Pre-Flight Check
Printable Concrete Base 1/48 scale
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Friday, March 27, 2009 - 04:43 PM UTC
Inspired by the "Printable modern aircraft carrier deck" on the ARC Diorama Forum.
I'm working on a concrete version (tarmac). Each square tile is 4.625" which I think scales out to around 20 ft @ 1/48 scale. Any suggestions on: airfield markings (with a diagram and/or ref photos), manhole covers, drains, etc.. is much appreciated.
I'm building the PhotoShop file in layers, so that I can go from a clean concrete base to a dirty (abandoned) field—and anywhere in between. I'll post a few progress pics. This printable base is designed to be modular, so that you can cut the tiles apart as needed to fit your layout (and put in grass sections, etc).
Right now the PhotoShop file is being built (16 squares) to measure 18.5" x 18.5" @ 250 dpi.
Thanks for looking,
Posted: Monday, March 30, 2009 - 12:53 AM UTC
Hi Mike
That's a very neat idea indeed! I'm looking forward to seeing how it turns out.
drabslab
KitMaker: 2,186 posts
AeroScale: 1,587 posts
Posted: Wednesday, April 01, 2009 - 05:06 AM UTC
This is one very very very very very very good idea.
The only remark that I have is that all the concrete slabs that I have seen on airfields (at least when I was paying attention) were 6 meters by 3 meters.
Otherwise, i think that 300dpi is somewhat standard these days (or have i lost touch with printing reality?)
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Wednesday, April 01, 2009 - 10:43 AM UTC
Thanks for the feedback. I'll do a version that's 6 meters x 3 meters as well. I like the look of the square tiles though (as seen in Verlinden books).
And yes, 300 dpi is standard for printing. I'll res up the final jpeg version to 300 dpi. The files get to be very large (very quickly) when doing high res layers in PhotoShop, so every little bit I can save up front really helps.
drabslab
Posted: Thursday, April 02, 2009 - 01:12 AM UTC
What about publishing the individual layers in seperate files in photoshop format (the extension escapes me)
Someone with some photoshop knowledge could then combine whatever. This way the difference between a square and a 3*6 dimension would come down to activating another layer
Maybe you could publish the final result as a feature? Forum posts tend to get lost in the mass of posts created.
I think that i have some pictures and other data of typical airfield markings. I'll search these and send them to you if this can help?
Again, this is a really splendid idea. I could kick myself for not having thought about this myself
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Thursday, April 02, 2009 - 11:47 AM UTC
Great. I'd really appreciate the pics of airfield markings. The 3m x 6m version is coming along.
stonar
KitMaker: 337 posts
AeroScale: 309 posts
Posted: Thursday, April 02, 2009 - 09:25 PM UTC
This looks like a great idea. I've had a look at any concrete pics I can find and they all seem to be about 3m square.
Completely unscientific ,but if the aircraft below is 35' long (give or take a few inches) then the slabs are about 10' square!
BTW I haven't got a single picture with any markings visible - sorry.
Steve
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Friday, April 03, 2009 - 04:23 AM UTC
Thanks Steve. I'll modify the squares version to 10' (instead of 20'). All the help is appreciated.
Tomcat31
#042
KitMaker: 2,828 posts
AeroScale: 1,720 posts
Posted: Friday, April 03, 2009 - 07:51 AM UTC
All I can say is WOW.
I wish I could be as talented in photoshop as you as these would be great for some of my bases.
I agree with the idea of making a feature of how to do it.
Removed by original poster on 04/27/09 - 17:34:59 (GMT).
drabslab
Posted: Tuesday, April 07, 2009 - 09:22 PM UTC
Do you have this already?
"ETL 04-2 Standard Airfield Pavement Marking Schemes , with Change 1"
Just copy and paste the above line in google. It leads to the NATO airfield markings standard. I do however not have the impression that this standard is very closely followed.
I see on many airfields that the yellow (or white) line is painted in the middle of a (3 times larger) black line which makes the yellow stand out more.
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Monday, April 27, 2009 - 06:38 AM UTC
I've posted the high res files here: http://www.4shared.com/dir/14896314/608bc0dd/Tarmac.html
Each opened jpg file is about 29 MB, 11"x17" @ 300dpi in CMYK.
Enjoy,
TacFireGuru
KitMaker: 3,770 posts
AeroScale: 201 posts
Posted: Monday, April 27, 2009 - 07:27 AM UTC
Michael,
NICE!
Thank you.
amegan
#243
KitMaker: 996 posts
AeroScale: 915 posts
Posted: Monday, April 27, 2009 - 10:40 AM UTC
Neat idea!
I fly from RAF Topcliffe every week but never looked at the concrete. As you can see from the above the slabs are about 10ft x 20ft (Topcliffe was paved in 1942 or 43). The taxiway marking are yellow and I have not seen black edges on a RAF field. Parking locations are marked in white lettering (you can just see a "R" under the Vigi. Taxiways are paved in tarmac with yellow centrelines and dashed yellow lines down the sides. Taxiways are terminated at runways by double yellow lines.
CMOT70
KitMaker: 629 posts
AeroScale: 539 posts
Posted: Monday, April 27, 2009 - 11:23 AM UTC
These are great! Will look great mounted to bases for taking pics.
Thanks Michael
Andrew
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Tuesday, April 28, 2009 - 07:09 AM UTC
I'm working on the 1/32 version now. I'll have to make A and B sides, so you can tile the sections to print out on 11"x17". Or you can use them individually.
drabslab
Posted: Wednesday, April 29, 2009 - 12:39 AM UTC
supergreat stuff !!!
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Wednesday, April 29, 2009 - 03:04 PM UTC
Thank you. Here are a few more: http://www.4shared.com/dir/14896314/608bc0dd/Tarmac.html
Posted: Friday, May 01, 2009 - 01:00 AM UTC
Looks great, Michael.
Thanks a lot for sharing your great work.
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Sunday, May 03, 2009 - 01:34 PM UTC
Two last files at 1/48 scale. http://www.4shared.com/dir/14896314/608bc0dd/Tarmac.html
Posted: Sunday, May 03, 2009 - 06:57 PM UTC
Hi Michael
Fantastic stuff! I'll echo what the others have said - thank you for sharing all your hard work!
kenner
KitMaker: 122 posts
AeroScale: 119 posts
Posted: Monday, May 04, 2009 - 05:30 AM UTC
Yes indeed, very much appreciated!
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Monday, May 04, 2009 - 04:09 PM UTC
Thank you. I'm working on a 1/32 tarmac now. I also owe another ARC buddy some Soviet Slabs @ 1/48. According to Marcus on ARC if you scale these files to 66% you should have them in 1/72.
Send me an email if you need anything specific, or if my markings (or scale) are off.
Thanks,
Posted: Thursday, May 07, 2009 - 03:33 AM UTC
Hi Michael
I was going to suggest some Soviet-style hexagonal slabs too, but I didn't want to distract you from your primary focus. I'll defintely be keen to the result when you have them ready.
mgrandison
KitMaker: 34 posts
AeroScale: 31 posts
Posted: Thursday, May 07, 2009 - 06:15 AM UTC
Hi Rowan,
Can you send me some reference for the hexagonal Soviet slabs?
The only measurements I have are for rectangular shaped sections.
Thanks,
