| | Rotary WingDiscuss helicopters and other rotary wing aircraft from any era. | | |
| Subject: 1/18 scale Tervamaki Engineering JT-9T gyro | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
Posts: 48 entire network,
47 this site
| | | Posted: Friday, August 14, 2009 - 10:34 AM UTC |
| 1/18 scale Tervamaki Engineering JT-9T autogyro scratchbuildHaving tried my (suicidal) virgin 40 minutes flight experience with a friend's homemade autogyro during my summer holidays with him on flight controls and me on the passenger's backseat, I can surely say that you really feel like a bird, sensing even the slightest airwave or gravity accelerating change straight in your floating stomach. As soon as I safely stepped on solid ground again and returned back home in one piece, I felt the iresistable temptation to try a 1/18 scale autogyro scratchbuild. The following article is to describe step by step the 1/18 scale Tervamaki Engineering JT-9T autogyro, designed by Mr. Jukka Tervamaki and currently flying by ultralight aviators around the world keeping the Mad Max II GyroCaptain's (aka Road Warrior) spirit alive!  The basic JT-9 autogyro concept is about a tractor gyro design with good aesthetics and performance with fairly low power. A 1.7 m diameter 2-blades propeller is powered by HKS 700 or Hexadyne Aviation P60 diesel engines, both delivering about of 65 hp at 2400 rpm. The fuselage of the JT-9 is of normal steel tube construction covered with dacron fabric. On the other hand, the JT-9B model is equipped with an electric motor instead of a diesel engine, with only difference the 3-blades propeller and wider front cover to house the battery packs onto both sides of the fuselage. The model I'll try to build in 1/18 scale, is the JT-9T model, which is the two-seat trainer (as for the "T") model.    Having the basic blueprint line diagrams in hand, it was easy to convert them into 1/18 scale with a photocopier and I began the scale model building, starting from zero using 0.25mm plastic card and plastic sprue. To make the construction look more interesting, I decide to build the model in a way that airframe should look like cutaway side opened and let cockpit detail be easily observed. | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Friday, August 14, 2009 - 10:39 AM UTC |
| CHAPTER I - Basic airframe skeleton construction   Following the 1/18 scale printed diagrams and using just a sharp blade and ZAP superglue, it took about 60 minutes to build the basic airframe skeleton. The tiny gaps between the skeleton connections, were filled with Humbrol modeling putty, applied with an old brush. In order to make the putty liquid and let it spread naturally and fill the tiny gaps, I mixed it with nitro resolvent. Because the nitro resolvent is volatile, the liquid putty mixture took about 45 minutes to get fully dry and be safe to sand - carefully ofcourse. If you follow this method, be sure that you mix the nitro resolvent and the modeling putty into a metal or glass plate / canister, because the most plastic materials cannot stand it and melt. For this reason, keep in mind to use just the essential nitro resolvent quantity, in order to remain the mixture in liquid form, as it is presented at the following pictures.          About 45 minutes after laquer thinner and Humbrol putty liquid mixture applied with brush on the skeleton to fill the tiny gaps between the connections, it looked to be fully dry and safe to sand it. As soon as that was done, the skeleton was hanged by a string and airbrushed with enamel mat white color as a base coat. Cockpit floor, wheels etc made while waiting the putty to dry, were also spayed with base coat.    | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Friday, August 14, 2009 - 10:42 AM UTC |
| CHAPTER II - Diesel engine building & paintingSetting as a task to build the model in a way that airframe look like cutaway side opened with cockpit and engine bay details visible, I should also leave the engine's cover opened. that ofcourse means that a diesel engine building from scratch is something I couldn't easily avoid. Using plastic card, sprue, metal wire and unidentified parts found in the sparebox, here is my effort to build a realistic 1/18 scale engine.           After connecting with superglue the main elements, the electric cables and oil or diesel lines etc on engine's shape, I airbrushed it with enamel mat white color as a base coat, using high air pressure and spraying from distance to develop a pore surface and help silver & aluminum paint establish easier on plastic or metal engine's parts. As soon as the enamel mat white color seemed dry enough, a mixture of silver and aluminum paint sprayed on the engine and let about 24hrs to dry before trying to wash it with darker colors.    