings reflect a post-war F2B not the wartime version. This was a challenge for my WNW LVG build as well, given that some of the Shuttleworth aircraft is not original.
In terms of references, so far I have Vol 1 of the Datafile Special (which wasn't as much help as I had hoped), Chaz Bowyer's Bristol F.2B King of Two Seaters (which is little use for modellers but has an interesting and fairly comprehensive service history) and best of all was Rowan Baylis' walkaround photos available right here on Aeroscale:
http://photos.kitmaker.net/showgallery.php/cat/19336
Superb photos Rowan! I will paste in some of these to this thread as I go, to show how the kit can be made more accurate in places.
Does anyone have Vol 2 of the Bristol F2B Datafile Special? How useful is it for modellers - especially regarding internal details?
Happy Modelling
James
REPLY
REPLY & QUOTE
HIDE SIGNATURE AREAS
terri werner
CALLSIGN: thegirl
_AEROSCALECONTRIBUTORLocation: Alberta, Canada
Posts: 3,138 entire network, 2,648 this site
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, October 08, 2009 - 02:35 PM UTC
Hello James !
I really like your detailing with the seat . What gauge of copper wire did you use ?
REPLY
REPLY & QUOTE
ModeratorStephen T. Lawson
CALLSIGN: JackFlash
_AEROSCALECONTRIBUTORLocation: Colorado, United States
Posts: 5,994 entire network, 5,562 this site
_VISITCOMMUNITYGeneral of the Army
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, October 08, 2009 - 03:44 PM UTC
Its time to make a start on the group build. I'm doing the Biff as a cut-away on one side to show -off the gorgeous interior detail to the max. . ."
Happy Modelling
James
James please put a bug in Richard's ear on the cutaways. That kind of display always is a stunner. If they provided an aftermarket fuselage with the outer skin off (at least partially) just think of all the beauty that could be exposed for regular viewing.
REPLY
REPLY & QUOTE
Are you frequently seen with blood shot eyes from staying up til 3am to get the right colour scheme on your latest WWI model?
James Fahey
CALLSIGN: Jamo_kiwi
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, October 08, 2009 - 08:52 PM UTC
Hello James !
Hi Terri
I've had the copper wire for a long time - I think it came from a motor originally. Any electronic shop will sell electrical wire you can strip the plastic off and get some very thin gauge stuff. I also went to a handcraft shop and bought a reel of beading wire made by Crown Fox size #34 (24 yards) which is about the same gauge as the copper wire. I will try that for the second seat.
As my interior will be more visible than most I am doing a bit of research to determine what details could be added for extra realism.
Looking at the F2B at the RAF Museum you can see the screen behind the observers cockpit has holes in it for control wires to pass through. The holes have leather reinforcing panels around them:
This photo taken by Rob Leigh shows the scrren from the Shuttleworth machine which is only half height, so no need for any holes:
I wonder if the pockets on the screen were used for Lewis drums as there was room for seven drums elsewhere (6 on the brackets and one on the gun). Maybe maps or a flare pistol would have been more likely?
There is a handle on the right hand side of the fuel tank for adjusting the incidence of the elevator. In the kit it is quite simplified, which is fine for viewing from above but needs to be seperated from the notched bracket as per this photo from Rowan Baylis:
There is also a black support bracket which holds the control lever, mounted on the lower longeron.
The observers seat was capable of sliding fore/aft on the black runners, and was also capable of being flipped upwards out of the way when the Lewis MG was in action. I have drilled out the holes along the black strip so that they're visible from the 'other side'.
The mounting 'pyramid' under the rudder bar can be thinned considerably. Also, the mounting bracket for the brass reservoir (for the Constantinesco interrupter gear) is quite different to the kit item. Normally this wouldn't be visible, but for my 'opened up' build I'll have a go at making a new one. A PE set would really be the answer!
