Subject: FEATURE 1:48 Fw 190A Nightfighters |
 | Jean-Luc Formery TedMamere
Contributing Editor
Posts: 4,844 entire network,
3,553 this site
| Posted: Tuesday, October 06, 2009 - 09:33 AM UTC |
 Here is a full review build article of Eduard''s 1:48 scale Fw 190A Nightfighter Dual Combo, a very demanding but in the end also very rewarding package. Link to ItemIf you have comments or questions please post them here. Thanks! |
Better think one hour and build five minutes...
Than think five minutes and build an hour! | |  |
| HIDE SIGNATURE AREAS |
 | Rowan Baylis Merlin
Managing Editor
|  | Location: No Regional Selected, United Kingdom Member Since: June 11, 2003
Posts: 9,569 entire network,
6,033 this site
| Posted: Tuesday, October 06, 2009 - 09:53 AM UTC |
Hi Jean-Luc Amazing work on what must be your quickest build yet! When you mentioned it to me last week, I thought you were planning to build the kits, not that you'd already got them almost finished! They look fantastic! All the best Rowan |
(formerly "Porky")
BEWARE OF THE FEW...
As I grow older , I regret to say that a detestable habit of thinking seems to be getting a hold of me. - H. Rider Haggard | |  |
 | Steffen Arndt alpha_tango |  | Location: Germany Member Since: September 07, 2005
Posts: 3,277 entire network,
3,018 this site
| Posted: Tuesday, October 06, 2009 - 07:27 PM UTC |
Hello Jean-Luc
it is just amazing how fast you put these complex kits together .. outstanding work!!! Will you bring them to Merchweiler?
Though .. you know me, I have two nit picks on the article:
In your Pg.4 paragraph you write of "2 13mm MG 17". That is wrong the 13mm gun was the MG 131 .. the MG 17 was a 7,92mm gun (according to Wikipedia ..I just checked it, I thought it was 7,62) .. also called "Luftwaffenanklopfgerät".
And another one re armament. In paragraph pg. 5-7 you write that the covers on the wings were added for the MG 151, which is also not quite correct. they were added for the larger 3cm MKs (108 or 103). It seems they went into standard production of the wing as it was fitted no matter what actual armament was in the wing and it seems also very common on Schlachtflieger versions (of course there is always the exception to the rule that ruins your(my) day)
Still a great article but my kit will be in the box for quite a while .. soooooo many other projects to build...
all the best
Steffen |
| DULCE ET DECORUM EST PRO HOBBY MORI | |  |
Contributing Editor
3,553 this site
| Posted: Wednesday, October 07, 2009 - 12:20 AM UTC |
Hi Rowan and Steffen, Thanks for the kind words... and the nitpicking! I will of course edit the article. I've finished it late last night so let's say I was a little bit tired... Thanks again guys! Jean-Luc |
Contributing Editor
3,553 this site
| Posted: Wednesday, October 07, 2009 - 12:35 AM UTC |
Hi again Steffen, I've changed the text. The first mistake happened because I've wrongly read the kit's history and the second because of my lack of knowledge about the subject...  so thank you again! Of course I will bring the Fw 190s to Merchweiler. I didn't built many models this year so they will fill the space on the tables. Will you come with your models as well? Jean-Luc |
 | Ben Micklem robot_ |  | Location: No Regional Selected, United Kingdom Member Since: March 08, 2009
Posts: 219 entire network,
212 this site
The two planes both look great. It is annoying that there aren't enough parts to build every combination of the options, and after making that engine, you would have thought they would have added the detail to the engine covers so you can show it off. The photos of the different stages of painting look really good- the two planes being placed in exactly the same place between shots. How long did these take to build Jean-Luc? |
3,018 this site
| Posted: Wednesday, October 07, 2009 - 03:47 AM UTC |
Hi again Just for thought: looking at the pix of Migges white 9 and your model the rhs antennae look too narrow together and the lhs is also not fully met (should be closer to the wing IMO) ... I know I am a PITA .... Edit: when I speak of sides (in most cases) I try to refer to it from the pilots perspective sitting in his crate   all the best Steffen P.S. Source: http://www.dorst-freiburg.de/Kopie%20(8)%20von%20hp72z/Fw190.html |
 | Rowan Baylis Merlin
Managing Editor
6,033 this site
| Posted: Wednesday, October 07, 2009 - 04:16 AM UTC |
Hi Steffen It also looks like the antennae on the left (of picture) were parallel to the ground, not following the wing's dihedral as in the kit. All the best Rowan |
(formerly "Porky")
3,018 this site
| Posted: Wednesday, October 07, 2009 - 04:31 AM UTC |
Well I think the kit/ J-L got it right.