As I personally believe that following simple techniques and sometimes unconventional methods, result in superior effects, I usually do not use enamel or acrylic paint to wash, because I feel risky when applying the paint mixture and let it run. I prefer an easier technique that can be undone if the results are poor - that makes it the perfect technique. I use hard chalk pastels to wash (NOT oil pastels). The hard chalk pastels, look like a teacher would use on the blackboard in school. Do not use the soft oil pastels that artist use to draw on paper. The hard chalk pastels are easy to find in a variety of colors into your local art store or maybe Wal-Mart if in US or ASDA if in UK. To do the wash, I use an X-acto knife, a small metal or plastic container, an old brush, dish washing soap and a bit of water. Begin by scraping some chalk powder from the side of the chalk pastel stick, carefully put this chalk powder into the small container and add a tiny amount of water and stir. It is important to add a tiny amount of water in order to make the mixture look like mud - not like soup! For this reason, I use a syringe to add just few drops on the hard chalk pastel powder and I stir using the old brush. Because the chalk powder doesn't mix well with the water, a drop of dish washing soap is needed to break the surface tension of the water and also acts as a "glue" to help the chalk powder stick to the model.      Once the chalk is fully dissolved into the water/soap mixture it is time to "paint" this mixture onto the model's engine. "Painting" the mixture is simple - just apply it anywhere it is needed to darken recessed detail. The mixture can be applied carelessly, because any mistakes can be completely removed and redone. Once the chalk wash dried, I rubbed off the high spots with a slightly damp dry (not wet) Q-Tip cotton swab (Kleenex papers can be also used) and I wiped the dark color from the areas should be light & shinny. The high spots were cleaned to the SNJ bare metal finish and the low spots were left black. I did the chalk wash on the engine in under 30 minutes which makes it a very quick and effective technique. You can also read about this into Steve Bamford's article, by clicking HERE.       Some of the wash mixture is re-applied and the wash being wiped completely out of the narrow points. If you follow this method, it is adviced to not rinse out the wash container till you are finished this job. You will probably be touching up certain spots a few times, so it helps if you're not mixing up a new chalk mixture each time because you kept cleaning out your container of the chalk wash mixture. As soon as I paint the electric cables, the oil or diesel lines etc, I repeated the the wash process with lighter colors where needed. Using micro cotton batons found into cosmetic shop for less than 1£, I applied some red, orange, purple & brown chalk pastel powder on the engine's chrome excaust, to make it look overheated. I repeated the weathering process until it satisfied me and finally I sprayed a clear coat to seal the chalk powder on the engine.    The scale model building, cost me almost nothing and took about 2 evenings work so far . | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Friday, August 14, 2009 - 10:46 AM UTC |
| | | | HIDE SIGNATURE AREAS |  |  | Ben Micklem robot_ |  | Location: No Regional Selected, United Kingdom Member Since: March 08, 2009
Posts: 219 entire network,
212 this site
| | | Posted: Tuesday, August 18, 2009 - 08:38 PM UTC |
| Nick- A very interesting thread- your engine looks fantastic. Very envious of your modelling room. Looking forward to seeing the gyro finished. | | HIDE SIGNATURE AREAS |  |  | Klaus Pagano Avus | Location: Roma, Italy Member Since: March 10, 2006
Posts: 281 entire network,
93 this site
| | | Posted: Wednesday, August 19, 2009 - 05:56 PM UTC |
| A M A Z I N G !
The whole thing looks great but so far the engine is simply ... how can I say ... perfect! | Klaus
Don't worry about the world coming to an end today. It is already tomorrow in Australia. (C.Schulz)
Flying is learning how to throw yourself at the ground and miss. (D.Adams) | |  |
| | HIDE SIGNATURE AREAS |  |  | Jean-Luc Formery TedMamere
Contributing Editor
Posts: 4,843 entire network,
3,552 this site
| | | Posted: Wednesday, August 19, 2009 - 06:18 PM UTC |
| Hi Nick, Fantastic work so far and very informative. I've learned quite a lot so far! Keep posting please... Jean-Luc | Better think one hour and build five minutes...
