See Your Ad Here!
Reverse Post Order
REPLY
NEW TOPIC
IMAGE HELP
SUBSCRIBE
The Dockyard: Military Small Craft
For topics on PT boats, landing craft, Vietnam riverine, etc.
Hosted by: Sean Ford
Subject: Italeri 1/35 scale S-100 Schnellboot
Arjan Wiskerke
CALLSIGN: awiskerke
Posts: 231 entire network, 0 this site
_VISITCOMMUNITYCaptain
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Monday, December 08, 2008 - 11:07 PM UTC
Two weeks ago I started working on the new Italeri S-100 kit. I'm very pleased it has finally materialised after some two years of waiting, on the other hand there are some disappointments as well. Moulding quality leaves a lot to be desired , my kit at least has some nasty blemishes on the hull sides (near the pilothouse). This requires sanding but, unfortunately this is a spot that abounds with rivets. The hull construction has not been well-planned either. This involves the use of screws which have to be inserted from the side and are then hidden by plastic plates which should go on top. Unfortunately these plates never sit completely level with the surface of the hull sides, so again a lot of filling and sanding is required. Two of these plates of the bowsection are also surrounded by rivets... Unfortunately there are also some glaring errors. The first is the skylights of the engine compartments, these were not present in these late boats (due to production simplifications), this is the same mistake present in the Revell 1/72 model. The second mistake concerns the "door" in de 20mm guntub (on the foredeck) which should be located at the back and not at the side. Yet another is the omission of the panels located at the back of the Kalotte (near the rear of the torpedotubes). These are just some of the mistakes I have encountered sofar and I'm not even halfway building the thing. I must say that I cannot understand why Italeri didn't bother to do some proper research. Besides, quite a few articles have been written on the mistakes in the Revell kit so if they had taken the trouble to read some of these, the afore-mentioned mistakes could easily have been avoided. Needless to say I'm pleased with the kit but it might have been so much better if only they had tried a bit harder. By the way I would love to share info on the S-100 with other enthusiasts.
Arjan
REPLY
REPLY & QUOTE
HIDE SIGNATURE AREAS
Mark R. Smith
CALLSIGN: Gunny
Posts: 6,347 entire network, 46 this site
_VISITCOMMUNITY_AGUARDALT Master Chief Petty Officer of the Navy
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 09, 2008 - 12:49 AM UTC
Hi Arjan,
Welcome to Model Shipwrights mate!
I too share your enthusiasm of the Italeri kit (although I don't have mine ...yet! ), and will be very interested in seeing your progress...you can have your own personal "BLOG" (Build Log) thread here at MSW if you wish, and let us all follow along as you record your progress with the build...they are a great learning tool for all, for sure!
Looking forward to seeing the build, and I'm sure you'll find more enthusiasts here as well!
~Gunny
REPLY
REPLY & QUOTE
"And all I ask is a tall ship and a star to steer her by..."
Managing Editor, Campaign Administrator, Model
Shipwrights
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Tuesday, December 09, 2008 - 02:31 AM UTC
Thanks for your kind reply Gunny. I should probably have introduced myself first, being a new member. I have been interested in WOII fast strike craft for over 40 years ( I built my first Vosper at the age of 8 and have been hooked ever since). I built all the usual plastic kits of the Airfix, Revell, Lindberg and Italeri range. I must confess though that the British Vosper and German S-boote are my favourites because they often operated off the Dutch coast. Going through the pics I know of the S-100 type, I noticed this week that most vessels of this type have two hatches on the foredeck instead of only one (as is the case with the ""lang" boat modelled bij Revell and Italeri ). I'm beginning to wonder now if this (one hatch only) is typical for the very late versions of the S-100. According to the captions underneath the photographs, the two hatch type is also referred to as the S-100 and not the S-38. Would any of you people know more about this? If this is the case I think that only a very small number of the single hatch type were made. For those unfamiliar with the best Schnellboot site:
http://www.prinzeugen.com/SBOATIND.htm
Arjan
REPLY
REPLY & QUOTE
T. Garth Connelly
CALLSIGN: TGarthConnelly
Posts: 261 entire network, 0 this site
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 03:17 AM UTC
Sir,
If you go to www.ptboatworld.com, there is a build-up article on the Revell S-100 kit which addresses a few of the errors.
Garth
REPLY
REPLY & QUOTE
You've got a question, I've got an answer.
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 06:21 AM UTC
Thanks Garth. It's a very nice site ! Unfortunately the link to the S-100 model doesn't seem to work (whereas the others do). When I tackled the Revell kit some years ago I used this Baubericht (Buildlog) as a guide (helpful to know German though):
http://www.modellmarine.de/index.php?option=com_alphacontent§ion=11&category=188&Itemid=59
Returning to the mistakes in the Italeri kit, I should mention that the tub error can be easily corrected, simply remove the locating notch and turn the tub 45 degrees. The slats on the bottom will now run laterally instead of longitudinally but that is probably as it should be (I don't have any pictures of these slats but that's how they look in the Revell kit). The tub error may, therefore, be simply a mistake made during the production sequence of the kit (not so much a research error). The 3rd mistake I mentioned may be more tricky to rectify. It seems that there simply isn't enough room behind the torpedotubes (with the lid fully opened) to add the panels (struts?) to the rear of the Kalotte. The pic in the Squadron book page 41 top left may explain what I mean. In this picture one can also see two handwheels immediately in front of the struts. Can anyone explain what their function is ? In the Italeri model they are just wheels stuck to the side without any rods or mechanism whatsoever, I will try to post this photo as well but I have a feeling it won't work...