Happy Modelling
James
REPLY
REPLY & QUOTE
Carl Althaus
CALLSIGN: CaptainA
_AEROSCALECONTRIBUTORLocation: Indiana, United States
Posts: 2,219 entire network, 1,469 this site
_VISITCOMMUNITYMajor General
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, October 09, 2009 - 12:55 AM UTC
It looks like you will get a real good opportunity to practice your rigging.
REPLY
REPLY & QUOTE
Now, to quote Monty Python "Albatros"
"Treat 'em Rough",
Carl
Current Build---A Jug, currently stalled, a B-17 for the Mighty Eighth Campaign, and the Wingnut group Build which has started. I have also been delving into the darkside (Muscle Cars
James Fahey
CALLSIGN: Jamo_kiwi
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Sunday, October 11, 2009 - 07:32 PM UTC
I've had a second try at weaving my own wicker seat, moving a bit further up the learning curve. What I didn't get right with the first try (seat in the middle) was the 'X' crossover between the upper and lower sections. Also the second one has more dense weaving which I did by squeezing the rows together with tweezers after each thread.
As pictured, I used #34 gauge beading wire, which proved to be soft enough to weave easily. There are two vertical wires in each hole - make them too long and trim when finished. These verticals seperate half way up and join with adjacent wires to make the X. Leather padding is Tamiya epoxy putty rolled out into a thin sausage and plonked on top of the weaving (it still needs a bit of sanding).
I still have to replicate the fine weaving up the front supports - thinking of using dental floss for this. Colour will be the brighter wicker seen in the Wingnuts photo not the 90 year old colour of the Hendon seat.
REPLY
REPLY & QUOTE
terri werner
CALLSIGN: thegirl
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, November 02, 2009 - 02:28 AM UTC
Wow , love your seat's James ! Very well done .
REPLY
REPLY & QUOTE
Andy Appleby
CALLSIGN: Torchy
Posts: 1,125 entire network, 34 this site
_VISITCOMMUNITY_AGUARDALT Member of IPMS-UK KitMaker BranchWarrant Officer Class 3
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, November 02, 2009 - 02:30 AM UTC
Fantastic work James,love the seat
I use that crown fox beading wire on model ships,superb stuff.
I love cutaway models ,I will follow this build with added interest
Andy
REPLY
REPLY & QUOTE
Major Caryle,
"Shall we have a go at the far end now,sir?"
Lt Colonel "Johnny" Frost,
"Having a go,is hardly text book terminology Harry"
Major Caryle,
"But you'll let us try sir?"
A Bridge Too Far
Nick Zourbakis
CALLSIGN: NickZour
Posts: 363 entire network, 200 this site
_VISITCOMMUNITYTechnical Sergeant
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, November 10, 2009 - 06:44 AM UTC
Question 1: Can you please show me the F.2B campaign link ??
Question 2: Can my Bristol F.2B be in the campaign ??
Cheers Nick
REPLY
REPLY & QUOTE
All Weather Modeller!!!!!
The Beatles for ever & Ever!!!
__________________
BIRTH DATE:
22/11/1995
CALLSIGN: JackFlash
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, November 10, 2009 - 10:20 AM UTC
Cheers Nick
I don't think there is a Bristol Campaign just the WNW Campaign.
REPLY
REPLY & QUOTE
ADVERTISEMENT
Nick Zourbakis
CALLSIGN: NickZour
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, November 10, 2009 - 07:08 PM UTC
Sorry but what is the WNW Campaign ???
Cheers Nick
REPLY
REPLY & QUOTE
__________________
BIRTH DATE:
22/11/1995
CALLSIGN: JackFlash
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, November 10, 2009 - 07:28 PM UTC
Here you go Nick.
Click Here.
REPLY
REPLY & QUOTE
Reverse Post Order
REPLY
NEW TOPIC
IMAGE HELP
SUBSCRIBE
TOP
REPLY
 ACTIONS LATEST POSTS FORUM FAQ IMAGE HELP