Than think five minutes and build an hour! | |  |
47 this site
| | | Posted: Sunday, August 30, 2009 - 02:16 PM UTC |
| CHAPTER III – Instrument panel & cockpit constructionThe original Tervamaki Engineering JT-9T autogyro instrument panel is not what you would call as "glass cockpit". Actually it does only have just the basic instruments in cockpit to provide the pilot with information about the flight situation, such as height, speed and attitude. Since the JT-8T autogyro is not designed to fly in conditions of poor visibility or night, the main information is available from visual reference outside the aircraft. Of course, many pilots who are lucky enough to own an autogyro, they might add more sophisticated equipment such as CFT screens, HSI - Horizontal Situation Indicator to follow VOR signals, GPS screens, VHF/UHF radio, replace the heading indicator by a GPS-driven computer with wind and glide data etc. The basic instrument panel is consist by: I started by cutting the main panel shape in plastic and drilled the gauges positions. Using the Corel Photo Paint, I created a colored sketch of the instruments, copy & paste the image into a MS Word new file and print it on a simple A4 page. Meanwhile, I add some detail on the instrument panel, such as rivets made by streached sprue inserted in drilled out holes, knobs etc.        | | | HIDE SIGNATURE AREAS |  |  | Ben Micklem robot_ |  | Location: No Regional Selected, United Kingdom Member Since: March 08, 2009
212 this site
| | | Posted: Tuesday, September 01, 2009 - 06:54 PM UTC |
| Those instruments look super! And the panel with the rivets too. | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Friday, September 04, 2009 - 01:46 PM UTC |
| Using styrene plastic card, I cut the basic lines to form into the two simple seats. The dimensions are based on the basic 1/18 scale JT-9T two-seat trainer blueprint line diagram as seen HERE. On the real JT-9T autogyro, these simple seats are made of hard plastic, fiberglass or even wood sheet and buckram covered home made pillows are placed to provide comfort. These seats are fixed on metal rails, running across the cockpit floor connected with main skeleton, to ensure seat's secure installation.   For many years, I was used to form aircraft seat pillows with Milliput epoxy putty, which is popular among modelers and also useful in countless household & restoration applications. But, while I was in a supermarket last week, I found the following item and I thought that it could be nice to try it and start experiment with this material. It's an air-drying modeling clay ideal for scale modeling and shaping. According to the instructions, it can be easily formed into shape, become solid rock withing few hours, re-filled or sanded if neccessary and painted or lacquered. That sound quite good to me and similar to the well known Milliput epoxy putty, with the only difference that the 500g air-drying modeling clay pack cost only 1£, instead of 100g Milliput epoxy putty which cost 5£. That makes the new found air-drying modeling clay, about 25 times cheaper than Milliput epoxy putty and that's a good reason for me to give it a chance.   Grabbing a small quantity with a metal spatula and applying the air-drying modeling clay on the seats, it felt too soft and very easy to spread the material nicely to simulate pillows realistic way. I didn't want to care too much and try forming and shaping the clay, because I was planing to cover the sculpted pillows with wet soft paper to simulate the buckram covered pillows. After all, I had no idea how much available time I had, before the material start becoming hard and difficult to handle.     | | | HIDE SIGNATURE AREAS |  | |
|  | Rowan Baylis Merlin
Managing Editor
|  | Location: No Regional Selected, United Kingdom Member Since: June 11, 2003
Posts: 9,569 entire network,
6,033 this site
| | | Posted: Saturday, September 05, 2009 - 03:47 AM UTC |
| Hi Nick Simply fantastic work! There's so much to learn from at every stage - it's a real inspiration. I can't wait to see it finished. Let's get it onto the front page then as a Feature. All the best Rowan | (formerly "Porky")
BEWARE OF THE FEW...