When you look at the shadow at the leading edge and the aerial it seems to be the same angle (IMO)
all the best
 | Rowan Baylis Merlin
Managing Editor
6,033 this site
Hi Steffen I wonder if that is "White 9"? There seems to be an outline to the fuselage cross and the lower cowl is a dark colour. Looking at the shots at the bottom on your link (and not being able to read the German text quickly), are they all of the same aicraft? - those details differ between pics. Was it repainted? All the best Rowan |
(formerly "Porky")
 | Rowan Baylis Merlin
Managing Editor
6,033 this site
| Posted: Wednesday, October 07, 2009 - 04:40 AM UTC |
When you look at th eshadow at the leading edge and the aerial it seems to be the same angle (IMO)
all the best
Hi again We may be talking at cross purposes. The aerials on the right of picture (the aircraft's port wing) are indeed at the angle of the wing - but the ones on the other side are pretty much parallel to the ground: All the best Rowan |
(formerly "Porky")
3,018 this site
| Posted: Wednesday, October 07, 2009 - 04:50 AM UTC |
Hi Rowan might be, but there is the ortho chromatic crap and IMO the lower cowl could be yellow (BTW there are for sure pix of different aircraft .. but I think the one I quoted plus the one directly left of it show the same a/c .. too bad we can*t read the inscription on the "nose art") Thats why I do not like searching the i-net, but I could not find anything in my books so far .. still I do not think the aerials would be different on another machine. of course there are these pix of a prototype with non streamlined arms, but still the distances are the same because you need exact measures here to get correct readings from your screen. I am pretty sure the distances in the kit are wrong (thats why I searched for some pix) ... if you can prove me wrong I would be happy to admit I made a mistake. all the best Steffen P.S. Luckily I found 2 pix of 1N in Lorant vol.1 so I am pretty sure I can build that machine one day (it is the one I want to do plus an A-5 of Walter Grabmann) P.P.S. Quoted Text
ahh yes, my bad .. think you are right considering the prototype pictures on the site I have given Steffen |
 | Rowan Baylis Merlin
Managing Editor
6,033 this site
| Posted: Wednesday, October 07, 2009 - 04:56 AM UTC |
Hi Steffen No, I agree with you that there's something not quite right about the kit's antennae. The "anters" on the left (the a/c's starbord wing) definitely look longer on the real plane. Still, I only wish I could build as well (and as quickly!) as Jean-Luc! All the best Rowan |
(formerly "Porky")
 | marc toillie mark58 |  | Location: Bas-Rhin, France Member Since: July 28, 2009
Posts: 2 entire network,
1 this site
| Posted: Wednesday, October 07, 2009 - 06:18 AM UTC |
Hi These two look like credible Mosquito hunters don't they ? The Eduard dual combo set has a lot to offer, I'm impressed Jean-Luc's work is outstanding, I like the paintjobs I'll belong to the lucky ones who will see the models for real in Merchweiler
Marc |
 | Aleksey erwin_rommel | Location: Brest, Belarus Member Since: July 20, 2009
Posts: 52 entire network,
47 this site
| Posted: Wednesday, October 07, 2009 - 06:36 AM UTC |
Looks great! Выглядит здорово! It seems to me that lower surfices aren`t painted in light blue, are they? |
3,018 this site
| Posted: Wednesday, October 07, 2009 - 06:46 AM UTC |
Hi Aleksey yes, it looks healthy  (had to use multitran ... my Russian is much too rusty) Hа здоровье! Steffen |
Contributing Editor
3,553 this site
| Posted: Wednesday, October 07, 2009 - 07:49 AM UTC |