Arjan
REPLY
REPLY & QUOTE
Steve Joyce
CALLSIGN: blaster76
Posts: 8,153 entire network, 61 this site
_VISITCOMMUNITYGeneral of the Army
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 07:24 AM UTC
Can this be made waterline or will you have to chop it? Of course this thing is huge at almost 40" long. (and me the 350 scale king)But I just don't have the room for it, and having dealt with the old Enterprise kit with the screw dstogether hull, I'm not particularly happy with that method of design
REPLY
REPLY & QUOTE
Those who don't learn from history are doomed to repeat it
VMI "76
Order of the Red Nose Plug
Blue Volute Bumper Spring Award
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 08:34 AM UTC
Hi Steve,
You will have to chop it I'm afraid. But in terms of size that will not do you much good. I wouldn't worry too much about the screws, it's a bit of tedious work (sanding and filling) but you will require a punch and die set anyway. The sides of the pilothouse (underneath the Kalotte) are devoid of rivets and there should be quite a few of them . I have no doubt that some rivets will have to be added in other areas as well but I haven't bothered to check that out so far.
Arjan
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
Posts: 319 entire network, 0 this site
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 09:34 PM UTC
Arjan will be keeping an eye on this thread for more info just got the s-100 myself and was hopeing to get some research done in the holidays. Seam as though you have it sorted and is a good shortcut for me to follow Cheers.
Keith
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Wednesday, December 10, 2008 - 10:01 PM UTC
Hi Keith,
On the Missing Lynx forum someone is also beavering away at the kit (in between the Jagdtiger work, so ignore the pics of the latter and you'll find a pic of the Schnellboot):
http://www.network54.com/Forum/110741/thread/1226586840/Jagdtiger+so+far...
Arjan
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 12:38 AM UTC
Removed by original poster on 12/11/08 - 13:18:42 (MST).
REPLY
REPLY & QUOTE
ADVERTISEMENT
T. Garth Connelly
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 03:12 AM UTC
Really, ... the link doesn't work? OK, thank you ... I'll inform my webmaster.
REPLY
REPLY & QUOTE
T. Garth Connelly
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 03:18 AM UTC
Possibility sir;
Those flywheels you mention?
Could those open and close the outer door on the tube?
Garth
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 04:41 AM UTC
Thanks Garth. No, the doors were opened by turning the large crank visible in many photos. This crank is connected to a rod that runs all the length of the tube to the front. As far as I know this mechanism has been correctly rendered by Italeri. On the Prinz Eugen Schnellboot site the photo I posted is slightly sharper and it seems that a rod is faintly visible leading forward from the handwheels. This afternoon I made an abortive attempt to solve the single hatch/two hatch matter. I was far too hasty with my conclusions so that's why I deleted the whole posting. From the squadron book I learned that only with S-138, the official designation changed from S-38b to S-100. To complicate matters further the S-100 type was produced by two shipyards, the majority by the Lürssen Werft in Bremen and a relatively small number by the Schlichting Werft in Travemünde. The series S701- S709 was produced by a third company, namely Danziger Wagonfabrik. Lürssen probably started with the single hatch type during the S167- S 169 series, whereas S 188 from the Schlichting series S 187 - S 194 was still of the two-hatch type. Deutsche Schnellboote 1939-1945 by Jean-Philippe Dallies-Labourdette ( a great book) gives an overview of all the Schnellboot production series and the shipyards that made them.
Arjan
REPLY
REPLY & QUOTE
T. Garth Connelly
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 06:12 AM UTC
OK.
Well, if I can be of any assistance to you, sir, I'd be more than happy to try and help you...
I would like to see photos of your model.
Garth
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 07:57 AM UTC
Hi Garth,
I promise to post some photos by sunday. Don't expect too much though, I'm the type of maniac who spends more time on finding answers than on the actual build .... I must confess I often only finish a model when there are no nagging doubts left. Sometimes this takes years...
Arjan
REPLY
REPLY & QUOTE
T. Garth Connelly
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Thursday, December 11, 2008 - 09:14 AM UTC
Aaaaaaaaaaaaaaaaaaaaaaaaaah, I see.
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 01:25 AM UTC
Well i,ve already started on mine as you can see i may have to extend my work bench just a little bit Have put the 1/72 arfix e-boat next to it to give you an idea of the scale of this thing
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 01:27 AM UTC
wooops forgot the photo
more info to gather
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 02:22 AM UTC
Hi Keith,
You beat me to it . I wonder if your kit also has these moulding blemishes on the hull sides (extending to the pilothouse, for lack of a better description..) or am I the only "lucky" one in that respect ?