As I grow older , I regret to say that a detestable habit of thinking seems to be getting a hold of me. - H. Rider Haggard | |  |
47 this site
| | | Posted: Tuesday, September 15, 2009 - 12:28 PM UTC |
| | | | HIDE SIGNATURE AREAS |  |  | Bryan Dewberry Tin_Can
News Writer
| Location: Florida, United States Member Since: January 26, 2002
Posts: 1,505 entire network,
697 this site
| | | Posted: Wednesday, September 16, 2009 - 01:23 AM UTC |
| Just seeing your work for the fist time and am totally blown away. I especially like the way you used the solder on the engine to represent the cooling fins. Ingenious. I've used TP once before too on a tank project where I used it to make some rolled up canvas and as a the cover between the gun and turret.
Again, very nice work. | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Wednesday, September 23, 2009 - 10:31 AM UTC |
| CHAPTER IV - Right side fuselage constructionAs I said at the beginning of this thread, I decide to make the JT-9T building look more interesting and show the model in a way that airframe should look like cutaway side opened and let cockpit detail be easily observed. THIS artistic diagram gave me the idea and that would be a nice opportunity to present my way to do it. To do so, I decide that a solid rock one-piece "negative image" cast of the right side fuselage should be made of plaster first and then build a right side solid replica made of polyester, epoxy or resin. This replica - virtual fuselage, would be the basic line to create a thin right-to-scale fuselage surface. My local newsagent, usually wraps my newspaper and magazines into a plastic bag, which sometimes I use to collect the trash. This time, I decide to use the plastic bag in a completely different way. I cut free-hand few pieces of plastic, keeping in mind to make them longer & wider than the autogyro scale model dimensions. Using duct tape, I stretched the plastic bag across the airframe, in a way to simulate the full right side and half bottom fuselage surface, trying not to leave any visual wrinkles or marks.         I add some grams of plaster powder and few drops of water with a syringe into a soft rubber cup to make the right mixture. Materials like plaster, start as a dry powder that is mixed with water to form a paste which liberates heat and then hardens. Unlike mortar and cement, plaster remains quite soft after drying and this characteristic make plaster suitable for the job. Keep in mind that adding salt into wet plaster mixture, reduce the plaster's hardening time and adding vinegar into wet plaster mixture, extend the plaster's hardening time. When the first layer of thinned plaster applied on the plastic bag was dry and hard enough, a second thin layer of plaster was applied to form a basic strong cast. The basic idea, is to let the plaster follow the airframe details, accurate on scale and as thin as possible trying not to apply extra stuff where is no needed.        Found at my local supermarket and got for only 0.5€, the following modeling clay for kids. Some scale modelers, use this material to border camouflage patterns while airbrushing. I pick a piece, mold it into snake alike formation and placed it across the airframe to border the wet plaster flow - yellow color for up and purple color for bottom airframe side.         When I finally enclosed the right half JT-9T scale model into plaster, I left it few hours to get harden in order to be sure that the cast wouldn't break when I would try to remove the scale model from inside. Meanwhile, I took the soft rubber cup which I used to make the plaster mixture, squized it to break the last hardened plaster left inside, so it would be easier for me to clean it afterwards and prepare it for any future mix. That's the reason this soft rubber cup were used for.   As soon as the plaster cast was dry and hardened, I removed the the modeling clay I used for bordering the plaster flow and pull the enclosed JT-9T scale model airframe away, gently. Brushing the area with an old tooth brush, I removed unwanted dust or small broken plaster pieces.      Johnson's baby oil or similar is well know to anybody who have children in house. If you don't have children yet, ask your girlfriend - all girlfriends have a tiny bottle in their cosmetics drawer. If you don't have a girlfriend, close this web page, shut down your PC/laptop and get your feet out of house to meet one! Scale modeling is nice, but feeling a nice female next to you is much better. Continuing with the project, thin layers of vaseline based mixtures can be also used instead of baby oil to apply with a soft brush as a segregative material between the plaster cast and generous quantities of polyester filler applied on the plaster cast.     | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Wednesday, September 23, 2009 - 10:35 AM UTC |
| The specific polyester filler I used, comes with the proper catalyst which provides a solid rock build and approximately 3 to 5 minutes time window to form it into shape. I prefer to use epoxy putty or polyester filler with fiberglass grains for special purposes, because: - It becomes solid rock within only few minutes or seconds,
- it does not shrink and does not crack after months or years,
- you can pour to any shape that you want but you need to work fast because as soon as you mix it with catalyst cream approx 5%, you have limited time before becoming solid rock,
- you can also put additional layers of epoxy or polyester filler to build up,
- you can sand it, you can drill it, you can use any type of scale modeling glue, any type of primer or enamel / acrylic paint on it with no problem,
- can be purchased at any good crafts store into 250ml, 500ml, 1lt (comes with a tube of catalyst hardener) or bigger canisters and if you can't find it, fear not and try your local decent hardware store and finally...