Hi all, It seems there is a lot to discuss about the models. I think it's great because that's why review builds are made for aren't they? Ben, the first picture (cockpit tubs) was taken in September 2nd and the pictures of the finished model in October 1st. So it took about a month to complete both models. Aleksey, the under surfaces are light blue (RLM 76) but the oil wash may have darken the color a little bit, or maybe it's because the pictures were shot at dusk... I've decided to build the models as per instructions and from the box, including the color shemes and the position of the antennas... except for those which are located on the underside of the A-7. The antennas of the A-8 also look a bit thick when compared to the real ones. Hi Marc! Nice to read you here! Jean-Luc |
 | mwolfe wingman |  | Location: Pennsylvania, United States Member Since: December 09, 2003
Posts: 584 entire network,
567 this site
| Posted: Wednesday, October 07, 2009 - 08:31 AM UTC |
Great job. Nice review and great photography. Wingman out. |
WATCH OUT THE WOLFPACK IS COMING!
WOLF#8 | | |
 | Automaton | Location: United States Member Since: August 12, 2007
Posts: 38 entire network,
34 this site
| Posted: Wednesday, October 07, 2009 - 11:12 AM UTC |
Those are both very fine builds, Jean-Luc, but now you've probably caused me to have to add this set to my already burgeoning stash. A question: were you able to mix a good color match for the Eduard pre-painted interior parts, or did you use the interior tint color you referred to in the build article to integrate them? (Edit: I reread the article and see that you used X63, but the second part of the question still applies.) I had a devil of a time matching that color on the Eduard 190a5 I built a few months ago. In fact, I wasn't able to get it perfect. Again, two gorgeous builds Automaton |
 | Chuck Wojtkiewicz chukw1 | Location: California, United States Member Since: November 28, 2007
Posts: 216 entire network,
206 this site
| Posted: Wednesday, October 07, 2009 - 02:41 PM UTC |
You amaze an delight with every build, Jean Luc- and it's a double header this time! Fascinating commentary about the antennae and colors- I've always been intrigued about the picture taken at dawn or dusk that shows the heavy shadow falling nearly parallel across the airframe- you know the one? Many odd color profiles born from that, I think!
Cheers! chuk |
| [url]http://www.chukw.com[/url] | |  |
Contributing Editor
3,553 this site
| Posted: Wednesday, October 07, 2009 - 06:35 PM UTC |
Hi all, Quoted Text
I think I've found a good color match. On the picture below, the difference seems obvious but in real it is very difficult to see. I don't know why it appears that way on the photo, maybe because of the difference of material?  Chuck, I don't know the picture you are talking about (do you have a link?) but I know of a famous Ju88 photo which lead the Dragon guys to believe the aircraft received a special paint sheme while it was in fact the shadow of the above camouflage netting... Steffen, it seems as if the photo in this thread isn't Migge's aircraft. There are different fuselage and underwing crosses (as Rowan mentionned) and the "Adlerflügel" isn't present on the side. But I've noticed that I've forgot to add one small antenna on the bottom of the rear fuselage and I've also forgot to paint the pitch controller system in alu. Jean-Luc |
3,018 this site
| Posted: Wednesday, October 07, 2009 - 07:06 PM UTC |
Hi Jean-Luc Well, how can you be that sure? have you pictures of Migges aircraft or are you just basing this statement on Eduard instructions? But again: I was not talking about colours this time but only criticised the kit for wrong antenna layout and I stand to that comment. The small stab antena under the rear fuselage is for the IFF FuG 25/FuG 25a (IIRC) all the best Steffen |
Contributing Editor
3,553 this site
| Posted: Wednesday, October 07, 2009 - 08:21 PM UTC |