Arjan
REPLY
REPLY & QUOTE
Jim Adams
CALLSIGN: goldenpony
Posts: 2,858 entire network, 48 this site
_VISITCOMMUNITYMaster Chief Petty Officer of the Coast Guard
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 02:34 AM UTC
Now that really shows the size difference. I suppose the good thing with the big brother is you should be able to find enough “extras” to really spice up any dio.
REPLY
REPLY & QUOTE
Captain Rockwell Torrey "A fast ship going in harm's way - a lousy situation, Commander Eddington."
Commander Paul Eddington "Lousy!"
Associate Editor / Model Shipwrights
ADVERTISEMENT
T. Garth Connelly
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 03:50 AM UTC
I don't have the room for that monster. Why don't they just do 1:72 kits? Just to make it easier for people with LIMITED shelf space.
Garth
REPLY
REPLY & QUOTE
Ion
CALLSIGN: madwolf
Posts: 256 entire network, 66 this site
_VISITCOMMUNITYPetty Officer Second Class
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 05:11 AM UTC
Revell makes a regular version and a Flak 38 version in 1/72.
REPLY
REPLY & QUOTE
T. Garth Connelly
PROFILE
PHOTOS
MESSAGE
WWW
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 06:19 AM UTC
I've got the regular version Ion, great model, a few errors in the kit, but a good modeler can fix them. There's an article on the build-up my S-100 on my site, and oh guys - the links have been fixed ...
he same article appeared in the IPMS/USA Journal - I just love that model.
Garth
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 07:12 AM UTC
I,ve had a good look at the mouldings on mine and can,t see anything wrong with it will try to get a close up pic of that area and see what you think
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Friday, December 12, 2008 - 07:49 AM UTC
Thanks Keith,
Don't bother, you don't need a close up to see what's wrong with mine. Must have been a monday morning production run...
Arjan
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, December 13, 2008 - 01:08 AM UTC
I finally posted some photos, 10 in the gallery I think ,not terribly modest perhaps(I'm not sure if it worked, I haven't quite got the hang of it). And I will try to post some here:
Some of the pics probably show what I mean when I said there doesn't seem to be any room to add the struts I mentioned before. Some further comments: The worm gear thing at the bow that opens the torpedo tube doors doesn't really look like the real thing. The main vents (there is no pic of them yet) should not be straight as Italeri made them but should gently curve outward (for an unimpeded airflow). Pity Italeri didn't make the navigation lights out of clear plastic (I'm still dithering whether or not to make my own of clear material and put leds in them). The grips on the tube lids are positioned in the middle whereas there is a photo of the right hand tube that shows a grip in the half past 10 position (bit of a strange way of putting it perhaps). I like the pe a lot, I used Gator's Acrylic Hobby Glue for this (which is my modest contribution to the U.S. economy). I really think it's great stuff, works so much easier than superglue and it's easy to remove excess (it's not suitable though for really tiny pe pieces). Perhaps someone can tell what the function is of the pe rack which can be seen in the second pic here, left on the backpanel (bulkhead?) of the bridge ( perhaps for charts, binoculars or a first-aid kit?)
Arjan
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, December 13, 2008 - 01:39 AM UTC
Arjan in the first photo is that the skylights filled in you say are not on the later boats. As to the second photo looks like that is a chart rack or even for other navigation equipment
REPLY
REPLY & QUOTE
Arjan Wiskerke
CALLSIGN: awiskerke
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, December 13, 2008 - 01:55 AM UTC
Hi Keith,
I think you must be right about the chart rack. This item does look different in the 1/72 Revell kit though (the general shape is the same but it's not really a rack there). The photo does indeed show the skylights I filled in. The pictures in the gallery are much clearer though. When I posted them they were in the area of your pt pics I believe. I''m not a computerwizard though and I don't know if you can view them or not. I can still view them but then I have to click on my name. Help in this respect would be appreciated, I think it's all terribly complicated.
Arjan
Postscript: I see they are in the member gallery, can you view them Keith?
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, December 13, 2008 - 02:09 AM UTC
[img][http://gallery.kitmaker.net/data/17291/10912.JPG/img]
REPLY
REPLY & QUOTE
keith richardson
CALLSIGN: beefy66
PROFILE
PHOTOS
MESSAGE
HIDE USER DETAILS
REPLY
REPLY & QUOTE
Posted: Saturday, December 13, 2008 - 02:16 AM UTC
I ,am no wizard at this either but I think you are using the millitary small craft gallery??
which if I ,am thinking is sending pics to you photo file. You need to click on the pic you want to post in the larger view then copy and paste this to the thread I think, but some expert out there maybe will give you a hand like they have done for me sooo many times.There is a link some where with the instructions on posting photo,s,even so i still get it wrong again and again
REPLY
REPLY & QUOTE
Reverse Post Order
REPLY
NEW TOPIC
IMAGE HELP
SUBSCRIBE
TOP
REPLY
 ACTIONS LATEST POSTS FORUM FAQ IMAGE HELP