- it is cheaper than dirt - estimated prices are £3 to £10 depending the canister size, the quality, if contains fiberglass grains for maximum strenght etc.
Keep in mind that the chemical reaction after mixing the polyester filler with the catalyst hardener, produces some heat that possibly effect on thin plastic parts, so test it first before try it on your scale model. I don’t think that the produced heat is more than Fahrenheit 110, but better watchout. Remember that epoxy materials are dangerous when breath or shallow and could result skin, eyes or lungs problems or even cancer when used for long period with no precaution measures. Always keep in mind, that a powerful vacuum system to suck away the epoxy dust should be used all time to keep the workbench area clean while sanding or milling epoxy or resin materials. Using an issued breathing mask and a pair of surgery latex gloves to prevent dust contact with lungs and fingers while sanding or milling epoxy, is also an important matter that you should seriously take care of! My recommendation is to also wear an overall working suit (as I do) to keep your clothes dust free while sanding epoxy. Some people might find it too much, but I wouldn't like to bring epoxy dust & grains from my work bench into living room and my beloved. When the plaster cast used as a "negative image" of the right side fuselage, was filled with a thick layer of polyester filler and had enough time to polymerize and get solid rock, it was sunk into water and stayed wet for few minutes, in order to get moistened, become soft and let the right side fuselage replica made of polyester be removed easily.     …if you still read this, you are a father already or have a girlfriend  To produce a thin-skinned right side fuselage, the polyester part, must be vacuum formed. That means, that I should build from the beginning a new vacuum chamber box. Vacuum forming is a very simple technique that can produce thin-skinned parts of various forms. I mainly used vacuum forming for producing a variety of components for scale modeling. Basically, it’s all about a box with a connection for your household vacuum cleaner and a series of holes in its top plate and try keeping the box airtight at the seems. The basic idea is to build from scratch or buy one if you find something similar, a wooden box like the one I present. I found the following item (which supposed to be a display box or something, for placing plants, colored sand & stuff inside and make them look nice as a decoration on the wall) at my local IKEA. Looking exactly like what I've been searching for and considering the low price (not more that 5€), I preferred to buy it instead of building a new wooden box like this from scratch. As you can see at the following pictures, I removed the glass, applied a generous layer of water based white glue for wood (which becomes transparent when it dries) across the inner joints, to keep them as air tight as practical and be sure that no air could escape from there.       Visiting my local Dexion store (shelving & racking solutions), I got a 135x85cm hardboard sheet (more than 1 square meter area) for 8€. This is actually a louvred panel, designed to stand against the wall and accept hooks & spigots for easy storage of everything from belts and hose clips to spools and reels and all kinds of other parts. I cut a piece on the right dimensions and slide it into rail to test the fitting. The 35x25cm top plate has many 4mm wide holes to allow air to be pulled through them. The locations of the holes are not important, and can be also drilled by hand using a hand held drill. Just make sure that they are fairly close together. This top plate should be pretty sturdy to hold the subject being duplicated. I made mine from hardboard high-density fibreboard plate, but I have seen them made out of aluminum too. The top plate finally was slided into inner rails - otherwise it would be screwed down with flat head wood screws. Be sure to countersink the holes to make the heads flush with the top surface. I also epoxied it down, just to also make it a little more air tight. As long as 1 square meter area hardboard plate, is more than enough for me and can be used to build more than 5 or 6 vacuum forming device plates, I gave the rest to other fellow modelers who are also interested to build one.     | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Thursday, September 24, 2009 - 07:54 AM UTC |