Hi Steffen, I'm not sure at all!  I wrote "it seems..." I based my comment on the other pictures in the link you've posted earlier. Of course it can be Migge's aircraft at an earlier stage and of course you are right about the antennas... Jean-Luc |
3,018 this site
| Posted: Wednesday, October 07, 2009 - 08:36 PM UTC |
Good morning Jean-Luc I wish i could remember where i had seen the pix of Migges a/c IIRC there were ar least 2 that show the white 9 (and not only the one posted in the link above that does not allow much conclusions .. fuselage crosses and so forth not to be seen). I think "Kognak Y pumpe" was his personal emblem so if we could read the inscription it would help. I do not think you can see if there is an "Adlerflügel" on the pic I posted in this thread because the guys hiding that area .. my quota at kitmaker is almost full so I won't post reworked pix with what I mean .. if you do not get my idea, so be it ... The models are beautifully executed and very fast as our Master of Ceremonies already pointed out.The only thing that got me started was the right wing (seen from pilots seat) antenna mounts that just look strange and made me look for some backup of my "bad feeling" .... If I would have to build oob i would snip a mm of the left wing mounts and add these to the other two ... but IF I ever build this machine i will probably use the Dragon kit with the Eduard markings  .. sometimes it's nice to have a stack ... cheers Steffen BTW I still take wishes for kits that I should bring with me to Merchweiler ... Some decision help can be found here and of course in my Aeroscale Blogs ... |
Contributing Editor
3,553 this site
| Posted: Wednesday, October 07, 2009 - 10:09 PM UTC |
Hi Steffen, Quoted Text
Definitely the He 112, your latest Corsair and the Fokker E.V... Jean-Luc |
 | Jesper SGTJKJ | Location: Kobenhavn, Denmark Member Since: July 20, 2006
Posts: 5,008 entire network,
2,105 this site
| Posted: Thursday, October 08, 2009 - 08:43 PM UTC |
Excellent job, Jean-Luc! Really nice kits which will have to be added to my growing Fw 190 stash. Thanks for the report, Jean-Luc PS. thanks for the picture, Steffen. It was new to me. |
Now working on:
Thunderbolt for Thunderbolt campaign
Campaign'oholic - 69 campaigns so far | |  |
47 this site
| Posted: Tuesday, October 13, 2009 - 07:38 AM UTC |
Jean-Luc
May be.... but I guess they`re more white or grey |
 | Neil Page FalkeEins |  | Location: England - South East, United Kingdom Member Since: March 07, 2005
Posts: 545 entire network,
396 this site
| Posted: Monday, October 19, 2009 - 08:57 PM UTC |
..yes great builds but not Mosquito hunters with those radar aerial arrays. 'Yellow 1' was Bretschneiders a/c when with 6./JG 300 during late 1943, early 1944 (Owl decals got that wrong on their nightfighter sheet....nice to see that Eduard got it right! ) Quoted Text
Jean-Yves Lorant published it way back in 1980 in his book 'Le Focke Wulf 190' - I haven't seen it published anywhere else until now. - there is an entire line-up of FuG equipped 190s with the wilde Sau emblem in one shot in that book too .. quite a rare book nowadays |
 | Hermon VonCuda |  | Location: North Carolina, United States Member Since: November 28, 2005
Posts: 1,050 entire network,
611 this site
| Posted: Thursday, October 22, 2009 - 12:47 PM UTC |
With every kit that I build I think I'm getting better but then I see something like this and realize just how much further I still have to go. This is beautiful work once again Jean-Luc. The paint (as usual) is flawless near as I can tell and the dio is great. Your work, as well as others here at Aeroscale truely inspire me to keep trying harder. Hermon |
I was givin a choice between building models or taking anger management classes.
