Scale Modeling Sponsors
See Your Ad Here!
General Aircraft
Hosted by Kevin Brant
Aircraft Trivia Quiz 2 (Join In)
rdt1953
KitMaker: 909 posts
AeroScale: 805 posts
Posted: Thursday, September 07, 2017 - 11:10 AM GMT+7
Spring-loaded tabs?
You are on the right path - there is " springiness" involved but not springs in the conventional sense-
MJWard
KitMaker: 39 posts
AeroScale: 32 posts
Posted: Thursday, September 07, 2017 - 10:38 PM GMT+7
Not Spring loaded, but servo tabs ?
Best
Matthew
rdt1953
KitMaker: 909 posts
Posted: Thursday, September 07, 2017 - 10:52 PM GMT+7
I believe tabs act for fine trim and in some applications act as force balances.
What I am looking for is Horikoshi's elegantly simple ( in concept at least - execution may have been not so easy) system for progressively changing the ratio of control input to control surface movement as airspeed increased.
brandydoguk
England - North, United Kingdom
KitMaker: 1,488 posts
AeroScale: 640 posts
Posted: Friday, September 08, 2017 - 02:46 AM GMT+7
Did he use control cables that had some elasticity in them?
rdt1953
KitMaker: 909 posts
Posted: Friday, September 08, 2017 - 10:35 AM GMT+7
Hi Martin - You ,sir are the winner ! The control cables were reduced in diameter and some other components i ( likely belcranks, control arms ,etc ) had their mass pared away so all were stiff enough to produce full range of control surface movement at lower speeds but stretched/ deflected progressively as speeds and the attendant loads on the control surfaces increased . The net effect was progressive reduction in control surface movement relative to control ( stick) input.
While there were two fatal crashes of the Zero prototypes during initial testing- the first due to the failure of the elevator mass balance and the second due to aileron flutter traced to aileron force balance tabs - there was never any failure of the elastic linkages of the control systems in the service life of the aircraft .
Over to you Martin !
brandydoguk
Posted: Friday, September 08, 2017 - 07:08 PM GMT+7
Thanks Richard, that took some finding.
In WW2 the US Army Air Force conducted a study aimed at reducing losses in combat. They recorded the battle damage on returning aircraft and looked at where they were most frequently hit, the idea being to increase protection to those areas.
What was the basic flaw in this approach?
2002hummer
#257
KitMaker: 629 posts
AeroScale: 362 posts
Posted: Saturday, September 09, 2017 - 03:26 AM GMT+7
Adding extra weight due to the reinforcement called for in the study.
brandydoguk
Posted: Saturday, September 09, 2017 - 03:52 AM GMT+7
Sorry Darrell, that's not it.
KitMaker: 6,576 posts
AeroScale: 5,874 posts
Posted: Saturday, September 09, 2017 - 04:26 AM GMT+7
Those aircraft were the ones which returned, so by definition weren't hit in the most vulnerable areas. The ones that were didn't come back.
brandydoguk
Posted: Saturday, September 09, 2017 - 10:26 AM GMT+7
That's right Jessica, it was eventually realised that the damaged areas on returning planes showed these areas had adequate strength. Therefore it must be the other areas on the aircraft that were vulnerable.
Over to you.
Posted: Saturday, September 09, 2017 - 11:19 AM GMT+7
When last we tuned in, I asked about the Kármán line. Now another altitude-related question:
What is the significance of the Armstrong Line?
2002hummer
#257
KitMaker: 629 posts
Posted: Saturday, September 09, 2017 - 11:52 AM GMT+7
An altitude that atmospheric pressure allows water to boil at 98.6 deg Fahrenheit or 37 deg Celsius.
Posted: Saturday, September 09, 2017 - 01:06 PM GMT+7
Yes, which means...
rdt1953
KitMaker: 909 posts
Posted: Saturday, September 09, 2017 - 02:22 PM GMT+7
Yes, which means...
The water in your body will boil ? Yikes !
Posted: Sunday, September 10, 2017 - 12:46 AM GMT+7
Yes, which means...
And the implications for a pilot are...
brandydoguk
Posted: Sunday, September 10, 2017 - 01:08 AM GMT+7
Yes, which means...
He turns on the air con..............Sorry, couldn't resist
Posted: Tuesday, September 12, 2017 - 12:24 AM GMT+7
You're more nearly correct than you may think, for certain values of "air conditioning"
2002hummer
#257
KitMaker: 629 posts
Posted: Tuesday, September 12, 2017 - 03:01 AM GMT+7
Water on the body surface will boil off, drying the skin. The air conditioning would be a suit that controls the humidity to keep the body surface(skin) from drying out.
rdt1953
KitMaker: 909 posts
Posted: Tuesday, September 12, 2017 - 03:40 AM GMT+7
The " air conditioning" would be " air pressure" - in that atmosphere the pilot would need a pressure suit to survive.
Posted: Tuesday, September 12, 2017 - 10:19 AM GMT+7
The " air conditioning" would be "air pressure" - in that atmosphere the pilot would need a pressure suit to survive.
DING DING DING! We have a winner!
rdt1953
KitMaker: 909 posts
Posted: Tuesday, September 12, 2017 - 10:54 AM GMT+7
Thanks Jessie but drat! I was hoping to avoid coming up with another question.
Here goes - What aircraft pioneered the type of wing construction used by Boeing on the B 17 and in what way ? ( other than both were cantilevered mid wing monoplanes)
rdt1953
KitMaker: 909 posts
Posted: Thursday, September 14, 2017 - 10:06 PM GMT+7
Bump bump
KitMaker: 16,659 posts
AeroScale: 12,410 posts
Posted: Saturday, September 16, 2017 - 08:53 AM GMT+7
Hi Richard
Seeing as nobody else has answered yet, I'll throw myself on the sacrificial fire with the Boeing 247. If nothing else, it'll cross one contender off the list. ;
rdt1953
KitMaker: 909 posts
Posted: Saturday, September 16, 2017 - 10:50 AM GMT+7
Hi Richard
Hi Rowan - thanks for keeping this alive but no, that's not it - have to look earlier than the 247 , different manufacturer and foreign to boot !
Richard
raypalmer
KitMaker: 1,151 posts
AeroScale: 985 posts
Posted: Sunday, September 17, 2017 - 02:05 AM GMT+7
Junkers J1?