| Using the proper Black & Decker saw tool, a 34mm wide hole was drilled through the side of the box to facilitate a vacuum cleaner fitting. Luckily, last week I found a real bargain at the local Media Markt store and I bought a 1600W brand new Hyundai HVC-6003 vacuum cleaner for 15€ only. I decide to use in this vacuum cleaner into my hobby room and for vacuum forming purposes only. I cut a plastic tube - you may have an old piece of an old tool laying around the house or you can purchase one at a vacuum cleaner shop - and fix it with Bison glue for PVC on the box. Then, I screw a wooden stick into the box's center to prevent any possible hardboard plate bending because of vacuum and finally slide the high-density fibreboard plate through the rails to close the box. I sealed everything with white water based glue for wood. The following pictures show the vacuum chamber box building progress and where you will plug in your household vacuum cleaner.       I also got few wooden picture frames found at the local IKEA store for only 1€ to 3€ each (depending size) and few metal made spring clamps for 0.5€ each, to use them for steady & tight styrene sheet holding while being heated. Avoid plastic clamps, because they might melt while in the oven. It's also possible to build clamping plates made by aluminum sheet and the two plates are clamped together using screws and wing nuts. Aluminum clamping plates is better but might cost more. For these, you are only limited by the size of the oven you have.     Heat your electric oven to some predetermined level, whatever works and start heating the plastic sheet. I have never tried this with a gas one, so use caution if you do! Once the plastic gets warm, you’ll notice it will droop down. When you think the plastic is soft enough, fire up the vacuum cleaner, take the plastic from the oven and thrown the sheet on the vacuum former. The plastic will nicely form around the moulds. This will take some practice and sometimes a mould tips over or the plastic won’t form properly over the mould (folding around edges). This is also the part where I should warm you that you can burn your fingers - I highly recommend Nomex Aramid flame resistant MilSpec gloves, which I personally use for the job. I buy large plastic styrene 50x30cm sheets for 0.5€ to 1.5€ each (depending width), not the more expensive styrene by Evergreen. When an attempt fails, I usually throw the sheet back in the oven and start again. I’ve included some pictures above, but remember, this description of how to make a vacuum form is only a guide. You can make yours with many variations to suit your own needs and from various materials. Once you have the machine, you can make all kinds of things. You can make a lot of aircraft wings, airframe, panels etc out of a sheet like that. You can make the master molds from basswood, epoxy, polyester etc and the parts you make depend on how accurate the master molds are. The molds must be as accurate and detailed as necessary to achieve the results you are after. | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Friday, September 25, 2009 - 05:36 PM UTC |
| I thought as good idea to try something different this time and I did not use the metal made spring clamps to hold steady & tight the styrene sheet on the wooden frame and experiment with thumbtacks. I placed the frame into the preheated electric oven and I wait few critical seconds watching the plastic start heating. As soon as I noticed that it started drooping down, I removed the frame while wearing Nomex Aramid flame resistant MilSpec gloves, to prevent finger burns. While the vacuum cleaner was already switched on, I placed the wooden frame with the pined plastic sheet on the vacuum former plate. The plastic nicely formed around the “virtual” airframe mould... and voila!     Note: If I leave the styrene plastic sheet in the electric oven a few more seconds and the plastic was softened further, I would avoid the shrinkage of the plastic that appears in the lower right corner of the original cast. The fact that the plastic could heat up even more, evidenced by the fact that one or two thumbtacks were pulled. But as long as my point of interest (the whole right side of the fuselage and a bit from the bottom side) formed nicely around the mould, the result fully satisfied me and I didn’t try a new vacuum forming. | | | HIDE SIGNATURE AREAS |  |  | Nick Zourbakis NickZour | Location: Attica, Greece / Ελλάδα Member Since: May 01, 2008
Posts: 358 entire network,
195 this site
| | | Posted: Friday, September 25, 2009 - 07:03 PM UTC |
| | All Weather Modeller!!!!!
The Beatles for ever & Ever!!!
__________________
BIRTH DATE:
22/11/1995
47 this site
| | | Posted: Sunday, September 27, 2009 - 08:49 AM UTC |
47 this site
| | | Posted: Wednesday, September 30, 2009 - 11:43 AM UTC |
| Do you remember the wooden picture frames I found at the local IKEA store for only 1€ each, securing the styrene plastic sheet to be vacuum formed? I kept these thin plexiglas plates, to use them as required. Continuing the cockpit construction, I had to build the rear cockpit cover, so I placed the autogyro model upside down facing a glass surface, I boxed it by placing the thin plexiglas plates around it, securing in place with modeling clay for kids. Then, I removed the scale model carefully, leaving space between these thin plexiglas plates. Wet white plaster mixture, applied into the gap, between the thin plexiglas plates to fill the area. When the first layer of thinned plaster was dry and hard enough, two or three extra layers of white plaster followed to finally build the basic cast. Keep in mind that adding salt into wet plaster mixture, reduce the plaster's hardening time and adding vinegar into wet plaster mixture, extend the plaster's hardening time.         When the plaster cast was dry and hardened after few hours, I removed the modeling clay for kids and the thin plexiglas plates. The white plaster cast got shaped into proper dimensions but cutting it with saw, filling with tiny quantities of modeling putty added to close minor scratches and pores on white plaster cast surface, dry sanded and finally sprayed overall with gloss shiny coat.      | | | HIDE SIGNATURE AREAS |  | |
47 this site
| | | Posted: Wednesday, September 30, 2009 - 11:44 AM UTC |
47 this site
| | | Posted: Sunday, October 04, 2009 - 12:21 PM UTC |
| I placed the rear cockpit’s cover in place and secure it with just one or two drops of cyanoacrylate super glue. Then, using a small pencil, I defined the exact line that the rear cockpit cover should be cut in order to let the inside structure visible. Using the mini Dremel tool, I cut and removed the left half part, in a way to look kind artistic.   | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Sunday, October 04, 2009 - 12:23 PM UTC |
47 this site
| | | Posted: Sunday, October 04, 2009 - 12:24 PM UTC |
| Few hours later, soft sanding and a quick airbrushing with white color to make mistakes, scratches etc become easy to spot, the rear cockpit cover was finally ready.  | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Sunday, October 04, 2009 - 12:25 PM UTC |
47 this site
| | | Posted: Monday, October 12, 2009 - 11:21 AM UTC |
| | | | HIDE SIGNATURE AREAS |  |  | Tony Swärdh LongKnife | Location: Jönköping, Sweden Member Since: April 25, 2006
Posts: 807 entire network,
664 this site
| | | Posted: Tuesday, October 13, 2009 - 05:07 AM UTC |
| Well Nick. This far into the build I have only one comment. McGyver walks the earth - and he builds models! Wonderful use of nothing to create something. I'm just waiting to see how you will create the underpants on your pilot figure  Tony | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Wednesday, October 14, 2009 - 01:40 PM UTC |
| CHAPTER VI - Landing gear system constructionThe single seat JT-9 and the tandem seating JT-9T, are available with tricycle landing gear system with a steerable nose wheel or a taildragger version too. For both types, the type of landing gear is based on the placement of the exact CG position, determined after complete weight calculations according the owner/pilot's personal needs. My 1/18 scale model is designed to be equiped with a tricycle landing gear system with a steerable nose wheel. An utillity free-spinning tail wheel is also placed, to prevent any accidental damage on tail structure if the autogyro raise nose too high while in ground. Feel free to check the diagrams and images found into my first post of this project, back in page 1. Using plastic card, sprue, metal wire, resin tires and brakes fit accurately to 1/18 scale diagrams and few unidentified parts found in the sparebox, I build a realistic looking 1/18 scale main landing gear system with absorbers and a steerable nose gear. I stole a nickel plated button from GF's favorite dress (hope she'll never find out where's the missing button or I'm in real trouble), placed it into a plastic tube piece, covered with with transparent plastic card & add some details to simulate the landing light in scale.           Yeah, yeah, yeah... I know! I am a button stealer, but let's admit it! We all prefer less buttons on female dresses.  | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Thursday, October 15, 2009 - 08:02 AM UTC |
| CHAPTER VII - Canopy constructionThe Tervamaki Engineering JT-9T autogyro canopy is made by bented and cold-formed 3mm polycarbonate sheet. The backwards sliding canopy of the single seat JT-9 version, offers the possibility to taxi and fly slowly with the canopy open, a benefit in a hot climate. The trainer / tandem seating JT-9T, has a side opening one piece canopy. Of course, canopy modifications can be done, according the autogyro owner's personal needs or desires.     I used styrene plastic card to form it as shown into following pictures to give the basic shape of the canopy. Then, a layer of polyester filler applied on the styrene. The specific polyester filler I used, comes with the proper catalyst which provides a solid rock build and approximately 3 to 5 minutes time window to form it into shape. I prefer to use epoxy putty or polyester filler with fiberglass grains for special purposes, because:
Keep in mind that the chemical reaction after mixing the polyester filler with the catalyst hardener, produces some heat that possibly effect on thin plastic parts, so test it first before try it on your scale model. I don’t think that the produced heat is more than Fahrenheit 110, but better watchout. Remember that epoxy materials are dangerous when breath or shallow and could result skin, eyes or lungs problems or even cancer when used for long period with no precaution measures. Always keep in mind, that a powerful vacuum system to suck away the epoxy dust should be used all time to keep the workbench area clean while sanding or milling epoxy or resin materials. Using an issued breathing mask and a pair of surgery latex gloves to prevent dust contact with lungs and fingers while sanding or milling epoxy, is also an important matter that you should seriously take care of! My recommendation is to also wear an overall working suit (as I do) to keep your clothes dust free while sanding epoxy. Some people might find it too much, but I wouldn't like to bring epoxy dust & grains from my work bench into living room and my beloved. When the basic canopy shape made by styrene sheet, was fully covered by a a thin layer of polyester filler and had enough time to polymerize and get solid rock, I sand it with wet sandpaper to make the cast curved and shiny. To produce a thin-skinned canopy, the polyester part should be vacuum formed. As described into previous chapters, a transparent plastic sheet were pined on a wooden frame, preheated into electric oven and as soon as I noticed that it started drooping down, I vacuum formed it. The clear plastic nicely formed around the canopy cast following the curves & details as planed. Using an X-acto, I removed the formed canopy buble from the transparent sheet and start adding details, such as canopy's frame. Few drops of cyanoacrylate glue applied on the right spots with great caution. Remember that CA glue does fog the transparent parts and this canopy would not be an exception - that's why I placed some very tiny drops of it, just on few spots.        | | | HIDE SIGNATURE AREAS |  | | Nick Karatzides Nick_Karatzides | Location: Thessaloniki, Greece / Ελλάδα Member Since: May 22, 2009
47 this site
| | | Posted: Wednesday, October 28, 2009 - 03:49 AM UTC |
| It’s sad! Obviously, voodoo curses came from the unspeakable dirty Viper snake, got real and the final varnish finishes on the model suffered what the Americans call as FUBAR - F@cked Up Beyond All Recognition.  In brief words, the color layers popped and “cracked” everywhere on the model’s surface, just before the final touch. For some mysterious reason, the color looked peeled off and an unexpected chipping (I would never succeed this by purpose) appeared! The scale modeling accidents committee is expected to investigate the possible reasons within following days, but unconfirmed sources report "pilot’s error" - OK, I made a rookie’s mistake, while using old colors or coat varnish. Meanwhile, the following actions took place: - Garlic cloves were hanged across the workbench to keep away evil curses, vampires and “snakes” (or those who claim themselves as “snakes”),
- The scale model were covered with a thick layer of ModelStrip product, locked tightly in a plastic bag and left overnight to let the chemical work.
